Hibernates by itself!
I have a Dell workstation which is hibernating by itself! This happens when there is no activity for 10 minutes or so. I have checked the basics like power settings (never) & screen saver options (180 minutes). Any help would be much appreciated. J.B.
  • maintenan547 Apr 15, 2009
    We are running XP - Thanks
  • Jerry Purvis May 11, 2010
    Are you running Vista or XP?
  • 64 Answers
Go to control panel, then click on "Power Options" You should see a tab that says "hibernate" click on that, then make sure the box labeled "enable hibernate" is unchecked. Click Apply, then click OK. That should take care of it for you.
Posted on Apr 15, 2009
My dell inspiron n5050 automatically hibernates after booting
on start up togglr F8 key when screen comes up choose start in safe mode once it gets to main screen right mouse click in center of scren pick personalize click on screen saver and go to change power settings and see what hibernation is set on and set it higher restart and see if problem is solved
Jan 19, 2013 | Dell Inspiron Computers & Internet
When i hibernate, my computer turns back on in 30 seconds/
check that it is not set to 'wake on wifi', if so, turn this setting off
Oct 19, 2012 | Dell Inspiron 1200 Notebook
Dell inspirion hibernates when plugged in during use
check your power settings in the control panel
Jul 25, 2012 | Computers & Internet
Dell d520 hibernates, won't wake up
When you get access, go into power options, select hibernate top right, and uncheck the box to the left to disable it, this will free up more disc space and get rid of microsoft worst idea.
Jul 20, 2012 | Dell Latitude D520 Notebook
Laptop hibernates automaticaly
hello,
check the settings for hibernation,i think its programed to hibernate becuase of a setting check this link http://www.dummies.com/how-to/content/how-to-program-your-pc-to-hibernate.html
Jun 12, 2012 | HEWLETT-PACKARD Hewlett Packard HP...
My dell Studio laptop takes too long to wake from sleep mode and the monitor just flickers when i try to switch on
If you use Windows 7, u might have hybrid sleep activated. This is similar to hibernate. When u choose SLEEP, your computer goes to hibernate. Sometimes this hibernate just hangs. You have to reboot computer.
Try pressing the power button for several seconds (10-15). It should power off the laptop.
If not, unplug the charger and remove the battery for a few minutes. Then try to start it up again.
May 13, 2011 | Dell Studio 1537 Laptop
Dell inspiron 1525 when starting it says resuming windows then goes to hibernating with a little blue curser going around
Turn the computer off, remove the battery, make sure it is not plugged in to power, and hold the power button down for 10 seconds. Wait about a minute before re-installing the battery. If it does it again, hold F10 while the computer is turning on, this should bring you to the "boot select" menu, use the arrows on the keyboard and select "start windows normally" instead of "resume windows". When you get it started up run "Defrag" to prevent this from happening again.
When windows hibernates it saves everything in the ram to a "swap file" on the hard disc. Sometimes hard disc's get "bad sectors", this is considered wear and tear, it happens eventually to all drives. It sounds like there is a bad sector on your disc where the swap file is stored, so you have to start windows without using that part of the disc, then by running defrag the computer will find the bad sector and remember not to use it anymore.
Have a nice day.
Jul 24, 2010 | Dell Inspiron 1525 Notebook
Dell Inspiron 6000 screen goes black / hibernates / turns off
well go to your power setting by clicking on the battery by the clock and then say power options to change those setting such as Hibernating sleep ect... you can also get to this by going to you control panel then power options hope this helps
Jul 28, 2009 | Dell INSPIRON 6000 CENTRINO...
When watching movies on netflix my monitor hibernates after 20 minutes..can you help with this?
Open up the Control Panel and double-click on the Power Options applet. Change your current power settings so that the monitor will not turn off after 20 minutes of idle time (set it to Never).
May 26, 2009 | Acer AL1916W 19" LCD Monitor
How to turn on toshiba satellite M300 laptop from hibernating mode
hi shirleygty, is that automatic hibernation (the computer hibernates by itself) or manual hibernation (by pressing the hibernate button)? If either applies to your case you might need to update the BIOS information for your computer to fix the power management issues on it. You can get it here. Just run the file, click install & choose Install From Windows. Make sure you don't have any BIOS password or any external devices connected to the computer. When the update completed successfully, your computer will automatically restart, then try hibernating this time (manual or automatic). I do recommend setting the hibernation to 1min. at the control panel > power options > change when to turn off the display. When it hibernates, pressing any keys or the power button should wake up the computer.
Hope this helps.
Oct 05, 2008 | Toshiba Satellite A205-S4617 Notebook
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
