Question about Brother HL 5250DN Laser Printer
Toner and Drum Display Reset
We have 11 brother printers in our office and we are having the same recurring problem. The toner light and the drum light are staying on even when the toner cartridge and drum was replaced, and the printer was non-operational. However a local printer company was able to reset one of the printers fixing the problem, but they will not divulge the information and was wondering would anyone know how to do this as this is a common problem with these printers.
  • 3 more comments
  • Anonymous Apr 20, 2008
    HL-5240 how to make drum reset
  • Diana Townsend Jun 09, 2008
    Having the same problem. And I did read the instructions! And followed them for reset. Then Toner light started coming on. Toner is fairly new. Replaced toner and light still coming on.
  • Anonymous Jun 10, 2008
    The toner light came on - we changed cartridges and the litght remains on and the printer will not print. We have tried resetting according to the instruction in the booklet - it did not work. Any suggestions?
    Thank You
    Francine
  • Kelly V Aug 01, 2008
    Our drum light started coming on a couple of weeks ago. Today I replaced the drum unit with a new one and the light is on again!
  • Anonymous Mar 31, 2014
    HAVE hl2240 - HAVE BEEN USING NON-OEM TONER WITH NO PROBLEM. WHEN I RECEIVED THIS CARTRIDGE I TESTED IT AND PRINTER WORKED. I PUT IT AWAY. NOW WHEN ITRIED IT, IT DOES NOT WORK - COULD IT BE THE DRUM?
After replaceing the drum keep front panel open while holding down the go button. Once all lights turn amber release go button.
If you close the panel the reset does not work.
Posted on Jun 09, 2008
Open the front like your going to replace the toner/drum remove the drum then press the "GO" button and hold for 6 to 10 sec and all the lights will light up then release the button put the drum back in and close the machine up this should resolve the problem. make sure you test print could have a few print smears but will go away after about 5 pages. hope this helps. Ted
Posted on Dec 12, 2008
Tedfarinajr is absolutely correct! You must have the drum and toner OUT when you hold down the GO button. Leave the drum and toner in and it will not reset. Thank you!!
Posted on Feb 02, 2010
  • Mergatroid Jul 07, 2011
    They will reset fine with the drum and toner installed (I just did one). You just have to have the front door open and hold the "go" button down until all the lights are lit.
    Please note. If you have a lot of toner dust inside the machine and some gets in the high voltage grid, it can cause arcing which in turn causes little flashes of light that can fool the machine into thinking the toner is low. Make sure the drum chamber is fairly clean as well as the drum itself. As someone else mentioned, don't swap toners between machines The bias voltage changes depending on how much toner is in the cartridge. If you put a different toner in, that makes the bias voltage wrong and you may affect your print quality. Only replace toners with new cartridges, and avoid the crappy refills (you wouldn't reuse your oil filter in your car would you?). No, I'm not a "repairer", I'm a service technician/engineering technologist.
  • claudio_coma
    claudio_coma Feb 14, 2013
    grazie del prezioso suggerimento a tutti voi
    Scholar:
  • 77 Answers
All right, I'm going to take a major hit here. EVERY toner and drum unit comes with INSTRUCTIONS how to reset the counters. Your local company did you a favor the first time. I don't know what business your in, but let me know so I can call you consistently for your free but OBVIOUSLY knowledge that is COMPLETELY without value. Since you've obvioulsy thrown the instructions away, they are on the Brother website. HINT: leave the front cover open. If you wish, you may personally lambaste me at: biztechsvcs@hotmail.com Ed Paulinski
Posted on Sep 17, 2007
    Scholar:
  • 78 Answers
The toner cartridge on you machine has a gear mechanism on the side set to reset the toner when its new. Its basically to stop the refillers just refilling the toners. The local repairer has just rewound the gear to the right spot. I have done this myself as I'm a repairer myself. As you have 11 printers do not interchange toners as it confuses the printers as to how much toner is catually left. The drum reset should be in the box with the new drum. With the Brothers it usually involves holding down the button while powering on.
Posted on Jan 21, 2008
    Actually, it's to reset the toner bias voltage when a new cartridge is installed.
    New Friend:
Have lines running on printed paper
Posted on Feb 05, 2013
Douche.
