Question about Garden
Gas leak murray lawn mower when i'm done with cutting grass and wait about 30 min. before putting in gargae about 2hrs later wil smell gass fumes gas leaking to places on mower
  • 218 Answers
Hi..my name is Keith..and this is a common problem..i would overhaul the carb..but my neighbor, his Murray done the same thing..but he is a tightwad..he just put a shut-off valve in the fuel line..i hope this has helped
Posted on Jun 30, 2009
Transmission went out was wondering how long does it take to take the old one out and put a new one in
for me 30 min. for you could be hours. depends on how many you've done. I've done plenty
May 31, 2015 | Toro 36" Cut Wide Area Walk Behind Lawn...
I have a murray riding mower, 10hp, 30'' I filled my gas tank and 2 days later the gas was gone. but I did not see a leak. in the tank
check to see if gas running out of carberator also check your oil make sure gas is not in there if it is or fuel running out of carb replace needle and seat in carb check for cracked seam on gas tank also make sure fuel line not leaking
Sep 15, 2014 | Garden
Have a cub cadet 50 inch cut zero turn, after cutting grass for 30 min or so it acts like wants to die but if I shut the PTO off it catches up but will start to die if I reengage the blades. starts a
When it starts cutting out and you turn off the PTO, how long do you have to wait until it can be turned on again? It sounds as if your PTO is overheating and loading down the engine. Run the mower for about 10 minutes, shut it off, and carefully feel the PTO housing. Resume cutting and repeat after it starts cutting out.
Replacing it is not as simple as changing the spark plug, but does not require an advanced degree.
Jun 24, 2014 | Cub Cadet Street Sign- tractor lawn riding...
I just bought a 775ex walk behind that was repaired. I filled it with gas and ran it for a few mins. to try it out and it ran fine. A few hours later I smelled gas in my garage and found the mower's tank...
There could be a couple problems. 1 the fuel tank may have a leak.
2. The connection(usually a hose) between the fuel tank and the carburetor could be cracked or faulty
3. There could also be a bad seal in the carburetor that is letting the gas leak out.
check those out first. I would put some gas in it and then see where it comes from.
Aug 18, 2013 | Husqvarna Garden
Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut hydrostatic transmission slipping
first i would check the belt tension also check the belt for oil is so look for the cause of the leak the repair the leak and replace the belt
Jul 30, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Lawn mower leaking gas fumes
If its just fumes and you r not losing any gas then u don't have any problems. No need to worry.
Apr 09, 2012 | Garden
I have a self propelled Toro walk behind that does not have a throttle control. Stalls out if grass is just a bit high. How/ where do I adjust throttle
Most new mowers do not have a throttle adjustment, the motor has a govnor that helps the motor speed up when the load requires it. The first thing you should check is that the blade is sharp which makes it easier to cut the grass. If the grass is still too high for the motor to keep up, it's usually easier to raise the deck (lower the wheels) so you are not cutting as much grass on each pass. Then lower the deck to where you want the grass height to be and make a second pass.
Jun 06, 2011 | Toro Power Lawn Mower
Quit running while cutting the grass. Notice gas coming out of the exhaust when trying to crank
Just as Alaska bratt says check your carb. I had gas leaking into the oil and the entire engine was destroyed. Gas dilutes the oil and then there is no lubrication. FYI don't be worried about gas/fire as the gas is also diluted and is not very flammable, with gas it is the fumes that are highly flammable. I recommend rebuilding the carb draining the engine oil and keep your fingers crossed that you didn't damage the piston/sleeve/cylinder.
Jul 07, 2010 | Parks Optical 13.5hp Briggs And Stratton...
Husqvarna YTH20K46
Is this the first time cutting grass with a lawn tractor?
How tall of grass?
Use the grass cutting heigth adjustments on the tractor to a higher setting when cutting tall grass. Cut again to a lower height setting on the second pass. Grass higher than your tractor is not good for your tractor. Follow the manual instructions for best results.
Jun 27, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Garden Logo
166 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
