Question about Whirlpool 24 in. GU2500 XTP Built-in Dishwasher
My soak/scour light is blinking and cant get my dishwasher to work. Any solutions would be greatly appreciated on how to fix the problem
    President:
  • Whirlpool Master
  • 2,651 Answers
Generally any time a button continuously flashes, you either have a bad door switch that doesnt recognize door closing, therefore will not start, or the electronic keyboard/touch pad is shorted out, in which case youll need to replace the console assy
Posted on Apr 29, 2009
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
Quite partner iii soak and scour light blinking. Machine wont run
Open the door, press cancel, wait for about 10 seconds, reprogram after you read the owners manual. when that light blinks it's telling you that your not programing something properly.
Dec 27, 2014 | Whirlpool Dishwashers
How do i reset the consol on a westinghouse dishwasher with the buttons rinse only, quick wash, china crystal, normal, pots and pans, soak and scour, hi temp scour, sani scour, air dry and cancel?
Normally you will have to press High Temp and Air dry button alternatively 3 to 4 times within 8 secs until the whole panel lights up. Then press Cancel. That should reset the dishwasher.
Hope this helps. Welcome to fixya.com.. It is a public forum and you can also answer questions by selecting Solve Problems and answering solutions for problems on categories that you are comfortable with.
May 03, 2014 | Westinghouse Dishwashers
Pots/pans and normal wash cycle lights blinking fast and soak/scoure continuously lit and start light blinking slow all at the same time. Tried cutting power to reset, it didn't work.
Normally removing the power will clear this error code, if not the touch pad is bad. This is a simple repair, you can watch a video that explains how to repair this yourself at the link below.
http://www.appliancerepairlesson.com/
Mar 08, 2011 | Dishwashers
Lights are blinking and nothing happens when you push buttons
Have you tried pushing and releasing the sani rinse button, then the heated dry? go back n forth several times. If that doesn't work try the soak and scour and hi temp wash buttons and re post results
Feb 20, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Problems with Whirlpool dishwasher model GU1500XTKB0
have they checked the thernals on the bottom of the tub
Mar 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Error soak and scour light comes on wont wash
press and hols start button until it resets then try again.
Feb 20, 2008 | Whirlpool 24 in. GU1500XT - Multiple Color...
Hotpoint DWT10 Dishwasher error codes/lights
food stuck in drain pump remove and clean out or scoop out - soak up all water then fill with 3 or 4 hot litres of water . cancel programme , start new one ( first thing unit does is switch to drain cycle ).
Then rock machine back and forth - this sometimes frees jammed debris thus pumping out of machine.
This works for me i have done it several times and it works
Jan 26, 2008 | Dishwashers
will these units (silo and jtrip) start back on their own? if so, it is likely they are heating the water.
otherwise it sounds like a logic board, unless there is a defective door switch or sensor issue.
electronics seem to be a recurring problem with whirlpool.
i would ask whirlpool (electorlux) to either buy it back or fix it.
good luck
mark
Jan 09, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Blinking Quick Rinse
brent, After doing a little research on this model, I see that Sears put out a service flash concerning this problem. Dishwasher stops in mid cycle and one or more of the lights are flashing. SF22-715. The correction is to replace the existing board with an updated board that controls the line voltage better. Part number 8530928. You could be covered under this flash. The tech will have to eliminate the possibility of a stuck or shorted keypad which will cause this same effect. You can try to get this back in operation by pressing in this order: high temp wash-air dry-high temp wash-air dry. This will put it into a self test mode. Just let it run through if it works. If you don't have those keys try power scour-air dry-power scour-air dry. Catriver...post back.
Nov 19, 2006 | Kenmore 16639 Built-in Dishwasher
Whirlpool 24 in. GU2500 XTP Built-in Dishwasher Logo
428 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
