Question about Garden
I have already paid for the help. Send the solutions to my e-mail. 2bigal@comcast.net The problem is on an Echo Chain Saw. The chain keeps running when it is in idle mode. It even starts moving when I crank the saw to start it and the engine doesn't fire. The help I have gotten so far from your experts said to adjust the idle screw and check the dogs on the clutch to see if they are dirty or hanging up. Both of those things are fine. I keep getting e-mails from Fixya asking for more money for a higher level of expert help. Probable 5 or six of those messages in a week. How about sending me 5 or six solutions instead. My fingers are getting tired of typing in the make and model etc. but here it is again. Echo saw with a 14 inch chain. CS 3000 IE SN. 023613.
    Scholar:
  • 152 Answers
It sounds to me like maybe the springs in the clutch are bad or there is some debris in there. I would check that out. Remove the bar and chain. At that point the clutch will be exposed. The outer round surface should turn freely around on the inside part. If this is not the case replace the clutch.
Posted on Apr 15, 2009
Echo chain saw has no spark how to fix
Not being facetious here... change the spark plug as a first step. They require regular replacement. If that doesn't work, use a multimeter to check that the spark plug wire is actually releasing electrical pulses. If it isn't, you'll need to keep moving further up the line to the coil.
Sep 01, 2014 | Echo Chain Saw Service Repair Manual...
Lowering idle speed does not stop chain on ECHO SC chain saw?
I will need more information. Will the chain stop if touched to a log? Is it just creeping along compared to the speed of the motor or matching the speed of the motor? Has the saw been used enough to have saw dust build up inside the clutch and keep it engaged?
Nov 12, 2013 | Echo CS400 18" Chain Saw
Brand new Echo cs-400 chain saw: The chain spins fast on idle. Should'nt the chain be stationary on idle?
The manual is available here:
http://safemanuals.com/user-guide-instructions-owner-manual/ECHO/CS-400-_E
The idle speed of the negine may be too high.
Page 26 of the manual gives instructions for adjusting the speed with the "T" screw on the carburettor.
May 12, 2011 | Echo CS400 18" Chain Saw
Chain is not getting oil
Remove the bar and chain--clean the port area where the bar fits. Run the saw at speed for a few moments--it should ooze oil out of the port. If it doesn't, then you need to check the pump, lines, and tank for plugging or other problems. If the oil came out ok, then clean the bar drive-end small oil passages that run out to the chain groove on each side. Clean the entire chain groove as well. Reassemble the bar and chain (the teeth cut toward you on the lower run), and adjust the chain so that it just pulls up to the bar, but not so tight that you can't pull it by hand. Run the saw tip at speed near some cardboard--it should throw off a thin line of oil. Hope this helps!
Jul 09, 2010 | Echo CS400 18" Chain Saw
Chain brake jammed on Echo CS400 chainsaw
You will need to release the brake by applying a very heavy screwdriver to the + shaped part of the brake coupling. Check the action of the brake handle and duplicate it at the the +. Hope this helps!
Jun 25, 2010 | Echo CS400 18" Chain Saw
ECHO CS 3000 chainsaw-while idling, shuts off if held on an angle
The idle speed screw may be set too low--adjust so that the chain stops moving, but the engine keeps running. Drain the fuel tank and see if the filter falls to the lowest point of the tank whatever the position. If it doesn't, replace the fuel line hooked to the filter as it may have lost flexibility. Hope this helps!
Apr 11, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Chain brake not working needs adjistment
I found several outlets that said they sell Echo chain saw parts but none of them could come up with the ones I needed. It seems that ECHO doesn't want anyone repairing their equipment except their dealers who seem to easily get the parts.
I took the saw to a dealer an hour from here and he put a new clutch, drumb, bearing, and some other small parts in that clutch area. The saw runs fine now so I won't need farther help. Your solutions was correct but I just wasn't able to get the parts and do it myself. Thanks 2bigal
Apr 14, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Broken bolt that holds chain bar in place
As you know, your chain saw is obsolete, However, go to this website and they will have what you need:
http://www.cmsmallengines.net/echo-kioritz-c35.html
Good luck.
Jan 13, 2009 | NRS Oregon Bar And Chain Set For Echo...
I have an Echo CS-440 18" chain saw and the chain came off. Now that I have put it back on, it won't move either by hand or when the engine is running. Help
OK.  This is simple. Either the chain brake is engaged or the chain is too tight. Start by pulling back on the chain brake toward you.  There should be a "click" if the brake was released.  If the chain is still immovable, try resetting the chain tension. 1. remove the spark plug wire 2. loosen the two clutch cover nuts 3.hold the bar nose up and loosen the tension adjustment screw until the chain moves freely without becoming loose. 4. tighten both clutch cover nuts with the bar held up. 5. Pull the chain around the bar by hand.  Loosen the adjustment if you feel tight spots. 6. When the chain is properly tensioned,tighten clutch cover nuts securely.  Do not overtighten! 7.  Check chain brake operation and release. 8. Replace spark plug wire and operate  saw.
Hope this solution will Fixya.
Jan 10, 2009 | Husqvarna Chain Saw 20" Bar
Garden Logo
93 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
