Question about Dell 828FI 15" CRT Monitor
Monitor dead Hai My monitor is dead. this problem are facing to 3months and above. My monitor problem is LOT is not working. LOT NO: sony 8-598-803-00 serial. thanking you srinivasreddy A
0 characters
1 Points
The monitor turn on but when I connect with the pc I don't see any immagine
1: power light on?
2: OSD work with called up, (menu) hit all montor buttons.?
3: yes, to above.? then, boot windoz in to safe mode? F8 key
still dead and all cables good.?
then RIP , Mr. monitor.
Sep 25, 2013 | Samsung Computer Monitors
I have a Sony 1410 LCD monitor, when it is powered up the screen displays vertical coloured lines on the left hand side for about 60 ml wide and the remainder of the the screen displays grey and black...
In most cases, this could be due to two factors. One - Your video card is losing life. Two - Your Sony monitor is almost dead. Simple way to trace the root cause is - borrow a monitor from your friend or someone and check. If the borrowed monitor works fine - it is the video card, that should be changed. Else, go for a new monitor.
Lastly, often people forget to check the cables. Sometimes broken pins or bent pin at the connectors could cause the problem too.
Mar 04, 2011 | Sony LMD-1410 14" LCD Monitor
No power at all to monitor after 1yr and 3months of use.
It should be still under warranty, please verify that first, if you open it up, it will void the warranty, it can have serious problem in the power supply or backlight inverter circuits.
Aug 23, 2010 | Samsung 2333SW 23" Widescreen DVI LCD...
Sanghatmak sarkar se kya tatpriya hai.iski mukhya visheshtaya kya hai. sanghatmak sarkar ekatmak sarkar se kaise bhinn hai. sanghatmak sarkar bade desho me hi kyun safal hai?
Would you please give information as regards the problem posted in English? Giving me this information in English will guide me to suggest a solution to the problem.
Take care.
Jul 11, 2010 | Samsung Computer Monitors
No display but on karne per 1 second vertical line dikhti hai
Horizontal IC kharap hai apko moniter repair karna hoga..
Feb 09, 2010 | IBM E54 15" CRT Monitor
Blank screen - appears to be dead
If the screen is completely black, your screen may indeed be dead. There are a few solutions you can try before throwing in the towel though.
1) Test the monitor on another PC if you can.
2) Make sure the contrast, and brightness aren't turned all the way down.
3) Make sure the graphics card in your PC is functional. You can easily test this by connecting a known working monitor to your computer.
If these steps do not resolve the issue, and your graphics card is in good working order, you indeed have a dead monitor on your hands. It may be cheaper to buy a new monitor, than to have that one serviced.
May 30, 2009 | Sony GDM F520 21" CRT Monitor
Loss of color/Discoloration
do you have a speaker or any thing to do with a magnet? if so thats what it is. if not try to get a new cable for it. that could be it too..
Aug 11, 2008 | E-Machines eMachines Monitor E15T4
Monitor black screen
Try asking from your nearest service centre .
Mar 27, 2008 | Sony SDM-HS73P 17" LCD Monitor
Dead set lg studio works v452 monitor
lg g505 this moniter 5 or 10 mnt woking then hot transister is damaged why this problem ?
Jan 26, 2008 | LG Studioworks 45 14" CRT Monitor
I had the same problem for about a week and solved it yesterday by downloading the latest driver by NVDIA who makes my video card (NVDIA GeForce 6200).
I had previously updated the latest Sony driver for the monitor. It did not solve the problem but could be part of the solution in conjunction with the new video card driver.
Oct 31, 2007 | Sony SDM-HS75P/S 17" LCD Monitor
Dell 828FI 15" CRT Monitor Logo
Top Dell Computer Monitors Experts
Brian Sullivan
Brian Sullivan
William Miller
William Miller
Are you a Dell Computer Monitor Expert? Answer questions, earn points and help others
