Question about Dishwashers
Soap is left in dispenser, not enough water? dishes are still dirty
Soap is left in dispenser, not enough water? dishes are still dirty.
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
Www.dishwasherfilter.com has a product out that will solve this immediately. check it out.
Posted on Jul 26, 2009
  • 423 Answers
I bet if you go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) and use it in place of generic, ultra-cheap dishwasher powder, your problems will be solved almost immediately.
If you still have problems, please post back here. OK?
Posted on Apr 18, 2009
  • Jeff Meyer Apr 20, 2009
    Please report back with what solved your problem, OK?
    Not only did I suffer from the problem of generic dishwasher powder causing problems, I have found at least 8 other people here (as of April, 2009)who have found the very same problem. That is because the generics have added fillers that are mineral based that does not dissolve, does build up on the enclosure of the dishwasher and especially on the silverware - white "blotches" and very poor cleaning. Our problem's were solved by switching back to a brand name powder. This is not some sort of scam reply trying to get you to spend more money needlessly. (I am a big believer in buying store brand and generics for almost everything, but it has been proven that many generic dishwasher soap actually causes problem, so I don't buy the ultra-cheap. FYI: I have found that the Kirkland brand @ Costco to work as well as the two brand names I mentioned above.
    Please report back what you find fixes your problem. If, after testing the detergent theory, the problem continues, and if your problem includes a film on most glassware, then suspect that your heating element has failed. No heat _will_ cause dishwasher to not fully dissolve and not activate, but rather build up on the dishes.
    If the problem continues after confirming that the heating element is working during the wash cycle, then after confirming that the filter and wash arm is not seriously blocked, your main wash pump motor is almost certainly weakening to the point of failing soon.
    Again, my reply was not a scam to by a more expensive product. I seriously have found that ultra-cheap dishwasher powder does cause the exact symptoms you reported. PLEASE report bank what you find to be the cause and please post the manufacturer and model number of your dishwasher when you reply.
    Good Luck!
Soap gets clotted is soap dispenser. Dishes greasy and dirty after cycle.
Hi, the soap is clotting because there isn't enough water being sprayed around inside. The water spray washes the soap out of the dish, if all is working well. My machine had the same problem. I had sufficient water level, but the spray head wasn't spinning very well. I found the end-most hole in the spray bar to be plugged. It is the end hole that provides a jet that makes the head spin. I cleaned a bunch of debris out of the hole and the machine started working and cleaning like it was new.
Jun 26, 2011 | KitchenAid 24 in. KUDI01ILBS Stainless...
Soap dispenser not emptying during cycle. Dishes
Checkout this tip that I wrote about that problem...
Dishwasher Repair Problem Detergent Cup does not Open
http://www.fixya.com/support/r4225828-dishwasher_repair_problem_detergent_cup
Dishwasher Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Jul 18, 2010 | Maytag Dishwashers
Soap is not dissolving. Dirty dishes! Help!!
the dishes could be hot from the heater start the dw then open the door feel the water it should be hot if not prime the sink before starting the dw
May 31, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
Soap doesn't empty from dispenser
Assuming you are using the correct detergent powder, check if the dishes are remaining dirty.
The water from the impeller may not be rushing up enough due to blockage or limited movement of impeller arm. Follow the insructions to clean the impeller, filter etc or check base of drawer for obstructions to impeller arm.
Dec 04, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
LEFTOVERS ARE STILL BEING LEFT AFTER THE CYCLE IS DONE. I RINSE DISHES BEFORE HAND BUT THERE IS A BLACK DISCHARGE ON THE BOTTOM OF THE TUB, AND SOAP STILL LEFT IN DISPENSER.
clean detergent dispenser drain hose could be kinked,check pump it could be dirty,is the water hot enough and is the detergent new?to remove spray arm un screw spray tower also clean out spray arm there may be food particles in arm as well as tower,try this out try washing unit with out dishes sometime vinegar or c.l.r will take care of problem but let it soak and don't add detergent.thanks
Dec 01, 2009 | Kenmore 24 in. 16362 / 16364 / 16369...
Dirty dishes
plugged jets, possible
more likely it is leftover food reminance left in the pump area. and on certain dishwashers it could be a swollen check valve, not allowing the evacuation of the used dirty water.
does your soap dispenser open?
May 29, 2009 | Dishwashers
Soap still in dispenser and dishes dirty after dishwasher is ran
Your description sounds like the water pump is wearing out. Call the repairman.
Mar 26, 2009 | GE 24 in. Profile PDW7800 Built-in...
Our dish soap is not dispensing from the flip container.
sounds like you have a water circulaton issue, make sure your getting enough water in machine, and nothing is blocking the dispensor eform getting hit with the waster stream
Jan 11, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Kitchen aid NOT CLEANSING DISHES
It sounds like you are not getting enough water to make the dishwasher function effectively. Could be a bad valve could even be that the spray arms aren't letting through enough water.
Jan 01, 2009 | Dishwashers
Dishwasher not cleaning dishes. Casade cleaner not disolved.???
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwashers Logo
381 people viewed this question
Top Dishwashers Experts
