Question about Refrigerators
Flashing red light on ice maker control unit inside freezer
I'm trying to determine why the red light is flashing on my ice maker control unit (inside the freezer). My model is the Thermador KBUDT4865E01 - I can't find any information in my owners manual on what this red flashing light means. Any assistance would be appreciated. Thanks!
  • 2 more comments
  • gojimmie48 Apr 15, 2009
    About 6 months. It was bought brand new off of ebay so I'm not sure about a warranty.
  • gojimmie48 Apr 16, 2009
    No but the fridge does say the filter is at 5% so maybe that's what it is. Seems to be making ice okay though. I'll change out the filter and see what that does although Thermador says I shouldn't have to change out the filter already (at $30 something each, I'd hate to have to do it this often) but we've had some issues with a new well and dirty water. Thanks much!
  • Raymond Ramirez
    Raymond Ramirez May 11, 2010
    tNormally the ibdicates a new filter is needed or the filler is having problems not filling the ice maker in the allowed time. Have you changed the water filter?
  • Raymond Ramirez
    how long have you had the unit for?
  • 331 Answers
I understand the price seems pretty high have you tried an OEM for a better price. I am understanding that your filter is a common filter 4396510 I think is the aftermarket number
Posted on Apr 21, 2009
BROKEN INFRARED ICE CONTROL - ON WHIRLPOOL SIDE BY SIDE. CAN I REPLACE THAT PART?
The part you need to replace is 4389102 this comes with both boards and replace them as a pair. I have a question though, is the harvest fingers in the ice maker at position like a clock? Also to confirm the flashing of the light when the flap is depressed it 2 flashes and a pause? Not 1 flash and a pause, this means unit is harvesting and the ice maker should be moving and if not the ice maker could have a broken gear. This control unit could run you about 100 buck so make sure this is what you need before your purchase. Good Luck
Jul 28, 2014 | Whirlpool Refrigerators
The ice maker has stopped working. The light inside is flashing red. I checked the manual and nothing is stated about the red light flashing in the troubleshooting section. I've checked the lines and...
this sounds like a control board circuit problem..but first remove perishables and defrost freezer ..turn off or un plug..leave refr door closed..freezer door open..if you have lots of water while defrosting you almost cirtainly have froozen the evap coils solid..freezer cannot work like this..after defrost..plug in and see if temperature returns to normal..if it does it won't last indefinately..your probably have a bad defrost timer and/or evap heater gone bad
Apr 22, 2010 | Refrigerators
Ice maker stop making ice red light flashing inside freezer water dispenser still works kitchenaid kscs25
the emitter/receiver has gone bad and will need to be changed out. the part number is 4389102 at about 130.00
Feb 28, 2010 | KitchenAid Superba Architect KSCS25INSS...
Red light flashing on ice control panel in freezer section of my Whirlpool gold GS6NHAXVT02. I have the setting on ''on''.
The red light is supposed to flash. The number and frequency of flashes is a diagnostic tool we use to determine what is wrong if the icemaker is not working. If your icemaker is not working, count how many flashes before it rests, and let us know. Good Luck, Appliance Specialists
Jan 21, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The freezer and the fridge are not on but the
flashing light stating that its too warm .. compressor probably is not running / power is ok or lights would not be on . look for a bad relay . somethes you can here clicking in back.. that is the comp trying to start .**** hop this helps you mmm leave feed badk pls .
Dec 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker stopped working, red light is flashing, however water is working? What is the problem, how do I fix?
For the red light try removing or replacing your filter.
The ice maker usually has a make ice bar about it inside the freezer. The down position is usually on.
Dec 02, 2009 | Kenmore 23.1 cu. ft. Side-By-Side Counter...
Red Light Flashing by Ice Maker on and Off switch
Red light flashing and NO ice. I used a hairdryer to hopefully clear the frozen waterline and it made 1-ONE row of ice and stopped and the red light still flashing. help!
Oct 22, 2008 | KitchenAid Superba Architect KSCS25INSS...
Strip between freezer & fridge
light falshing is normal, the strip between being hot is not though, remove the kickplate from under refrig and vaccuum the coils, pull unit out and clean behind, while there make sure that the fan adjacent to compressor is running(when compreessor is on). clogged condensor =hot mullion stip. not a major problem
Mar 02, 2008 | Kenmore 51252 / 51254 / 51259
Ice maker not making ice.
These Icemakers have plastic gears on the modules that are breaking, also some have thermostats that are malfunctioning. I recommend haveing an experianced tech look at the unit to see if you need the new upgraded indoor ice maker.
Jan 14, 2008 | Kenmore 21.7 cu. ft. Top Freezer...
Refrigerators Logo
1,364 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
