SC350-01 error code
I have a sc350 on a ricoh aficio 350
  • chicagojoeco Apr 28, 2009
    thank you for your help
Probably just a dirty "ID sensor". If you remove the drum (carefully) and set aside. Open the right cover, and towards the back of the machine above where the drum sits there is a small LED sensor mounted pointing down toward where the drum sits. Clean this with a tissue, put back drum and try.
If this fails, then the sensor is bad (or broken wire), or there is a circuit board problem (serious). Either IOB board or High voltage board.
Hope this helps.
Please rate solution
Posted on Apr 23, 2009
Ricoh aficio MP2000 ERROR code SC302.
https://printcopy.info/?l=en&mod=erc&brand=Ricoh&model=Aficio%20200&code=SC302
Ricoh Aficio 200 Error Codes
Ricoh Aficio 200 Error Codes Code:
Code
SC302
Description
Charge roller current leak
A charge roller current leak signal is detected.
Causes
• Charge roller damaged • Charge high voltage supply board defective • Poor connection of the PCU
Apr 18, 2018 | Ricoh Computers & Internet
How to solve this problem sc 302
Hi
I managed to find a list of Ricoh error codes with brief explanations of their causes here:
Ricoh copiers error code messages
This clearly identifies the problem as a laser motor problem - OR
Charge roller, HVT, or fuse FU5 (AFICIO 340, 350 series, 355, 450 series, and 455) - OR
SC-302-01, 02, 03, 04 Charge corona assembly Aficio 550/650
SC-303 Charge corona wire cleaner, disconnected or time out for printer.
All of these sound rather like an engineer requirement but you may be able to something with appropriate spares
Sep 25, 2014 | Ricoh Office Equipment & Supplies
Poslem poveke stranici kopiranje se pojavuva kljuch so functional problems SC350-01.Aparat Ricoh 450.
sc 350 is the ID sensor error. clean the ID sensor and it should be fine. the ID sensor is located above the drum unit.
Oct 27, 2010 | Ricoh Aficio 450 Copier
Error sc 350-1
ID sensor error
dirty id sensor-- pull out the drum unit and from the right door clean the id sensor (above the drum)with a dry cloth
Jan 07, 2010 | Ricoh Aficio 450 Copier
Solve Your ''aficio 350 functional problems sc350 03'' Problem Now!
sc 350 is toner density problem. many things cause this. bad developer, drum, id sensor, charge roller, blank lamps. you need a tech to look at it.
Dec 31, 2009 | Ricoh Office Equipment & Supplies
Error code 350 error code 990 error code 540
Error code 990 indicates software problems yuo can check in SP7-403 for information.
Error code 540 will proberly indicate some heating trouble in the fix, you have to reset the machine with service code SP5-810.
Code 350 will disappear if you restart the copier.
Oct 09, 2009 | Ricoh Aficio 1035 Copier
Functional Problems SC350 - 01 Turn On/Off Switch off the On If the error appears agian Call: Service; 00 - 0000 - 0000
I have recently provided a post to the same problem. Please note that the Power must be turned off with the "main power" (red button) to reset.
The link is here:
http://www.fixya.com/support/t1999925-sc350_01_error_code
Please let me know if this helps, and rate my solution :)
Apr 23, 2009 | Ricoh Aficio 450 Copier
Error code sc 101.... sc 350
SC101 Scan Lamp Error
SC350 ID sensor pattern test error
Your scanner should be checked by a technician to determine what is causing the error. There isn't any calibration or troubleshooting that can be done unless you have scanner parts.
Aug 21, 2008 | Office Equipment & Supplies
Sc350
Image density sensor is dirty. Usually caused by toner being dumped on it.
You will have to call a tech to see if the sensor is broken, dirty. It requires removal of the drum and inspection of the sensor.
Jun 13, 2008 | Ricoh Aficio 450 Copier
742 people viewed this question
k24674
jasbo
jasbo
