Question about Gestetner DSc224 Copier
We have a gestetner DSC224 in the office, it had been setting for 7 months. When starting back up we received an SC570 error, we filled the oil but now cannot get tp SP mode to complete the process any suggestions?
  • 227 Answers
Turn the main power switch off
then on before entering SP mode.
Reset the SC (set SP5-810 to 1),
then turn the main switch off then
on again.
Posted on Apr 15, 2009
  • Arthur Hoffmann
    Arthur Hoffmann Apr 15, 2009
    Let me know if that worked for ya
DSC224 printer displays low on fuser oil
There is a sensor that need to be cleaned if the code will not clear. I believe there is a black float that is part of the fuser bottle. If you swing out the oil bottle and look where the float would be... There is a sensor, clean the sensor and make sure it is plugged in correctly... Good Luck
May 22, 2012 | Gestetner DSc224 Copier
I have a problem with my copier i cant make a copier first it indicate that no oil i went and buy the oil but still so please help me. my number SC570
See? Ya need to listen to the baby. It told you it was low for days. Ok, I have to assume you have filled the oil bottle.But now the copier can't know that. We need to reset the error code.You will need to go into the SERVICE MODE in order to do this. In order to go into sevice mode you must press a few buttons. Locate the yellow CLEAR button located above the 9 key pad. Now locate the red STOP button at the bottom. Ok, press the Clear button for a moment and then press the numbers 1-0-7, then press the STOP button. So....CLEAR(release) 1(release) 0 (release) 7(release) then press and hold the RED STOP button for 5 seconds. The screen will change indicating you are in service mode. On the menu you will see tabs. Select COPIER. Now you will see a new screen that will have several tabs across the top.SP DIRECT should already be highlighted, if not touch it and highlite it. Now, use the keypad and press "5810" and then press the # sign. When you press the # sign the display should ask you if you want to EXECUTE. Press EXECUTE. Now unplug the copier. Wait a second or two and plug it back in. This should do it.Glad to help and please let fixya know I helped you. SPINAL
Jun 17, 2011 | Gestetner DSc224 Copier
Dsc224 ploblem sc142
Error Detection White Balance
The White Balance can not be resolved glass or optical section
within the target at the Spotted
automatic gain control. Card SBU defective
Map BICU defective
Exposure lamp defective
• Cruise the lamp defective
May 31, 2011 | Gestetner DSc224 Copier
I have aficio Dsc224 and i used wrong towner color i used aficio C1224 by mistake and the machine not work propebly ..
The toner for Ricoh 1224C and the Gestetner Dsc224 are the same. Here is a link to show you that the toners are the same for this series.
Good Luck and Thank You for using Fixya.
WheatlandServices
http://www.precisionroller.com/search.php?q=1224C+toner
Dec 21, 2010 | Gestetner DSc224 Copier
Postscript Option (PS/3 DIMM) for a Gestetner DSc224
either from a local dealer or you try and google it or Ebay
Sep 15, 2009 | Gestetner DSc224 Copier
I HAVE PROBLEME OF GESTETNER DSC224 ERROR COPIER SC570 .
Fuser oil end On the rear of the copier is a cover that is near the lower center of rear cover you need to add silicone oil (fuser oil) to the copier and cycle power. Oil P/N A2579550
-Carl, please let me know if this helps.
Jun 18, 2009 | Gestetner Office Equipment & Supplies
Reset admin password for web-interface
If you're 'ok' with resetting all the network info such as Ip address, Etc - not to mention the scanner locations, fax speed dials etc. then you can email me. I will give you the instructions to reset "NCS" which will set all network settings to default, but I haven't got the time to walk you through all of the reconfiguration settings - - you're on your own there.
sandy_macneill@hotmail.com
I don't post service mode adjusmtents here
Apr 08, 2009 | Gestetner DSc224 Copier
Gestetner DSC224 Scanning and Fax Issues
scanrouter? disable delivery server from scanner menu
Jan 22, 2009 | Gestetner DSc224 Copier
Sc 570 error code
SC 570 means Fusing oil end.
You have insufficient oil in the oil tank situated at the rear of the machine, please fill up with correct oil.
Afterwards please enter SP mode 5-810 and set to 1, then switch off and on the machine.
If you have sufficient oil in the tank and sc570 re-occurs, you have a defective oil pipe, oil pump or oil end sensor.
Dec 23, 2008 | Gestetner DSc224 Copier
Error code sc142
I could not find any detailed explanation of what this "service code" means, but most of the "what to do" answers on their website say to contact your local sales/service office. Here is their website: http://www.gestetnerusa.com
Feb 23, 2007 | Gestetner DSc224 Copier
372 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
