Question about Hitachi Deskstar 7K80 Hard Disk 80GB, 7200RPM, ATA-6, 2MB Cache, Desktop, 20PACK (HDS728080PLAT200A3021020PK) Hard Drive
HDS728080PLAT20 my hard drive seems to not receive power.. it happened from one day to the next. it isn't my master drive, but it does contain backup worth thousands... PLEASE HELP
  • 1 more comment
  • Angel Lopez Jr Sep 16, 2007
    this is NOT the primary as mentioned above. it isn't receiving power. i tesed the molex connectors on my tower, as well as a few others. they work but not my HDD
  • SANTANORTH Jun 06, 2008
    HDS728080PLAT20 DOES NOT READ INTERNAL BURNERS
  • Sebast Jul 27, 2008
    Same model, when i connect it and turn on the power it takes 2 seconds and everything turns off (the whole cpu), I tested the power of the tower and works fine (everything works but the HD).
    My guess is the controller board is not working so if i look close at the "infineon" chip i found out a little circle that i don't know if it has been there always or if that's the problem. (the circle is on the bottom right if you look at the chip on the proper way to read it)
Plz connect the another Hard disk to the primary drive and restart the PC.
Posted on Sep 14, 2007
Flash the firmware..... just contact hitachi manufacturer,n wait... the program will come to you.... good luck.
Posted on Jul 28, 2008
How do i make a wd5000aakx hard drive a slave drive
http://www.wdc.com/wdproducts/library/other/2579-001037.pdf
Jul 11, 2015 | Conrad WD HDD 500GB SATA 3,5" WD5000AAKS...
Why isn my memorex mks8506 turning on?
Try unplugging from power then hold power button for about 30 seconds or more, plug back in and try it. Have several computers on my work network that do the same thing and that's how we get them to start up again.
May 12, 2017 | Memorex Televison & Video
I have a working hard drive (Barracuda 7200.7) from a 2007 HP Pavilion a430n that contains files that I would like to retrieve.
Your description has me confused. I'm not clear on which power and data cables you are using. You described pulling one cable from first hard drive and connecting it to your second drive. Extra power connections should have been in a loose wire bundle somewhere in the computer. (Often they are tucked into an unused drive bay.)
The SR1720NX has 2 SATA controllers and two IDE controllers. Thus it can have 2 SATA and 4 IDE devices. The computer sometimes shipped with a SATA hard drive or an IDE hard drive. In all cases, the hard drives must be connected to the data cable (and to the motherboard) and then the power connection from the power supply has to be connected. So there should be 2 cables plugged into each drive. The optical drive is usually an IDE drive for this model, also a master drive.
The IDE power connection is a large 4-pin Molex connector; the SATA power cables are a smaller 5 pin connector. There is also a small 4 pin connector that powers a floppy drive, if present. IDE data cables are a wide 40-pin ribbon cable (sometimes an 80-pin cable for master/slave). The SATA data cable is a 15 pin cable.
First make sure that the jumper on the drive from the A430n is across the two pins in the second position (counting from the side away from the power connection). This is the cable select option. Next make sure that the IDE cable is firmly connected to both drives and the motherboard. (I've sometimes loosened the data cable while connecting the drives.) Finally check that the appropriate power cables are firmly connected to all the drives. Then power up the computer. (With the second drive on the Slave connection, if the device on the Master connection isn't powered up/recognized, then weird things may occur.)
BTW: you should be alert to the power needs for the computer. The original power supply could be overloaded with the extra drive. You might be better off using an external drive enclosure (USB) or a USB/SATA/IDE dongle that leaves the drive out in the open. Connect these with extreme care following the directions for when to connect the power supply. Some enclosures won't work without reformatting the drive - you do not want one of those.
I hope this helps.
Nov 24, 2011 | Seagate Computers & Internet
Select as master
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master
IDE-1 means Pri slave
IDE-2 means Sec master
IDE-3 means Sec slave
single or master :::::
master with slave ::'::
slave :::':
black line between dots is plastic jumper
note the plastic jumper is ' located at the rear of the hard drive between the EIDE and electrical lead/s
Nov 14, 2011 | Samsung (SP0411N) 40 GB Hard Drive
Pri Master Hard Disk:S.M.A.R.T. Command Failed
You do not seem to have a smart capable hard drive, disable the setting in the BIOS by pushing F2
Jul 05, 2010 | Computers & Internet
My hard drive has stopped being recognised by my computer! Please help! One day it was working fine and then the next it just completely stopped being recognised by the computer. I have tried the drive in...
that really happens when hardisk crashed..
there is nothing to do but replace it.
but wait.. I have experience that also, could not retrieve all my files in my drive. So what I did is hide it in my stock room for a couple of weeks.
Then one day when i am about to throw away the drive,I get this crazy ideas to try my hardisk again as back up drive.
I connected my drive, put the jumper in it as slave and open my computer.
At first, it reads very slowly after booting, hardly recognized the disk, but it did...
when I am in windows and started browsing the disk, it would take it some time before loading all the files.
When that happened I back up those files and save that to my master drive.
Don't lose hope It might happen to you..
I think what happen is when I hide the disk for a couple of weeks the disk itself discharge all the left volts in it.. not sure about that.
May 19, 2010 | Iomega Black Series USB 2.0 & FireWire...
Delete info from an external hard drive?
run diskmgmt.msc delete. then create then format .. also theres a tool called Wipedisk from www.thefreecountry.com/security/securedelete.shtml
Jul 21, 2008 | Maxtor Hard Drive
Burners cannot be read
Do a search for PC Fixer, a free tool. I had this problem on a Gateway I was trying to add this drive to. PC Fixer fixed the CD-ROM problem, but the drive seems to not be compatible with the Gateway for use as a master boot drive.
GC
Jun 06, 2008 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
New internal hard drive not showing up
Did it showing on MY COMPUTER AND MENAGMENT CONSOLE???
Nov 15, 2007 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Computers & Internet Logo
1,306 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
