Question about Dryers
My belt broke on my kenmore dryer and the idle pulley was just laying on the bottom. how do i install it or a new one and does the belt sit on top of it or thread through it.
  • popguntim Apr 15, 2009
    can't find a spring or a place to connect a spring unless the
    spring is underneath the dryer???
    President:
  • 1,865 Answers
The pulley should be attached to a spring and its used as a tensioner (keep the belt tight) find a spring that is not connected on one end
Posted on Apr 15, 2009
I have a Kenmore Gas Dryer (model 11087471810) that threw its belt. I have the replacement belt and know how to replace that. When I opened the bottom of the dryer, I noticed the Idler pulley sitting at...
The idler pulley/tensioner fastens into two slots in the base of the dryer to the left of the motor . The belt goes around the drum then through the idler to the motor pulley ,you have to make a loop with the excess belt and feed it through the idler pulley, i normally pull the plastic pulley towards the right side of the dryer to give enough belt to go around the motor pulley then let the plastic pulley rest on the backside of the belt. do not turn the drum too much as you may pull the belt back off .
May 13, 2011 | Kenmore Dryers
How do i get tension in my new dyer belt
All dryers have a belt tensioner installed. If your belt came off before opening the dryer up, the tensioner is laying at the bottom more than likely. It has a pulley on it for the belt and the pulley should be replaced as well
Jul 05, 2010 | Dryers
Need to install drive belt- lady kenmore dryer..loop designation
The belt probably broke first, which caused the idler pulley to come loose. This is normal. With no tension on the pulley it will commonly fall over. To re-install, follow these steps:
1. Loop the new drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. If this is a Kenmore dryer, it will be manufactured by Whirlpool. Refer to diagram H. If you still have questions, please let me know. I hope this helps you.
Jun 25, 2009 | Dryers
Belt on my Kenmore series 70 dryer broke. How do
broken belt......simple fix.......remove lint filter from top 2 screws remove.........insert screwdriver between top & front push down to pop top......1 screw on each side holding front on at top remove them....front will then pick up off the 2 remaining clips at the front bottom.....spin door around to the side belt should be laying in the bottom of the dryer or around the tub but broken.......hope this helps......check back.......
May 05, 2009 | Kenmore Dryers
Belt broke
Buy a new belt. Insert the idler pulley into the slots under the motor pulley. The wheel should be on the left side of the motor as you face it.
Put the belt around the drum, then through the idler roller. Then over the motor pulley.
Mar 11, 2009 | Kenmore 63942 Dryer
The dryer belt came off the idle pulley came off
i have no picture but it sounds to me like my old dryer. There should be a couple slots on the bottom piece of sheet metal. The pulley will appear to just loosely sit in these...wtf??? Its a trick its mostly the reverse pressure of holding the belt that keeps it in place. So when you removed the belt the idler just kinda fell outta place. mine was a whirpool though so ur situation could be totally different. good luck
Feb 18, 2009 | Maytag Dryers
Dryer belt broke on my kenmore series 80
With the front cabinet panel off, place the drum against the back and on the rear rollers. The roller on the right will sometimes move toward the rear so reach from underneath and pull it forward. The rollers should sit in the groove. The drum will tilt forward but shouldn't fall off. Route the belt around drum, pulley and motor. Tilt the drum back and support it while placing the front panel back onto it's hooks. With the front panel on (don't screw it on yet), rotate the drum by hand to make sure the seal is not kinked and the belt won't slide off the pulley or motor. If all is well screw in the front panel and re-assemble the rest.
Feb 16, 2009 | Kenmore 62622 Electric Dryer
Install a dryer belt
depends on the brand. always post brand and model #.
if it is a whirlpool or kenmore the idler pulley will be laying in the bottom of dryer. the belt should have come with instructions as to how to loop it around motor pulley and Idler.
J
Jun 10, 2008 | Dryers
Kenmore series 70 electric dryer idler pulley
I figured this one out...there are two pairs slots...the tab of the idler pulley goes in the right slot near the motor and the idler pulley goes off to the left.
Nov 13, 2007 | Kenmore 60172 Electric Commercial Dryer
Dryers Logo
35 people viewed this question
Top Dryers Experts