Posted on Apr 11, 2008
    ^^^^^Mature Adult^^^^^
My printer says drum troubleshooting contact guide manual and maintence I did eveything but still not working
If the display shows drum error you can try cleaning it by following the steps below:
1. Open the front cover. 2. Pull the drum (black) and toner (gray) towards you, put a little force on it. 3. Remove the toner by holding down the tab on the side of the drum, then pull the toner out. 4. Use a dry lint-free cloth to clean the roller inside the drum unit. Make sure to remove any excess toner from it. 5. Put the toner back to the drum, make sure that it clicks, Reinstall the drum and toner back to the machine, 6. Close the cover.
If the display still shows drum error, go ahead and do the drum reset.
1. Open the front cover 2. Press the Options button on the control panel 3. The display should show "Replace Drum - 1. Yes 2. No 4. Press 1 to reset the drum count 5. Close front cover. The display should show the date & time
If still it shows drum error, The drum unit needs to be replace. After replacing the drum unit, do the drum reset again,
Hope this helps.
May 08, 2011 | Brother MFC 7420 All-In-One Laser Printer
I have a HL 2070 Brother printer That that toner light will no go off, I replace with a new toner and after that did not keep working, I tried to reset the toner opening the front door, also holding the go...
Hi there!
You can remove the drum and toner, remove toner from the drum unit then gently rock the toner from side to side for about six times to distribute the toner inside, then on the drum unit slide the green tab on the upper left hand from left to rigth for about six times and then put it back to the home position. Reinstall the toner back to the drum unit and then put the drum and toner back to the printer. closed the front cover. the toner light should turn off,
Hope this helps.
Mar 28, 2011 | Brother HL 5250DN Laser Printer
Does the 'Drum Near End' message for MFC 8460N mean to indicate the toner cartridge needs replaced?
Same with our Brother 8640N, drum near end means toner is nearly to end but sometimes even you replace bew cartridge is appears this message. TONER LIFE END message need to replace cartridge.
Dec 17, 2010 | Brother MFC-8660DN All-In-One Laser...
Drum light flashes
This means that you will need to replace the drum soon. Order a new drum and when the light becomes steady or the print quality becomes poor, replace the drum. The drum should last ~12,000 pages. The part number is DR350. You may be able to order this from your Office Supply store; otherwise try the Brother Mall site: http://www.brothermall.com/Accessories/AccessoryDetail.aspx?AccessID=DR350&AspxAutoDetectCookieSupport=1 .
The procedure is similar to replacing the toner but instead of putting a new thing of toner inside the drum, you remove the toner and put it in the new drum. Open the front cover and pull out the drum and toner assembly. Place on newspaper or other disposable material (toner may spill). Push down the blue lever to unlock the toner cartridge. Remove the cartridge from the drum. Unpack the new drum (keep it out of the light until ready to replace the drum). Push the toner cartridge into the new drum until it locks into place; the blue lever should lift automatically. Put the assembly back in the printer. Clean the printer as recommended in the manual while it is open; this includes cleaning the corona wire before replacing the drum assembly.
After replacing the drum, reset the drum counter: with the printer on and the drum light blinking, open the front cover and press and hold the GO button until all of the LEDs light up (about 4 seconds). Then release the GO button and close the cover. Check that the drum light is off. (The manual says you should do the reset first but I tend to avoid this in case of distractions.)
I hope this helps.
Oct 06, 2010 | Brother HL-2040 Laser Printer
My all-in-one printer keeps telling me that I need to change the drum soon. I bought a new drum inserted it into the printer and now I can't print anything. Plus, it is still telling me that I need to...
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
Note
    Brother strongly recommends that customers do not use generic drum units and/or toner cartridges, or refill their Brother toner cartridge. Each Brother laser printer is designed to work at pre-set temperatures that are matched exactly to each of our individual toner formulations. Each individual component is designed to work with the other to ensure quality and reliability. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability. The Brother limited warranty does not apply to any problem that is caused by the use of unauthorized third party drum units, toner cartridges or toner.
    If you are using a genuine Brother drum and toner and after following this procedure the unit continues to show "CHANGE DRUM SOON", your machine may require service. Please contact the Customer Service Center.
May 01, 2010 | Brother MFC 7420 All-In-One Laser Printer
How do I replace the drum on a Brother hl 2040.
I have 'reused' the same drum three times and still prints like a charm.
