Question about GE WBSR3140DW Top Load Washer
Doesn't agitate or spin - GE WBSR3140DW Top Load Washer
  • 1 more comment
  • irenehowerto Apr 15, 2009
    The washer has a new timer, a new lid switch. The knob broke on a sunday I coninued using the washer with out knob and broke the timer. We ordered the new part put it on and it did nothing different. So I ordered a new switch, this new part did not make a difference. I got on this website and also read a reset to do for different models, which has not worked either. It fills with water goes through the cycles with out washing comes to rinse cycle it drains and empties no agitation and final spin only pumps water out. It does this on each setting of this washer.
    My model # is GE whdsr209g2ww.
    sINCE IT IS THE AGITATE AND SPIN CYCLE THAT ARE NO LONGER WORKING. THE RESET STEPS YOU JUST POSTED HAVE ALREADY BEEN PREFORMED AS I MENTIONED IN MY LAST STATEMENT. SO YOUR SAYING THE MOTOR IS NOT GOOD? WHAT WOULD CAUSE THIS IN A 2 YEAR OLD WASHER?
  • irenehowerto Apr 16, 2009
    I bought a new washer, the replys to this were answers I had typed in my original post. Wasn't offered anything else to do that I didn't already know.
    President:
  • 987 Answers
If spin always works when you turn the dial to the "spin after rinse" section of the dial, then you have a problem with the timer. Check it a few times to make sure that it really is only the wash section of the dial that won't do spin, because timers can be a bit expensive, and "no spin" can be caused by many things. Once you are sure that it is /only/ the spin during wash cycle, you can do a search for the part by model number (located on a sticker under the lid or possibly on the back of the control panel). Changing them is easy.
Posted on Apr 15, 2009
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
Whirlpool lsq8243h doesn't aggitate
if it doesn't agitate but will spin it is probably the agitator cams.
http://www.repairclinic.com/PartDetail/Agitator-Repair-Kit/285809/470910
If it doesn't spin it is probably the motor drive coupling
Here is a link to the part and a video on how to replace it.
I would suggest watchine the Video before you order the part then you can check if this is the problem.
http://www.repairclinic.com/PartDetail/Motor-Coupling/285753A/1195967
Oct 07, 2012 | Whirlpool Washing Machines
Whirlpool lsq8243h
If it doesn't agitate but will spin it is probably the agitator cams.
Oct 07, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
Maytag washer doesn't agitate
Google the model number. I had the same problem, Googled it, and found the actual turial on YouTube to fix it.
Dec 11, 2011 | Maytag MAV6200 Top Load Washer
My washer fills, agitates but will not drain
Does your washer spin? If yes, and it doesn't drain it most likely a failed/plugged pump.
If it doesn't spin it could be a belt or timer issue..
Sep 15, 2011 | Maytag MAV2755AWW Dependable Clean Top...
My 110 20862990 kenmore washer doesn't spin, the motor runs, it drains, and the coupling is in good shape. On another DIY page it asked to turn the drive side of the coupling one way to see if the...
My washer was doing the same thing. I had a magic marker on the bottom of the plastic tub below the inner tub. The agitation cam could not release for spin. I remove the magic marker and she took off.
This video shows how to get the inner tub out:
More here
More here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 09, 2011 | Kenmore 24032\24036 Top Load Washer
I have a Maytag Model A412, series 11 washing machine. After the machine fills with water the machine appears to start its cleaning cycle but the agitator doesn't work. The water starts & the...
if this is a two piece agitator,it should behave like a ratchet turn freely clockwise and catch counter clockwise if it doesn't catch the agitator "dogs " are shot this is a verry inexpencive repair
Jun 08, 2011 | Washing Machines
Old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Sep 29, 2008 | Washing Machines
GE WBSR3140DW Top Load Washer Logo
66 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
