Question about EliteGroup P4VMM2 Motherboard
I have a motherboard ecs p4vmm2 when i test it for the 1st try it working properly it pasr the post and last day i run again the board and now it won't work can you help me thank you very much
  • 1 more comment
  • Anonymous May 12, 2009
    The PC (P4vmm2 motherboard) does not boot every time it is switched on. It will some time run for some time then just hang. Switching it off and on does not help
  • Yannick Verhoog May 11, 2010
    Wat exactly doesn't work?
    Does the system not boot, i.e. does anything happen, like fans starting, when you start the PC?
    Does it keep rebooting?
    Or is it just your screen not showing anything?
  • ultimitloozr May 11, 2010
    Where is it failing? Is it beeping? Are any POST messages appearing on the screen?
  • 37 Answers
Remove the battery CMOS for serveral hours and place it back in. I need more detail in order to know whats going on.
Posted on Aug 06, 2009
What drivers can use for my video and sound card? ESC P4VMM2
driver for motherboard ECS P4VMM2
On this page you are offered with driver for p4vmm2 motherboard existing in our database. Icons placed on the left of file name will prompt you in which format and in what language driver download ECS P4VMM2 motherboard are represented in this file.
If the needed file doesn't exist, therefore the desired driver is missed in our database. It can be ordered in the File Request section.
You can also try to find the appropriate driver for kindred motherboard ECS models by clicking on the links shown below.
  • http://www.fixdevice.com/drivers/motherboard/ecs/p4vmm2.html
  • http://www.driverstock.com/elitegroup-p4vmm2-driver-download/25-9-3830/index.html
Sep 20, 2011 | Computers & Internet
I have an ecs board p4vmm2, cpu fan is running but i cannot install the os it hung up...any help pls?
Make sure you have the correct memory speed for that motherboard. Also go into the BIOS and set everything to default.
Apr 26, 2010 | Pioneer ECS P4VMM2 V3.2A P4(478)/FSB...
I lost my driver in mother board p4vmm2 how can i install again
Don't worry about it, you can still have the drivers for you motherboard by downloading it from the internet. Just go to there website, which www.ecs.com and there download the drivers. Okay..:-) Don't forget to rate me..Thanks..:-)
Nov 04, 2009 | EliteGroup ECS P4VMM2 Supports Intel...
I want to know the version of my ECS motherboard., specifically the P4VMM2 board
This link will show you exactly how to indentify your ECS motherboard by Model Number and Bios Revision.
Have a great day
http://www.ecs.com.tw/extra/productinfo/MB.htm
Apr 07, 2009 | EliteGroup ECS P4VMM2 Supports Intel...
Ecs p4vmm2 v1.0 motherboard windows xp sp2 can`t get sound to work onboardsound
1st: try enabling the onboard audio devices from the bios setup menu. it should be somewhere in the on board menus.
2nd: try installing the latest drivers from ECS
i did not manage to find the motherboard model you specified. i did manage to come up with these:
p4vmm2[v1.1] drivers http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=46&DetailName=Driver&DetailDesc=P4VMM2%20%20(V1.1A)&CategoryID=1&MenuID=82&LanID=0
and also p4vmm[v1.0] drivers
please re-check the specific model you have and download the driver that suits you
Mar 02, 2009 | Pioneer ECS P4VMM2 V3.2A P4(478)/FSB...
Memory Upgrade - from 256DDR1 to 1GB DDR1
sysa007,
EliteGroup makes two mother boards, P4VMM2, (No Revisions) & (P4VMM2 revision 8.1). Since your question states your memory is 184 pin DIMM your board must be, v 8.1. What does not make sense is the motherboard has two memory slots total.
(If you have 4 memory slots on the MB than the MB can not be the P4VMM2). Below is the link for the P4VMM2 (v8.1).
http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=1&TypeID=1&DetailID=436&DetailName=Feature&MenuID=45&LanID=9
The P4VMM2 v 8.1 can only use, two Double Data Rate (DDR) SDRAM memory modules. These sockets support up to 1GB system memory using 184-pin unbuffered non-ECC PC2100 or PC1600 DDR DIMMs. The two DIMMS you are using must run at the same speed.
Example PC2100 266MHz. OR PC1600 266MHz.
Continuous beeping means the memory is not seated correctly.
When using only one DIMM it should be inserted in the slot closest to the CPU. Re-check your memory. Remove & reseat. Make sure the latches snap closed on each stick of memory while inserting. Below is all of ECS P4VMM motherboards;
http://www.ecsusa.com/ECSWebSite/SearchResult.aspx?q=P4VMM2&f=Products&MenuID=104&LanID=9
Good luck sysa007!
More question, post here.
Thank you for using fixya.
If you find this helpful, please vote.
Mike
Jan 31, 2009 | EliteGroup P4VMM2 Motherboard
ECS P4VMM2 driver
I lost my ECS P4VMM2 motherboard driver, and i need the driver to work my pc completely...
Aug 11, 2008 | ECS RS400-A (V1.0) Motherboard
Upgrading VIDEO CARD
If your motherboard's graphics slot is AGP and your graphics card is AGP then it should be fine if your motherboard is PCI-E and graphics is PCI-E it also is fine make sure your motherboard and graphics are compatible.
May 29, 2008 | Pioneer ECS P4VMM2 V3.2A P4(478)/FSB...
Second opinion for ecs p4vmm2 8.1
It's ok to upgrade the processor to P4 the mother board is capable to run the pentium 4 2.0Ghz only . I said that because i'm using that type of motherboard ecs p4vmm2 with processor 2.0Ghz. But for my opinion the problem of your friend computer is not the processor is about the cooling fan heatsink because if the heatsink is not fit or properly lock the processor is over heating that's why the computer hanging and shutdown. If you can tight the two clip that was broken the problem is solved because i have also the same problem before one of my client computer. but if you friend want to upgrade to p4 it's better to buy also a new fan and heatsink for P4.
Thanks and God Bless
Jemuel
May 08, 2008 | EliteGroup P4VMM2 Motherboard
EliteGroup P4VMM2 Motherboard Logo
183 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
