Can't install OEM Windows XP on fresh hard disk
Install OEM Version Windows XP on Compaq Presario 700US? Tried several known good discs, XP Pro and Home. Install starts normally, loading files etc, the the computer reboots at the same point everytime....Strating Windows setup. No errors mentioned, just a hard reboot. Any ideas?
  • 1 more comment
  • nevis1 Apr 15, 2009
    jlpurvis2009....I tried reseating the memory, and ran memtest an Microsfot's MemTest for about 2 hours each. No errors. The hard drive is a Toshiba, and they do not have any utilities. Blew out all fans and made sure they were working. Also I never get a chance to format the drive, as the PC reboots before I get a chance to format. Used a program called Zap which deletes all aprttions, so all I need to is install the OS.
    Did find this, http://www.dslreports.com/forum/remark,1... which at least now the PC does not reboot, but locks up at the "Setup is starting Windows.
    Just tried a new hard drive that is known to be good, smae problem. :(
    Found a Toshiba disk utility, ran it all was fine. Used Gdisk to wipe.
    No luck
  • 64 Answers
Could be a memory or hard drive problem. Try reseating the RAM, then going through a complete reinstall again, and do a regular format to NTFS, not a quick format.
Posted on Apr 15, 2009
    Champion:
  • 207 Answers
Please check the consistancy of hard drive or try to run a zero format first and then reinstall the win
I am having HP COMPAQ PRESARIO MODEL. I HAD CHANGED HARD DISK AND INSTALLED FRESH COPY OF WINDOWS XP. THE STAND BY OPTION AND OTHER VIDEO FUNCTIONS ARE NOT FUNCTIONING NOW DUE TO NO DRIVER FOR VGA..PLZ...
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure
you select your model motherboard and the XP Windows version of the drivers you require and install them. Click onthis link to download the drivers: -
www.compaq.com/country/cpq_support.html
Feb 06, 2011 | HP Compaq Motherboard
Not recognizing hard disc drive for windows xp reinstall .
You aren't using the correct install disk . The generic XP install disk can't recognize a SATA disk.You will have to load the appropriate driver during install. Here it is ftp://ftp.hp.com/pub/softpaq/sp32001-32500/sp32492.exe
Or you could create a custom install disk  as explained here
http://news.softpedia.com/news/Install-Windows-XP-On-SATA-Without-a-Floppy-F6-47807.shtml
May 13, 2010 | HP Compaq Presario C304NR Notebook
Changing Vista to XP Pro on a Compaq Presario SR2180NX Desktop PC
SR2180NX has the Vista 32Bit OS from HP. The restore partition will always put Vista 32Bit back on if you use it. Windows XP can only be put on from scratch and I have done it while I still have Vista installed. One problem: there are no XP drivers under SR2180NX webpages. Do your research on the parts that are installed in the 2180 and any other HP machines that have the Windows XP operating system as the OEM OS. But First, check the Intel Site for the 945 chipset drivers (include the SouthBridge, too) under XP. Get them downloaded to a CD and burn the rest of the drivers you find for XP on the same CD. This way, you will have them ready when you are performing the down-grade to windows xp. After you are done with the XP install, you will still have access to the files & work you had done while in Vista. The Vista files are still readable. You might want to consider getting the Windows 7 Professional (not basic) available October 22, 2009. AND you will still have to get the Intel Downloads for Win7 any way, so why not make it a project and make it last for a few years. XP Support stops in 2014.
Sep 07, 2009 | HP Compaq Presario SR2180NX (RK548AA#ABA)...
Compaq Presario C300 Recoivery Disc 2 corrupt
Hi John.
F11 process is not working and you get a NTLDR missing when you turnon the notebook.
Steps to be performed:
1. Perform hard drive self test from BIOS.
2. If it is passed then use retail version of operating system disk to install XP or try using new recovery disks which nay cost you $15.00.
In your notebook model this issue appears if there is any issue with the hard drive.
Jul 04, 2009 | HP 435768-001 - Compaq Presario C300...
Compaq 2500
The disk itself may be corrupt , go to microsoft and download xp home or pro , whatever your using and burn to a disk .If you don't have access to another computer , go to a repair shop and you can usually buy a burn't copy of xp for 5 to 10 dollars . RE-install as usual. please note !!! you must know what service pack is needed for the install . SP1 - SP2 ....OR to be on the safe side just get XP SP1. good luck!
May 30, 2009 | HP Compaq Presario 2500 HP Pavilion ZE...
IBM NetVista M41 PC Desktop Os Install Impossible
You probably need an OEM version of XP...not that IBM version. If you buy an OEM version, you can use it many computers. A real XP disc will partition, format, and delete partitions on any functioning Hard drive. Don't buy a recovery disc, please. That just sounds WRONG.
A cheaper solution might be a new Hard Drive...but I don't trust your IBM version of XP.
Apr 07, 2009 | IBM NetVista PC Desktop
Sound drivers problem Compaq Presario 784TU
thats cause the drivers you are installing are not compatible with windows xp
here is the link for the xpdrivers
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3739730&lc=en&cc=us&dlc=en&submit.y=7&submit.x=2&lang=en&cc=us
click on Windows Xp,, download and install them..
Mar 02, 2009 | Compaq Presario 700US Notebook
Compaq Presario SG3430IL Desktop PC display does not work with windows xp sp2 and vista
Kindly get me the drivers as i have installed xp in my compaq system. and i want drivers for that
Aug 20, 2008 | HP Compaq Motherboard
Compaq Deskpro EN contant restarting when attempting to load XP
Last time this happened to me, I had to reformat and reinstall windows. I tried all those modes, and I even tried the windows repair. None of that worked, I just did a complete new install. All of the data will be lost, if you do this.
My advice, if you need some of the data on that hard drive, you need to hook the drive up to another computer and backup what you need.
Or buy another hard drive, install windows on the new drive. Now slave the old and backup the data.
Nov 11, 2007 | Compaq Deskpro EN PC Desktop
Computers & Internet Logo
361 people viewed this question
David Payne
David Payne
