Question about GE Washing Machines
GE washer doesn't spin or agitate has new timer new lid switch still nothing have tried the reset for other GE models
  • irenehowerto Apr 15, 2009
    GE well it started out with the timer, actually only the knob broke timer was broke trying to use it with out knob, so what could have possibly happened to the motor. My model 3 is whdsr209g2ww
    President:
  • 1,865 Answers
Bad motor?
Posted on Apr 15, 2009
  • buffalonyman
    buffalonyman Apr 15, 2009
    Did the washer work after installing the new timer?
My model GLET1041AS2 Frigidaire Laundry Center fills/agitates, but does not pump or spin. The timer would make a slight buzzing/timer sound when it hits the spin cycle, but nothing else.
The circuit board has a Cycle generator and sequencer that accepts commands when you manually do a setting. When the sequence enters the spin phase a block occurs and discontinues further action. It is not the timer, but the command center on the circuit board. Because the board has many functions, it is like a set of Christmas Tree lights in series, and when one bulb fails, so goes the set. You will no doubt need a new command board for that model.
Mar 12, 2014 | Frigidaire Genuine Washer Timer 134049600
I have a model WJRE5550H1WW washer that will fill agitate but will not pump out and spin
first check the lid switch, a lot of washers will agitate with the lid open but wont spin out. If its not that check your timer and then your water pump. Most likey it is the lid switch.
Feb 27, 2012 | GE WBSR3140DW Top Load Washer
GE Washer does not drain or spin
Inspect the drain hose for kinks
Test the timer control
Test the lid switch (some models)
Inspect the water pump
Inspect the drive belt (belt drive only)
Inspect the motor coupler
Jul 15, 2009 | GE WDSR2080D Top Load Washer
My washer agitates but will not spin
Check the lid switch, in some cases if the lid switch is broken it will agitate, but will not spin.You may need to replace the belt, if belt is in good condition and tight, you may need to check the timer. When you find the faulty part that needs to be replaced call First Source Parts and use the model number to order the part you need.
Jul 05, 2009 | GE WJSR2070B Top Load Washer
Agitator doesn't spin during wash cycle
If The washer won't agitate
Check to make sure no clothing got wrapped around the agitator. Check the lid switch, timer, and drive belt, other potential causes, such as a bad transmission or bad agitate/spin solenoid, but they are much more involved.
if the washer won't spin, the lid switch, timer, drive belt, transmission, or agitate/spin solenoid could be the cause here as well. Sometimes if the load is unbalanced or too heavy, the washer won't spin. Take some of the clothes out and try the spin cycle again with a lighter load.
Here are the steps to replace the agitator.
1: Take the fabric softener dispenser off and pry off the agitator lid.
2: Use a socket wrench with an extension bar to remove the stud and seal.
3: Remove the agitator top and bottom.
4: Check the agitator clutch assembly (located in the agitator top) for excessive wear.
5: To replace, just reverse the directions.
Jun 29, 2009 | Washing Machines
GE washer no main motor run so no agitate or spin
This is the electronic washer. Unplug for two minutes, plugin then open and close lid 7 times. This will reset motor. Also make sure belt is not broken.
Jun 07, 2009 | GE WBSR3140DW Top Load Washer
Will not agitate or spin
Check 1. the water level switch, 2. the timer, 3. the lid switch.
May 15, 2009 | GE WBSR3140DW Top Load Washer
GE TOP LOAD WASHER DOES NOT AGITATE OR SPIN
ck lid switch can be acessed by pressing clips at front edge of front anel and pulling panel off
Nov 20, 2008 | GE WWSE5200B Top Load Washer
Actual model is WWA3650SALWH
JUST A QUICK SUGGESTION FOR YOU ... ON MOST WASHER MOTORS THERE IS A SMALL RESET BUTTON ON THE MOTOR ITSELF. TRY RESETING IT ... IF IT RESETS AND POPS RIGHT BACK OUT OR IS JUST FLOATING THE MOTOR IS MORE THAN LIKELY BAD OR ... YOU MAY ALSO HAVE A CAPACITOR START MOTOR. THE CAPACITOR IS UNDER A COVER ON THE MOTOR ITSELF THAT CAN BURN-OUT OR GO "OPEN CIRCUIT". THEY ARE REPLACEABLE. IT SEEMS YOU HAVE CHECKED ALL THE OTHER CULPRITS I USUALLY SUGGEST. I HOPE I COULD HELP OUT.
May 02, 2007 | GE WWSE5240D Top Load Washer
Washing Machines Logo
191 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
