Question about Apple iPod shuffle MP3 Player
Can't sync Ipod shuffle 2nd gen after my computer crashed
I had to reinstalled my window files after my computer crashed. My ipod is seen by the pc but it tells me that the ipod is sync with another computer. How can I re-sync it with out erasing all of the songs on it?
    Problem Solver:
  • 21 Answers
If you did not safely remove hardware or eject from itunes..theis will happen...try to do either or open my computer and make sure it is not showing up where you see the c/drives and stuff. if it does, remove it there
Posted on Aug 07, 2009
PyroMan6x9x9
  • 150 Answers
SOURCE: Sync problem
Try resetting the ipod, this usually works. As follows: How to reset iPod To reset an iPod with a Click Wheel, including: iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation) iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button. When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. Good luck, and I hope this helps.
Posted on Sep 20, 2007
SOURCE: 2nd Generation iPod Shuffle Wont Turn on and 3 orange lights sync
ALLOW IPOD TO RUN DOWN..BY LEAVING ON.THEN FULLY CHARGE.TURN ON AND IT SHOULD RESET ITSELF IF NOT LET ME KNOW.I WILL ADVISE FURTHER.RICHARDM69
Posted on Dec 04, 2008
  • 13 Answers
SOURCE: ipod shuffle 2nd gen. shuts down my pc when plugged in via usb
rokk, read all of this before trying it. If you are using WinXP or Vista they have a built in system protection that if something comes in and is recognized as a physical threat to the system it will shut it down. Check your settings. You may have picked up a corrupt file. Watch out for .P1 and files that don't remove from the player. They will lock the player and your PC.
Not a full solution but I hope it sends you in the right direction. If you are running Norton shut it down then <with care turn off> firewall, etc, one at a time. If its a bug once you restart Norton it should grab it. If in doubt, don't.
Posted on Mar 20, 2009
mneilsen2084
  • 342 Answers
SOURCE: My ipod touch 32GB 2nd gen crashes frequently?
The only viable trouble shooting option I have available on this current issue is to restore the ipod touch using itunes. Just in case you are unsure of how to do a restore, I have included step by step instructions below.
Posted on Apr 24, 2009
dvdcdlaser
  • 1285 Answers
SOURCE: Ipod shuffle (2nd gen) completely dead
you are still under warranty...take it to the sony apple store...they will fix it /replace it or tell you there is cost if it not the battery (note do not tell them you charged overnight, and for the future do chage any gadgets more than 3-4 hrs) when you do charge over night you are actually shorten the battery life span or overcharge....so as soon as you come home from school,work,whatever cell/ipod or any other device needs to be charge...charge it now and unplug before you go to bed....
Posted on Jul 05, 2009
Green/Red Flashing - iPod shuffle 2nd Gen. & Orange Flashing
Aug 07, 2009 - OK, I found the answer...there was a problem with the updated Windows service pack. I had to uninstall all applications(even in recycle bin) of all previous service packs including the new service pack 3. Then, went to Windows update and reinstalled the service pack 3 only and after installation, my ipod came to life! It was beautiful....Must be a compliant problem with the packs...I don't know!
See less
Aug 05, 2009 | MarWare Docking Station for iPod shuffle...
I can not play the music i copied onto my ipod shuffle 2nd generation any to help me.i want to know if itunes is the only way to sync files to the ipod
You need to download songs in mp3 format as any music you take from a cd will have copyright in the tracks and will not play on your ipod.
Jul 13, 2009 | Apple iPod shuffle Second Gen. Silver (1...
IPOd Shuffle 2nd Generation incompatibilities with iTunes
click on your ipod icon and that should be songs on your shuffle, play to see if they really are on there. sometimes it tricks you...
Jun 08, 2009 | Apple iPod shuffle Second Gen. Silver (1...
Ipod shuffle 2nd gen problem
Remember these five basic suggestions if you have a problem with iPod shuffle. Try
these steps one at a time until the problem is resolved. If one of the following doesn’t
help, read on for solutions to specific problems.
Reset iPod shuffle by turning it off, waiting five seconds, and then turning it back on
again.
Retry with a different USB port if you cannot see iPod shuffle in iTunes.
Restart your computer, and make sure you have the latest software updates
installed.
 Reinstall iTunes software from the latest version on the web.
 If the status light blinks orange when you press a button, the iPod shuffle buttons are
disabled. Press and hold Play/Pause (’) for about three seconds, until the status light
blinks green.
 Connect iPod shuffle to a high-power USB port on your computer. Your iPod shuffle
battery may need to be recharged.
Turn iPod shuffle off, wait five seconds, and then turn it on again.
You may need to restore iPod shuffle software
May 31, 2009 | Apple iPod shuffle Second Gen. Silver (1...
Ipod no longer syncs
It happened to me once.One problem is that you iPod's version is higher than your PC version(Or vis-versa).So just try updating you iPod and PC.
Apr 09, 2009 | Apple iPod shuffle Second Gen. Silver (1...
ITunes+used 2nd gen ipod shuffle not working.
Ok, try completely uninsalling itunes, then reinstalling it. then importing the songs via add to library.
Jan 05, 2009 | Apple iPod shuffle Second Gen. Silver (1...
Ipod shuffle
FULLY CHARGE THE UNIT.DOWNLOAD ITUNES.PLUG PLAYER TO COMPUTER AND SYNC WITH ITUNES ITNES WILL GIVE YOU THE FILES..CONFUSED REFER TO ITUNES HELP.RICHARDM69
Nov 26, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Ipod 2nd generation shuffle
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod.five_rs/
Have you tryed that?
Well if you go and try it on a friends pc does the same thing happen? Let me know.
Mar 25, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Apple iPod shuffle MP3 Player Logo
193 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
