I cannot find my manual
SOURCE: MICROWAVE TURNS ON WHEN DOOR IS OPENED.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switches are most often damaged by opening the door while it's cooking (instead of pressing Stop / Clear first) or food
/ grease debris in the switch.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
SOURCE: panasonic microwave oven model nn-p994sf
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Lost manual for Panasonic microwave
CLICK HERE for your manual in PDF format. The link is partway down the page.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
SOURCE: i have a microwave oven i purchased
Remove the glass turntable, then the roller ring. Then seta glas of water in the unit and turn it on for 5 to 10 seconds. Look through the door window and see if the drive hub is rotating. If it is, then check the underside of the glass table to match up the drive hub. If it isn't turming, the drive, then it is internal and should have a 1 yr warrantee minimum. Remember, the, the turntable and drive must engage each other and the roller ring in place. Good Luck, and let me know please. One more thing, make sure there isn't a Turntable on/off swirch set in the off position. Good Luck, Ne
