Question about Nintendo Wii Console
My wii remot can turn on and i can push a and b but the wii remote wont work when i play baceball or boling. for exampol my avatar wont swing the bat when i play baceball.
Make sure the batteries are not worn down. If the sensor bar is in really bright light it will not work. Close the curtains so there is not lots of sunlight. Unplug the sensor bar and plug it back in again. You could try to re synch the remote, open up the wii remote battery pack and press the red button at the top once. Then quickly press the red button on the inside of the SD Card flap on the wii. If this problem persists try to get a new remote, or better contact customer services if these solutions don't work. Info is in the Wii manual.
Posted on Apr 16, 2009
Wii remote works but not for wii sports
If you're wii remote works as a pointer but not when swinging it then it is a problem with the accelerometer inside the wii remote and not the infra red bit on the end. Good news is its usually just stuck as mine was. Nintendo recommend turning the remote upside down and giving it a few taps on the palm of your hand. Worked on mine and saved me £30 as i was about to buy a new one.
Aug 04, 2009 | Nintendo Wii Remote Controller
Wii remotes wont hook up
did you try syncing them up by pushing the red button on the wii and the remote
Jan 03, 2009 | Nintendo Wii Console
Nintendo wii problems
Hold the Wii Remote with the button side down. Without using much force, firmly tap the button side of the remote against the palm of your other hand a few times. Doing this does not take a lot of force, so be sure not to tap the Wii Remote very hard. Check for proper response.
  • Check to make sure the Sensor Bar cord is inserted into the back of the Wii console and the Sensor Bar is centered above or below your TV screen.
  • Make sure you are using fresh batteries in the Wii Remote.
  • The Wii Remote Controller should be used between 3 to 10 feet from the TV.
  • Make sure no objects are blocking the signals between the Sensor Bar, the Wii console, and the Wii Remote.
  • Check for interference from infra-red light sources, such as candles, sunlight, fireplaces, and stoves.
  • Radio frequency interference may cause the Wii Remote to work erratically. Check for wireless devices such as cordless phones, wireless computer keyboards or mice, or other similar devices, and move or turn them off.
I hope this fixes it for you!
Jul 08, 2008 | Nintendo Wii Console
My wii remote
@ Slivic22
Some games does not use Sensor Bar pointing because they play with motion/accelerometer only. After you select the number of sets on Wii Sports Tennis, there is no Sensor Bar pointing except for Pause menu. That's because you Swing the remote like a racket.
May 24, 2008 | Nintendo Wii Console
Remote "action" doesn't work
maybe the sensor on the top of your screen is messed up that happens to me some times too. Just move it up little bit
Apr 27, 2008 | Nintendo Wii Console
Wii freezing up
Hi Ashley,
It sounds like the accelerometer in your Wii Remote is not working properly.
The "point-and-click" stuff like the Wii Menu use the WIi Remote's camera (which is behind the dark part on the front of the Wii Remote). The motion-sensing for swinging, tilting and other motion uses the accelerometer in the Wii Remote.
Wrap your Wii Remote in a towel and give it a whack against your knee (not so hard as to injure your knee) - sometimes the accelerometer part gets "stuck" and needs to be jarred out of position.
If that still doesn't work, then go to Nintendo.com, click Support, and go to the Wii Troubleshooting section for more options.
http://www.nintendo.com/consumer/systems/wii/en_na/ts/wiiremote.jsp
Also, you don't have to use the same remote as #1. The first remote that is activated will become #1.
You can also push the Home button on the Wii Remote, then point to the bottom (where the battery levels are shown), press A, then click on Reconnect. It will tell you to press the 1 and 2 buttons on each remote in the order you want them to appear. Press the 1 and 2 buttons on the remote you want to be #1, wait for the remote to sync (the Wii will make a happy nosie), then do the same for the remote you want to be #2, etc.
Apr 01, 2008 | Nintendo Wii Console
Wii remote
Hi There, this is quoted from
http://blog.wired.com/geekdad/2007/12/crazy-wii-remot.html
The GeekMom and I got the kids a Wii for Christmas. Last night, one of the remotes went funky - you could press the buttons and select options on the screen, but when you went to swing a golf-club, bowl, pitch a baseball or swing a baseball bat, the Wii remote acted like it wasn't there. I'm a GeekDad - I can fix this...I know I can...
  • Fresh batteries - nope.
  • Re-sync the remote - nope.
  • Re-sync all the remotes - nope.
  • Reset the remote - still nope.
So, I exhausted all the options for getting a remote to work given on the Nintendo support site and called (with gritted teeth) the customer service line...two days after Christmas. I expected the worst.
I was surprised. A very pleasant lady took my call within one minute of getting through the push-button maze to get to Wii Remote troubleshooting.
I explained what the problem was and what I had tried. She then asked me to check one more thing - the Wii Sensor - which checked out. Then the conversation went something like this:
Friendly Nintendo Help Desk Lady: "Okay - I want you to take the remote, button side down and smack it into the palm of your hand two or three times."
Russ: "You've got to be kidding"
Friendly Nintendo Help Desk Lady: "No sir, do it hard enough that I can hear it across the phone line but not hard enough to damage the remote"
Russ: "You're sure?"
Friendly Nintendo Help Desk Lady: "Yes, sir."
So, button-side down, the funky Wii remote got smacked in the palm of my hand three times....
...and the thing worked!
End Quote
Hope this helps
Maxicube.
Feb 09, 2008 | Nintendo Wii Console
Wii remote controller not fully funtional
in baseball you have to hold it beside your head and in bowling you have to raise your WII control up and realese th B button(hold B button than do instruction)(not for the Baseball game)
Jan 02, 2008 | Nintendo Wii Console
Wii remote error
The accelerometers are stuck. Hold the controller so you can smack it on the palm of your free hand. Smack on the palm of your hand with the same force and quickness as you would a fly swatter. This will free the accelorometer. The accelorometer gets locked up when you swing to hard. Also try changing your batteries.
Sep 06, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
109 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
