Question about Black & Decker Saws
I am looking for a replacement copy of the
I am looking for a replacement copy of the written materials that come with my B&D m-47 jug saw. Thank you
  • 2,176 Answers
I went to Dewalt's website and they do not offer that manual online. You are going to have to call them to get a copy, wish I had better news.
Posted on May 21, 2009
How do I change disks in my Makita PA - GF 30? Thank you
https://www.matbase.com/material-categories/composites/polymer-matrix-composites-pmc/reinforced-polymers/material-properties-of-polamide-6-30-percent-glass-fiber-reinforced-pa-6-gf30.html
PA GF30 is the base material of the housing set of the machine not the model number made a google search for " makita saw " on pictures the chance is that you find your model .
Feb 05, 2017 | Makita Saws
Paper size is undetected
The material to be copied may have been placed in the wrong position on the glass.
Aug 11, 2016 | Office Equipment & Supplies
Gold powder or particles on base
It's probably brass, run it a few time and clean it, if it continue, their a good chance that your bearing is dying (grinding it self),check if you can replace that section.
Jan 06, 2014 | Breville Blenders
Need a piston& ring set from canada? Or close to B.C.
CHECK EBAY, IT'S CALLED A JUG KIT .COMES WITH PISTON, RINGS, WRIST PIN AND THE CYLINDER (JUG). THERE THE BEST WAY TO SPARK A SAW BACK TO LIFE. I WOULD LOOK FOR THE CRANK SHAFT SEALS ALSO, ESPECIALLY THE BLADE SIDE ! .. IT HAS A HARD LIFE, AND IS COMMON TO LEAK, MAKING YOUR SAW HARD TO START.AND RUN POORLY. JAY THE POOL PUMP REPAIR GUY IN LONGWOOD FLORIDA .. IF I WAS OF HELP CLICK ON THE YES .. THNKS JAY
Jun 20, 2011 | Garden
Hi, I'm looking for a part from my Prima TV, it's a very little rectangular piece where it is written STR G9656 and 47 06 with like 4 metal legs. Does anybody know where I can find that? Thank you
This is a regulator IC and can be purchased from B&D Enterprises. See the link below. Enter the part number and you can order directly. They are in stock.
Dan
Link: www.bdent.com
Apr 20, 2011 | Prima CV2011 TV
Start up good and run good , or later on it start stumble and die out
1. your vent for the fuel tank may be clogged
2. your ignition coil, when the saw warms up, the blades inside the coil heat up and separate causing loss of ignition
3. fuel delivery may be an issue, your fuel filter or carburetor need to be cleaned
4. possible air leak
5. your saw could have possible slight scoring and when the saw heats up and the jug/cylander swells you could lose compression
There are many other possibilities, depending on where you are located, we would be more than happy to take a look at your saw to diagnose the problem. if you are outside of CT we can have it shipped. Please call 860.233.5439 x222 Butler Power Equipment.
Thank you!
Sep 06, 2010 | Husqvarna Chain Saw 20" Bar
Hi there; my stihl ts 420 does not start easily
replace the decompression valve. also check for carbon buildup on top of piston. usually when a saw stops on its own after 5 min or so.... the piston and jug are scored and need to be replaced.
Jun 16, 2010 | Stihl Ts 410 420 Cut Off Saw...
1992 saab clarion radio code
The code is not on the radio
To get code go to intstant radio code uk
Apr 27, 2010 | 1992 Saab 9000
Has an electronics smell
Looks like one or more of the Jugs or (CRT's) has leaked coolant and has traveled down the wiring and shorting out the Main board and or the Power Supply board/s. ALL three CRT's will need to be replaced as well as the shorted Main bd and or the Power Supply boards the a Full Convergence Alignment must be done. Not Cheap.
Apr 06, 2010 | Samsung HC-P4741W 47" Rear Projection...
Cleaning SCUBA tanks
Jul 29, 2009 | Aeris Atmos Lx BC
Saws Logo
60 people viewed this question
Top Black & Decker Saws Experts
Jason
Mike Carew
Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
