Question about ASUS Eee 4G Notebook
My Asus F2 series notebook won't turn on. I plug it in and nothing happens, so i press the on button and this light bulb symbol thing lights up, then another cylinder shaped symbol flashes, then they both go out. I press the power button again, and it does the same thing! How do i fix it?
My Asus LaptopModel X205Ta is fully dead and won't charge or turn on.
MF. Could be the new charger is faulty, return charger for exchange or refund. Battery could also be faulty, have it tested if you can by a computer tech. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My laptop notebook will not turn on
my asus laptop wont even charge or turn on after it shut off mid windows...
Laptop Won Come On Even When Connected To Charger
Why Won My Laptop Turn On Even Though It Plugged In
Jul 09, 2016 | ASUS Computers & Internet
Asus eee pc 1000ha wont take charge from adapter
try unplugging from the mains, remove the battery, hold the power button down for 30 seconds. plug the mains adapter in and try turning on. if it doesn't work then it's either the power socket or the mainboard.
if it does work, then try it again with the batter in. if it stops working then your battery's shot.
Apr 13, 2013 | ASUS Eee PC 1000HA Notebook
Asus Eee PC 1005HA wontl load OS
what key do you see during the boot up process
you should see a certain key it will be very quick you might have to restart a few times to get a good look
try pressing the delete key
hope it helps
Apr 09, 2012 | ASUS Eee PC 1000HE Netbook
Won't Turn on, not even when connected to mains - LED lights on but no HDD drive light
The HDD can go at anytime without warning, does the Asus logo come up on the screen?
Apr 08, 2012 | ASUS Eee PC 1000HE Netbook
How do you restore a asus eeepc notebook 1001ha/1005 series
Turn it off. And as it turns on press F2. Then it will prompt for the advance option then press F8. When the menu comes up press "repair my computer". choose the restore to factory. Make sure you back up files that you want to keep. Caution: Make sure you charge the laptop full and keep it plugged in. If the there is a power failure and your laptop runs out of battery, it would mess things up.
May 24, 2011 | ASUS Computers & Internet
I was told press F2 simultaneously on startup, nothing happened
You need not to press F2 or tab or escape unless you need to do so. If your system is ok, it'll automatically boot up, but if there's boot up problem with your system, then that's different. Thanks for using FixYa.
Jun 06, 2010 | ASUS Eee PC 1000HE Netbook
Won't turn on, black screen
seems to be a hardware issue (not easy to diagnose over the net) I would take it into a shop and have it looked at.
May 28, 2009 | Dell Inspiron 1525 Notebook
My laptop acer aspire 3100 crashed. it was fine before i turned the laptop off, but when I tried to turn it on again it got stuck starting windows up, I have Vista. I waited for some time but after 30 min....
Hello rijotomas,
First you can try to pull the battery out and unplug the power adapter for a minute. Then plug the laptop back in without the battery. Then try to turn it back on.
Feb 23, 2009 | Acer Aspire 3100 Notebook
Laptop will not respond
It sounds to me that you may have an issue with the keyboard itself, as most BIOS will stop on a keyboard error unless told otherwise. But, this could be a malfunctioning keyboard, or a disconnected keyboard. 1 way to test either is to press the caps lock, num lock or scroll lock keys and verifying the corresponding light turns on and off with the button presses. If they do not respond, it's likely the keyboard has become disconnected internally. Other issues may also cause this to happen, but they are harder to test for. If it does respond, then it's more likely to be a keyboard failure, and a replacement of the keyboard may be required.
Hope this helps!
-Backu
Jan 16, 2008 | HP Pavilion ze2000 Notebook
ASUS Eee 4G Notebook Logo
567 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
