Question about Kenmore 98702 Stacked Washer/Dryer
Power to dryer
Dryer was working, and now nothing. its kinda like there is a switch turned off. is there a breaker inside somewhere to be reset? I have a stackable WCI - model #MLE655DW0 - serial #XE64553129 - mftr date 11/96
  • 1 more comment
  • Anonymous May 14, 2008
    is there a any enternal fuse for dryer
  • Anonymous May 27, 2008
    Dryer beeps
  • raulgonzalez Oct 15, 2008
    how can i check for current with meter
    Problem Solver:
  • 19 Answers
It is a lid problem
Posted on Oct 31, 2007
SOURCE:
No power at all, trouble shooting says to reset the breaker, but no info on how to do it, any suggestions
There is a breaker box somewhere in your house or garage, or even outside where
Electric meter is. Find that and inside it there should be a 220v breaker for your dryer. Turn it completely off then back on. If that doesn't help, then there is an internal problem with the dryer.
Oct 01, 2017 | Dryers
Cant't get house battery power.Holding batt switch over door in store position allows system to work, use position , nothing. Where do I look?
If you have to hold any switch for any system to work, replace the switch. Bad contacts inside the switch.
Jul 23, 2015 | Cars & Trucks
Dryer not powering on
The second frying of the switch indicates a major problem somewhere. Start at the receptacle and work your way back to the inside of the dryer and see that everything is tight. I think you will find that the problem lies at where the wire ends at the block inside of the back of the dryer. This might be ugly. Dryers conduct a lot of heat and electricity and can be safe if wired properly. Your breaker may need to be reset. Turn it off and then back on to get it to start up.
Feb 22, 2013 | Whirlpool LEW0050PQ 3.8 Cu. Ft. Electric...
SHORTED THE DRYER BY TOUCHING WIRE TO BODY, THERES POWER INSIDE THE DRYER(LIGHT ON), BUT NOTHING HAPPENS WHEN SWITCH IS ON, CONTINUITYIS GOOD ON START SWITCH, WHERE DO I GO NOW
Power to the dryer is 220 volts, with half of the total voltage supplied by each of two breakers. The breakers are combined into one larger breaker, but each side of the breaker connects to a different buss bar in the breaker box. What it sounds like is that one half of your breaker is tripped, and the remedy is to trip the double breaker in order to reset the half that is tripped. If tripping the breaker off and back on does not restore the operation of the dryer, trip the breaker back off, unplug the dryer, and check for any burned wires at the terminal strip where the cord connects to the dryer. Replace any defective or burned parts.
Best regards, --W/D--
Mar 06, 2011 | GE DBXR463EBWW Electric Dryer
My GE profile model dpgt750ec dryer will not turn on - checked breaker okay, light comes on inside the door, but no power when attempting to turn on
Recheck breaker turn the breaker all the way off and then reset the breaker. Then try a different cycle. like air only or something different than you normally use and see if it works then. Motor could be out or The control switch. Make sure you are looking at a double pole 220 breaker. hope this helps.
Dec 19, 2010 | GE Profile Harmony DPGT750EC Electric...
I have a Kenmore 70 series. About 10 years old. The inside light comes one, the timer ticks when turned but nothing happens when I push the start button. We have already checked the breaker. Is there...
you either have a blown thermostat, blown thermal fuse, or a bad heating element most likely a blown thermostat
email me if you need more help in replacing or testing
Nov 16, 2010 | Kenmore 73952 Gas Dryer
Dryer turns on briefly, then does not keep going. belt is fine and also manually turned to see if it was a reset. after turning on it dies...then after turning on nothing at all. power to motor is fine and...
It doesn't work at all If your dryer doesn't work at all, it could be because of problems with: Power from the house Door switch Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker. Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing
Jan 02, 2010 | GE 5.8 Cu. Ft. 2-Cycle Extra-Large...
Dishwasher doesn't turn on at all
fan fail safety switch
over heat safety switch
machine power switch
burnt out power cord test these first
Jul 19, 2009 | Kenmore 60172 Electric Commercial Dryer
Sparks from starter switch wires
you may have lost one leg of power at the panel if fused or on 2 single pole breakers,or you could have burnt the neutral connection somewhere inside the unit
Jul 18, 2009 | Dryers
Calypso Senseon electric, No beeps, no lights, nothing,
Door switch
Thermal fuse
Wiring
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
May 20, 2009 | Whirlpool GEW9868K Electric Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
107 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Gordon Richard...
