Question about Dishwashers
Dishwasher just won't clean even lightly dirty dishes. Sounds the same as usual but very poor results.
    Scholar:
  • 145 Answers
Run one cycle of your dishwasher empty, with a mild, food acid of your choice. Do this after you've done the other cleaning steps here, so that it will also take care of anything your cleaning missed or knocked loose. A "light" or short cycle is usually sufficient. Place powders into the detergent cup. Place liquids in a right-side-up cup or bowl in the top rack. Use whichever of the following is on hand or inexpensive:
  • Lemon juice
  • Distilled white vinegar
    I also had this problem before and the above soultionseemed to fix my issue with some internal cleaning.
    I also had this website saved that gives you some more ideas
    http://www.partselect.com/repair.aspx?appliance=dishwasher&part=dishes-not-clean
    Hope this helps :)
  • Posted on Apr 15, 2009
    Detergent lid opens, but undissolved detergent streaks down door and dishes aren't clean.
    5 results (0.58 seconds) Search Results
      Support - Dishwashers DW80F600UTS/AA ' Samsung ...
      www.samsung.com > Home > Support > Dishwashers
      Samsung ElectronicsVisit Samsung today for DW80F600UTS Top Control Dishwasher with Stainless Steel Tub (Stainless Steel). You'll find product and support information for our ...Missing: black ‎undissolved ‎streaks
      Dishes still dirty - dishwasher ' Ask MetaFilter
      ask.metafilter.com/145865/Dishes-still-dirty
      Feb 13, 2010 - If they use dry dishwasher detergent, some of the undissolved dishwasher ... (part of the pump of the dishwasher) breaking down or some piece ofblack plastic (often a ... Every single dishwasher I've ever worked on had a built inwater heating element. ... That's all we use and never get spots on our dishes.Missing: samsung ‎dw80f600
    Jan 19, 2016 | Samsung DW80F600 24" Black Built-In...
    My dishwasher won't clean the dishes properly - very poor cleaning results with residue left on the dishes.
    Check The Salt-Level ? Dishwashers rely, On salt and cleaning Fluids/Rinse Aids et,c. Also check for Any Blockages or Obstructions/Kinks/Bends et,c. in The External Outlet/Waste pipe.
    Mike.
    Jun 02, 2011 | Hotpoint 24 in. FDW60 Free-standing...
    Dishwasher is leaving white residue on dishes, won't come off
    Their are quite a few reasons for a dishwasher to have white residue on your dishes. I will list some steps to take and help you get your dishwasher working again.
    1. Are you low on Rise Aid? Most dispenser have a 1-6 setting right under the cap. Make sure your set between 3-4 for the best results. This additive helps in cleaning and drying your dishes and most manuals will say its required for best results.
    2. What type of detergent are you using? If you are using the dollar budget type product you will get very poor results. If you are using a name brand make sure it does not have rise aid already included. Too much rise aid could cause white residue as well.
    3. Do you have hard water? Hard water can make it more difficult for your dishwasher to clean. Be sure to use a dishwasher cleaner such as Dishwasher Magic at least once a month. Your dishwasher does a great job at cleaning dishes but when it gets dirty it needs a little help.
    Dec 06, 2010 | Kenmore Dishwashers
    It' no longer cleaning my dishes
    hello,
    If your dishes are coming out of the dishwasher covered by a removable dirty film, your water may not be hot enough, or you could be using an inferior brand of automatic dishwashing detergent. If you have tested your hot water and find it is between 140 degrees and 160 degrees Fahrenheit, consider how long it takes for the hot water to reach the dirty dishes in the dishwasher. If the hot water has to travel a long distance to reach the dishwasher, chances are the water filling the dishwasher starts out cold. To alleviate this problem, run the hot water nearest to your dishwasher until the water coming out is hot. This will guarantee the water filling the dishwasher is as hot as it should be to properly clean dirty dishes.
    To remove this type of film from dirty dishes, after running the dishes through a basic rinse cycle, set a bowl filled with a cup or two of white vinegar on the lowest rack of the dishwasher. Remove any metal pans or utensils, and with the vinegar on the bottom rack, wash the dishes as usual. Dirty dishes that were once covered in film should come out squeaky clean
    thanks.
    Oct 23, 2010 | Dishwashers
    Dishes are still dirty at the end of the cycle
    hello,
    hope this help?
    thanks.
    Oct 23, 2010 | Kenmore Dishwashers
    GE Dishwasher - poor cleaning
    I believe there is a screen/filter on the water line before or at the water fill valve. If that gets plugged it can restrict the flow. The fill valve can also fail/get plugged and restrict the flow.
    Also, dishwashers usually have a level sensor to tell when there is enough water to do the wash. It may be a float inside the tub that operates a mechanical switch or it may have a hose to a pressure sensor. Either type can get greasy/dirty/plugged and as a result cause improper water levels.
    Check both the water supply filter/fill valve and the level sensor. One or both of those may be involved.
    Mar 10, 2017 | Kenmore Dishwashers
    The arms do not spin and no water is going through them
    Switch to a brand name powder detergent like Electrosol or Cascade. Never use ultracheap, generic DW detergent powder in any dishwasher. Run a load with dirty dishes and see the results are.
    If cleaning results remain poor open the sump area by removing the lower spray arm and the filter assembly. Remove all debris in and around the sump area. Inspect the impeller down there to make sure it is not broken and that it spins freely. Clean the filter well in the sink. Reassemble. Also, check all spray arm holes for blockage.
    Run a load of dishes and check cleaning results. If problems continue, you almost certainly have a failing wash motor and replacement is your next step.
    Post here is you would like more assistance. Good Luck!
    Apr 11, 2009 | Dishwashers
    Dishes not clean
    If your dishwasher is cleaning poorly, check these:
    Water-inlet valve
    Internal filters
    Drain valve
    Spray arms
    Water temperature
    Detergent cup
    Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
    When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
    Dishwasher Water Inlet Valve Replacement
    Be sure to read and understand any instructions that come with the new water inlet valve.
    Tools required:
    Adjustable wrench
    Multi-Screwdriver
    Pliers
    Apr 04, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
    Dishwashers Logo
    62 people viewed this question
    Top Dishwashers Experts
    Owen Barnes
