Question about JVC XV-S500 DVD Player
Power Problems I'm having problems with my JVC XV-500. Right now when I power the unit up, it briefly displays "HELLO" then shuts off. Is there a factory reset for this model or is ther a solution to fixing it? I've taken it apart thinking that there was something jam the tray and inspected all cables. Please help..don't want to have to buy another DVD player Thanks Dion
  • t587l Nov 08, 2007
    When I press the power button the display briefly says "hello" and then shuts off. And repeat...
  • Anonymous Nov 09, 2007
    have the same problem power it up and it displays hello, if push open moves just a little then shuts down, willnot open or turn on
I have the same exact problem; what a piece of junk. I have only had it a short time.
Posted on Dec 29, 2007
    Problem Solver:
  • 13 Answers
It's DEAD!For good... Get a new one!
Posted on Sep 15, 2007
SOURCE:
Appears no power in unit. no lights or display. verified power into connector plugged onto primary board. xv-n212 jvc dvd acually loaded dvd disc then power ceased. again 120v onto primary board.
Sounds like faulty DC regulation in the power supply - due to numerous faulty electrolytic capacitors and/or IC regulators.
Check ALL the caps, and replace ALL of them as required. (You can easily do a visual inspection of the caps - some may have bulged, split their vents (in their tops) or leaked.) Electrolytics tend to have a short life, and, as these are inexpensive, you can adopt the blanket approach and replace all of them in the PSU circuit. They are available in every electronics shop - including Radio Shack. If this does NOT fix the 'dying power' issue, the unit may have to be submitted to a repair centre for a quote on further repair, and parts if necessary. At least with a quote you can make a decision afterwards as to whether it is worthwhile fixing or not. Up to you.
Mar 21, 2011 | JVC XV-N212S DVD Player
When I switch the power on the inverter, it squeals briefly and then shuts down.
Two possible problems; input voltage too low, or the output load too high. If input remains at 12v or higher and it shuts off with no load, then the inverter is bad.
Mar 19, 2010 | Vector 750-watt Power Inverter Power...
Want to play dvd's from any region. My JVC XV-S332SL/XV-S402SL DVD Player is restricted to Region 4
hi you can try this it been tested and will work if done correct we just tested this and had no problems unlocking this in the shop lol.
1. Power the player off.
2. Press and hold 'DVD Menu' and 'On Screen' on the player.
3. Power the player back on.
4. Release both buttons.
5. Press Standby. The display should now read either TEST 2, TEST 4, or TEST 6
depending on the machine's current region setting.
6. Press DVD Menu twice on the player.
7. When the display reads 000 5858 use the up and down buttons to change the
000 to 02E.
8. Using the Left and Right arrow buttons, change the last four digits until
they read 0000 for Region Free, 0001 for Region 1, 0002 for Region 2 or 0004 for
Region 4....
NB: DO NOT Use Region 20!!!
9. Press Enter on the player.
10. Press Standby.
11. Wait 5 Second.
12. Press Standby again.
Some titles may not play in region free setting. If this happens select the
needed region.
JVC XV-S332SL, , XV-S402SL,
riz.
Aug 17, 2008 | Televison & Video
Software problem with JVC XV N322
Reflash ur dvd player flash ic
Jul 21, 2008 | JVC XV-N320 DVD Player
Protection displayed and shuts off
The protect message indicates that the output amp section has a problem. Normally this requires the replacement of the output transistors or the output amp pac. Expect the repair cost to be about $20-$60 for parts plus the local labor rate.
Dan
Mar 22, 2008 | JVC HXC6 500-Watt Stereo System with 5-CD...
JVC XV-THA25
Fixed it by replacing a burned resistor.
100ohm 1 wat designation PR010 on the main pcb.
Feb 09, 2008 | JVC TH-A25 System
HELLO
i had the exact same problem yesterday (4/8) and just playing with the open/close button several times the drawer finally opened completely and closed like it should. i then did the reset sequence and all is back to normal
Apr 03, 2007 | JVC XV-S500 DVD Player
Power Light shuts off
That is a fault in the power supply My friend Wish i could be more help
Dec 12, 2005 | JVC XV-S200 DVD Player
JVC XV-S500 DVD Player Logo
188 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
