Question about RCA Lyra RD2765 MP3 Player
Hi when i terned on my lyra after checking battery it says file system corrupted what did i do wrong and how to fix it?
  • 150 Answers
To fix this you need to format the device(all stored music will be lost). To do so plug the unit into your usb port. Got to my computer and it should up as a removable disc usually comes up as drive F:, right click the icon and hit format. Usually magnetic interference can cause this problem, did you have it to close to any speakers or sub-woofers? Any magnets that get into close proximity will do this. Good Luck Hope this helps
Posted on Sep 14, 2007
SOURCE:
Mp3 wont work
If the file system is corrupted, you have put files into the wrong folders.
To fix it, simply copy over all of your files from the mp3 player to your computer, format the mp3 player, then synch the files back onto it.
Oct 14, 2009 | RCA Lyra RD2763 MP3 Player
Everytime i try to turn it on it says file system corrupted. It Does not go any farther then that.
Manual for Lyra RD2762 in pdf format:
http://www.voxxsupport.com/images/manuals/RD2762/media/RD2762_UMEN.pdf
Troubleshooting from page 53:
In case of a corrupted file system: player must be formatted.
FIRST BACKUP YOUR PLAYERS' DATA BEFORE FORMATING !
How to reformat the player is explained on this site:
http://voxrightnow.custhelp.com/app/answers/detail/a_id/1529/kw/lyra%20format/p/158/r_id/103795
Home page on all support for RD2762:
http://support.rcaaudiovideo.com/manual.aspx?product=202
Sep 19, 2009 | RCA Lyra RD2762 MP3 Player
FILE SYSTEM CORRUPTED MESSAGE
go to http://www.rca.com/digitalaudiodownloads/ and select your mp3 model and update the firmware.
Aug 17, 2008 | RCA Lyra RD2762 MP3 Player
My RCA LYRa is having issues!!!
http://www.fixya.com/support/t126039-file_system_corruption
(H115A)
Had "File System Corrupt!" message appear on my RCA H115A after a bit over a year. PC wouldn't recognize it, and it wouldn't stay turned on.
Following advice (thanks folks), I uncovered the screw under the barcode and popped the back with the help of my knife. I didn't notice that the connection from the hard drive was loose, but pulled it out, wiped everything off, and reconnected. It worked!
They don't give this at the help desk, but it seems to be a common problem with many models. Looks like the connection isn't very tight.
Jan 05, 2008 | RCA Lyra RD2763 MP3 Player
System file corrupted
I actually fixed this!!! Mine had been giving me the "file system corrupted" error. So, I opened it up (unscrew the screw on the back, pry the back cover off with a small flat head screwdriver or a key, etc.) and saw that the connector between the CF drive and the motherboard had come apart.
I re-inserted the cable into the groove of the connector on the motherboard, pushed the broken/separated piece of plastic that serves as a retainer for the cable back down, held it in place, and taped it down with a 1/4 inch wide strip of duct tape (taped all the way around the connector/cable to help keep it in). I put the Lyra back together and then turned it on... and it WORKED! It came right on into the normal menu! Yay!
Good luck other people, I hope that this is the same thing that happened to your player and that you can also fix it! =)
Nov 30, 2007 | RCA Lyra RD2763 MP3 Player
Have you tried replacing your firmware? I believe the firmware for that model is here http://drivers.softpedia.com/get/FIRMWARE/Lyra/Lyra-Mp3-Player-RD2760-firmware-207.shtml but you may can get a newer version from rca's support site.
Nov 20, 2007 | RCA Lyra RD2762 MP3 Player
My RCA Lyra RD2765 MP3 Player
mp3 player says the file system is corrupt
Aug 22, 2007 | RCA Lyra RD2765 MP3 Player
Thomson Lyra Jukebox pdp2860 av system files problem
go to this page, http://rcaaudiovideo.com/en-US/RD2780_Upgrade and follow the instructions, i had this same problem, and i fixed mine
Jul 23, 2007 | Thomson Lyra PDP2860 Digital Media Player
File system corrupted
Here is a real answer that may give you some insight. A lyra is a hard drive player and you must treat it like a hard drive. Run a scan disk check or some virus soft ware. Maybe even reformat it and down load and reinstall updates. However, if it is like mine and not allowing you to access anything on it to be able to fix it, then i guess we will have to get another one. RCA is under a new name since a few years ago. The new company is Thompson Inc. These people assumed RCA's name but give **** customer support.
Dec 29, 2006 | RCA Lyra RD2765 MP3 Player
RCA Lyra RD2765 MP3 Player Logo
54 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