Open the toner door and pull out the toner/drum assembly. Take the toner off the drum tray. Use a alcohol pad or lint free cloth and wipe the mauve coloured drum to remove the excess lint and toner collected on the drum. Rotate the drum with the white gear and keep cleaning until the whole drum is done.
Put the toner back in the drum tray. Clean the corona wire by sliding the blue tab back and forth 3 or 4 times. Put the toner/drum back into the printer and close the door.
After the printer does the self test the drum light will cone on again so then you need to reset the counters.
Open the door again
Hold the GO button until all 4 lights are lit up
Release the GO button
Close the door
Printer will self test and should extinguish all the trouble lights.
Apr 10, 2009 | Brother HL-2040 Laser Printer
The drum light came on (Brother HL 5240) and I replaced the drum with a new one and it still will not work... Any suggestions?
I continued looking and found where someone else had the same problem. I opened the front cover, held down the go key for 10 seconds and closed the door. This reset something because it works now.
Thanks
Jan 20, 2009 | Brother HL-5240 Laser Printer
Drum light HL-2040 Brother
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
On older models
  2. Remove the drum and toner
  3. Press the Go buttom button until all lights are lit, (they come on one at a time) then release it.
Oct 14, 2008 | Brother HL-2040 Laser Printer
Brother 8460n - toner error
Hi, This worked for us:
The message "Toner Error" is usually caused by the drum and/or toner
cartridge not being installed properly or if the machine does not
recognize the toner. To clear this message, follow the steps listed
below:
1. Verify you are using Genuine Brother Cartridges. Brother strongly
recommends that you do not refill the toner cartridges provided with
your machine. We also strongly recommend that you continue to use only
Genuine Brother Brand replacement toner cartridges. Use or attempted use
of potentially incompatible tone cartridges in the Brother machine may cause damage to the machine and/or may result in
unsatisfactory print quality. Our warranty coverage does not apply to
any problem that is caused by the use of unauthorized third party toner
and/or cartridges. To protect your investment and obtain premium
performance from the Brother machine, we strongly recommend the use of
Genuine Brother Supplies.
2. Make sure that you are using the correct drum and toner cartridge(s)
for your machine. The part numbers for your model are as follows:
NOTE: Some cartridges can look EXACTLY the same among different models
and will fit the machine even if they are not designed for use in that
model. Verify the part number before using the cartridge(s).
TN550: Toner cartridge (standard)
TN580: Toner cartridge (high yield)
DR520 = Drum unitt.
3. Make sure that the cartridge is not damaged. Remove the toner
cartridge by following the steps listed below:
a. Press the cover release button and then open the front cover.
b. Remove the old drum unit and toner cartridge assembly. Place it on a
drop cloth or disposable paper to avoid scattering toner.
NOTE: Be careful not to spill the toner. If toner gets on your
clothes or hands, wipe or wash it off immediately with cold water.
c. Hold down the blue lock lever on the right and pull the toner
cartridge out of the drum unit.
d. Look at the toner cartridge and see if any parts or pieces appear to
be broken or missing, if so, the cartridge may be defective and should
be replaced.
4. If the toner cartridge is not damaged, reinstall it into the drum
unit. If it was damaged, use a new toner cartridge and reinstall it into
the drum unit.
5. Reset the drum/toner unit into the machine.
6. Close the front cover.
7. If the message "Toner Error' continues to appear on the display
unplug the machine from the wall outlet.
8. Open the front cover and remove the drum and toner assembly.
9. Look inside where the drum was. On the left side wall, look for a
small, black plastic lever/actuator. A flashlight may help see it.
10. Using the palm of your hand, slide it along the left wall in and
out a few times as this may free up the actuator/lever in case it is
stuck. The actuator/lever is spring loaded and needs to move back and
spring forward to operate correctly.
If the lever does not move, spring back or is missing and your machine
is within warranty, you can locate a Brother Authorized Service Center
(ASC) in your area or contact Brother Customer Service by calling
1-877-Brother (1-877-276-8437) Monday through Friday, excluding
holidays. If the machine is out of warranty, you can locate a Brother
Authorized Service Center using the information listed above.
If the lever moves freely and springs back to its original position
continue to Step 11.
11. Reinstall the drum and toner assembly, close the front cover and
plug the machine in.
Aug 12, 2008 | Brother MFC-8460N Laser Printer
Reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Jan 06, 2008 | Brother MFC-8860DN Printer
Brother HL 5250DN Laser Printer Logo
20,098 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
