Ive lost my set up manual
I need the manual to set the vcr up to my tv
  • 43 Answers
Hey,
If you are looking for the manual, you can find an online manual for a lot of brands in the following link.
http://www.retrevo.com/samples/Projection-TV-manuals.html
Hope this helps
Thanks
Posted on Apr 15, 2009
I need a user manual for my sanyo HV-DX3E dvd/vcr combo player
there are only a couple ways you can hook it up and if you took the old tv off then you should have the cables you need
Feb 03, 2015 | Sanyo Televison & Video
I have lost the manual and would like to hook up the VCR to my TV in order to record programs. Can you help? JVC Video Cassette Recorder HR-D18OU Thank you.
Is the incoming signal OTA or cable? (If cable, is it analog (CATV) or digital (QAM)?)
Most TV's do not have a video out but you should check your TV. Assuming the usual TV with no video out, then you will need a set top box to record any program other than analog signals (CATV or a low power OTA option). The VCR only has an NTSC (analog) tuner.
For an OTA signal, take the coax from the antenna to a digital-to-analog converter coax in, then coax out of the converter to the coax in (tuner) of the VCR. Then set the VCR to channel 3 or 4. Set the switch on the converter. (Some VCRs will record Line In or Input, so you could use the composite out of the converter to the VCR.) Then coax out from the VCR to the coax in on the TV and set the TV to Channel 3 or 4 as well. Set the switch on the VCR. (Alternatively use the composite (A/V) out on the VCR to the composite In on the TV and set the input to AV1 (or whatever the TV calls the input). Digital cable will be set up like the OTA, except for using a cable set top box instead. You may want a splitter to allow for watching one program while recording another. In that case, put the splitter before the set top box if the TV has the digital tuner. Otherwise put it after the set top box. In both cases, you will need to use the AV (composite out) on the VCR to the TV.
For analog cable, take the coax cable and connect it to the VCR's coax in. Then connect the coax out or AV out to TV.
Set the VCR to the desired station and press REC. For timed record, enter the menu and set the time to start and end the recording as well as the channel. If you are using a set top box, set that to the desired station and then press record. (Leave the VCR set to Line in or channel 3 (4) as needed.)
Manuals for some JVC vcrs are here: http://support.jvc.com/consumer/product.jsp?categoryId=CATG0002&productId=PRD4600001&archive=true . A manual for a similar model will help since they all connect the same way. However the HR-D18OU is not in the list.
I hope this helps.
Feb 10, 2011 | Computers & Internet
I lost the manual to the magnavox dvd/vcr dual player so i dont know how to set it up. so i can watch dvds and vcr tapes.
The easiest way to hook up the combo is to use the cable in and out to tv connectors located in the rear. for this connection you will hgave to set the TV to Channel 3 or 4. You can usually download an owners manual from magnavox.com, you will need a model number.
Mar 19, 2010 | Philips Magnavox DVD/VCR Dual Player
I NEED TO KNOW HOW TO HOOK THE VCR UP TO THE TV SET. i LOST MY MANUAL I have PV-V4521
If you are using an antenna put your antenna connector into the rear of the VCR & then using a connecting cable (RF flylead), take this fron the other socket at the rear of the VCR & connect this to the antenna connector on the TV, you will then have to tune the TV to the VCR. Select channel zero for example on the TV, insert & play a tape, & then tune the TV in until it picks up the video playback picture then store this channel on the TV settings. Alternatly, do as above only use a Scart cable & connect this from the rear of the VCR to the AV connection on the rear of the TV, then when you wish to use the VCR channel, select the AV option on the TV.
Jul 11, 2009 | Panasonic Televison & Video
When i plug in my wii the color is like black and white pretty much, ive tried plugging in the cords every way but it doesnt work..the tv color works just fine and the other game consoles ive plugged in...
  • Is this your first time hooking up the Wii console or have you moved it to another TV or VCR? If so, please refer to your manual to review the step-by-step connection guide. Our experience shows that the majority of these issues can be solved by double-checking your connection and finding the correct Input Select for your TV or VCR.
  • If you have verified the connection is correct, and are still receiving a blank white or blank dark screen when powering on your Wii console, then the problem is likely with the system and it will need to be repaired. Please call Nintendo Support for repair options. 1-800-895-1672
    If you do not have a manual for reference, here is the set up info online: http://www.nintendo.com/consumer/systems/wii/en_na/setupAV.jsp
    Good luck! Hope this helps! :)
  • Sep 13, 2008 | Video Game Consoles & Games
    Lost remote for akai tv/vcr/dvd set
    I think you should look over the Internet to buy one from places like Ebay for your brand of TV.
    Apr 07, 2008 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
    Orion vcr model vr313
    You need not set your VCR to either CHs 3 or 4.  You simply have to set it to the channel that you would want to record. Further, the coax either from your cable or aerial should go straight to the VCR for it to receive any of the channels. The VCR then maybe hooked up to your TV either buy a shorter cable and this is when you set the TV to either 3 or 4. Alternately, you can use the RCA connector from your VCR to your TV.
    This is a generic/compressed solution. Pls post back should you want additional information.
    Good luck and kind regards.
    Oct 23, 2007 | Televison & Video
    Missing manual for - sharp VC-A560 VHS
    I lost my manual and the biggest issue of getting this set up is getting the vcr to the channel you need for play back either channel 3 or channel 4. To change the channel you hold the power button and the tv/vrc button at the same time till you get the channel you want. Three flashing lights is channel three, four flashing lights is channel 4. every time the power goes out mine resets to channel 3 and will not play videos until I reset to channel 4. Hope that helps.
    May 24, 2007 | Sharp VC-A560U VHS VCR
    How do you connect the VCR Mitsubishi HS-U446 to record a TV show?
    Usually the standard color coding for those connections are yellow, red and white. Yellow for video, red and white for audio left and right if it is stereo. Also pay attention on the the label of your vcr if it is input or output. You need need to connect it from output of your vcr to the input of your tv set. TV have also the same color coding. By the way the cable you use for this purpose is what we called RCA, which is also color coded. good luck!
    Feb 26, 2007 | Mitsubishi HS-U446 VCR
    Televison & Video Logo
    Top Televison & Video Experts
