Question about HP Officejet 4215v All-in-One Printer
I hve a installed a new hp print catridge but it deos not print
It asks for alignment
It asks you to align it. Press ok. The printer will print off an alignment page, then you have to run it through the copy part of your printer. Then press ok, and it will run through and line things up for you.
Posted on Apr 16, 2009
I recently replaced my printer cartridges in my hp psc 2210 all-in-one and it printed fine the first day. Now all it will do is print the alignment sheets and won't let me copy anything. The...
alighment not sucessfully completed because of one of the catridge nozzles are clogged or carriage assm not reading the align page properly,check the align page is properly printed? if no repalce catridge, if print quality is good clean align reader which was located beside of the carriage... best of luck
Sep 07, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Problem installing an ink catridge
Most HP printers will move the print heads to the center of the printer when you open the front.
Each cartridge has a flip that you can flip up. The cartridge can then be removed by tilting it toward you. You can install a new cartridge by removing it from the box and foil liner. You then remove a strip that protects the head. Like you took out the old cartridge, tilt the cartridge and straighten it up. Flip the flip down. Close the top. You should be ready to go after the heads clean themselves and do an alignment.
If the printing is not satisfactory, you can go to your programs and hp will have a tool to perform alignment.
You can use HP cartridges, refilled cartridges or fill cartridges yourself (depends).
I've filled cartridges with success. However, it can be a bit messy.
Jun 07, 2010 | HP Printer Cartridges (Complete List): ,...
All of a sudden it will not print but as soon as u turn the printer on it prints like a test page
may be you chaged the catridge.
It is not the test page it is alignment test page just put the printed alignment test page paper on scanner glass and press the scan button to complete the process. It is alignment process which is printer is doing for self testing after installing new cartridge. Just finish the process.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 18, 2010 | HP PSC 1510 All-In-One InkJet Printer
I have a HP 4100 printer. Installed new ink.Purple streaks
That's a neat trick. The 4100 is a printer that uses one BLACK toner cartridge. It doesn't print in color. And it doesn't use ink.
Oct 24, 2009 | HP LaserJet 4100 Printer
Print catridge alignment failed
Hello there... I am not savvy about this topic but see this one. I hope this helps... If not, please let me know...thanks!
Best wishes, Ai-ai
Oct 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
Tops and bottoms of letters are cut off. I have changed the ink cartridge
Replace the old ink cartridge.
Verify that the unit is on. The On button is lit when the unit is on. If the device is not on, press the button to turn on the unit. Open the print cartridge door. The print carriage moves to the far right side of the unit. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. When replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. When replacing the black or photo print cartridge, remove the print cartridge from the slot on the right. Pull the print cartridge toward you and out of its slot. If the print cartridge is being removed because it is low or out of ink, recycle the print cartridge. Remove the new print cartridge from its packaging. Remove the plastic tape by using the pink pull tab. Removing the Tape from the catridge.
  1. Will have Copper-colored contacts.
  2. Plastic tape with pink pull tab ( must be removed before installing ).
  3. Ink nozzles under tape
  4. The HP All-in-One prompts for an alignment of the cartridges every time a print cartridge is installed or replaced. Follow these steps to align the print cartridges from the control panel.
  5. Top & Bottom not printing properly.
  6. Load unused, plain, white letter, A4, or legal paper into the input tray
  7. If coloured paper is loaded in the Input tray when the print catridges are aligned, the alignment will fail. Load unused, plain white paper into the input tray when the Printer catridges are aligned, the alignment will fail. Load and unused plain white paper into the Input Tray and then try the alignment again.
    1. Press 6 to select Tools .
    2. Press 2 to select Align Print Cartridge The unit prints a print cartridge alignment sheet.
    3. Load the alignment sheet print-side down and top first in the center of the document feeder tray, and then press OK. Now the printer will print properly.
Jul 29, 2009 | HP Officejet 4315 All-in-One Printer
Black Cartridge
take all catridges out and unplug the power cord and press and hold the ON button for 1 min and plug back the power cord and insert the catridges one by one. Press set up and scroll down to tools and under tools u wil have a option called align catridges or print head, do that it should resolve your issue with the printer.
regards,  raj_p5983
Jan 15, 2009 | HP Photosmart C6180 All-In-One InkJet...
Do not see align or clean catridges at preferences /features
hi,
To Align the cartridges, please perform the following instructions.
  1. Load unused plain white letter or A4 paper into the input tray.
  2. Press the Setup button.
  3. Press the down arrow button to select Tools and then press OK .
  4. Press the down arrow to select Align Print Cartridges and then press OK . An alignment page prints.
  5. After the success or failure message displays, click OK to continue. Recycle or discard the alignment page
Regards,
Sagarjd
Nov 21, 2008 | HP Photosmart C4180 All-In-One InkJet...
Alignment message
to fix this problem place this alignment sheet on the scanner glass as if u were copying somthing n just press the scan button .the power light will blink few times n then stop.which means alignment is complete n u hve fixed ur problem. rate this solution as fixya n encourage us to solve more n more problem in future. thanks bye
May 23, 2008 | HP PSC 1410 All-In-One InkJet Printer
HP Officejet 4215v All-in-One Printer Logo
55 people viewed this question
Seeker5211
Seeker5211
