Question about Samsung SCX-4216F All-In-One Laser Printer
Line across left side when scanning or faxing
When I fax there is a solid thin line down the left side of the paper. This will happen when I scan unless I put the resolution at 1200 by 1200.
  • Anonymous Apr 16, 2009
    It doesn't have the problem when just printing. Just when using the scanner to scan or to fax. You can see the line without printing.
  • 4 Answers
Check your drum for any marks, or fused toner.
James Morgan
Gigafix Ltd
Posted on Apr 15, 2009
Line appears on scans and faxes
Do you use the document feeder when faxing and scanning? If so, the line is likely some paper dust, white-out, or other dirt on the thin piece of glass to the left of the main platen glass. Wipe that glass strip with a lint-free cloth, and if that doesn't work try using a little bit of alcohol.
If the line persists, or it occurs when you don't use the document feeder, it's probably dust somewhere in the optical portion of the unit, underneath the glass. If you want to take it apart, you can blow some compressed air around down there to scatter the dust or try wiping down the mirrors with a lint-free cloth.
May 05, 2010 | Brother Multi-Function Center MFC-240C...
Copies leaves lines when put through the feeder,but not on the glass .......have cleaned and sprayed air can everywhere I can think of The Hp Printer is HP 3055 All in One printer
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page.
If this is your problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Mar 16, 2010 | HP LaserJet 3055 All-In-One Printer
Unwanted verticle line on fax copies
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page. If this is the cause you will also find that faxes you send to other people will also have this line (although faxes you receive are not affected by this problem with your machine).
To fix the problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Feb 22, 2010 | Brother IntelliFAX 560 Plain Paper Fax
I get lines and can't read the right side of copies that I make with the 1270e. How do I fix this?
You have not specified why you can't read the right side of copies and I am assuming that the reason is because the 'lines' are covering the text. I can offer a solution to the lines issue.
Feb 22, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
I have a black line showing up on my faxed documents. I have opened it up, changed the film and re- set it, but the problem persists. The machine is about 5 years old.
Feb 07, 2010 | Brother IntelliFAX 775 Plain Paper Thermal...
A Solid black line down the left side of the page
It could be 2 things...
1. Your scanner glass is dirty...open the doc feeder and clean the glass. probably Wite-Out.
2. A segment of your scanner assembly lamp is burned out. Not good, uneconomical to repair.
Jan 21, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
2" black horizontal line appears on paper when I fax, print,
Check the wondow where the paper passes to be scanned. You will probably find some debris or white out stuck on the glass. That is usually the cause of vertical lines on sent faxes.
Sep 17, 2009 | Office Equipment & Supplies
Black line down one side of paper
Lift the auto feeder cover and clean the narrow glass that the originals are scanned across...sounds like you have some dirt there -maybe correction fluid? That's the most common.
Please rate me :)
Jun 23, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
2" BLACK LINE
1- itis on the Scanning unit open and look for a thin strip of glass, clean
2-the scanning unit is bad
Assuming it's only on Outgoing Fxs and not incoming as well ( that would indicate the drum)
Sep 10, 2008 | Brother IntelliFAX 4100 Laser Fax
Lines Through Faxes
If WHITE LINE(S) appears clean the scanning unit...if BLACK LINE(S) clean the thermal unit.
Jan 28, 2008 | Sharp UX 510 Plain Paper Thermal transfer...
Samsung SCX-4216F All-In-One Laser Printer Logo
114 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
