Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Mitsubishi Diamond WS(???) rear projection t.v.
Hi...It's about 4 years old and now it suddenly turns off and I have purple horizontal lines shaking all over. I read other problems, but none say "purple." I can see a picture, but after about 30 seconds, the picture goes away and these shaky purple lines appear with a black background. After reading other probs, I wonder if it's a bulb? Thermostat? Please help...Someone's coming over to check it out, but couldn't even guess (with my description of problem) what the prob could be. I love this t.v. It's the best! We have flat screens in bedrooms, but this can't be beat! Big & bulky and still the best!!!
Thank you!
    President:
  • 788 Answers
When the repair person gets to your house, first of all, let them work. Then once all is done ask them what they think is wrong with the set and how much it will cost. I think that you have lost the use of the green CRT, and you may just need a driver IC to fix it. You can ask the technician these questions and get a straight reply.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Posted on Jun 24, 2009
Image distortion
In the customer menu select convergence and then with the Mitsubishi remote select advanced, you should see a grid of lines.
If red or blue or green are out of position you have a problem in the convergence circuit.
If so, I have step by step instructions for this kind of repair and it can be a do it yourself job.
SD TECH
May 04, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Power Loss
You will find 4 swollen capacitors in the DM module of value 1000uF 16volt. Replace them.
Aug 31, 2009 | Mitsubishi WS-55711 55" Rear Projection...
Mitsubishi 55 inch-ws 55511
23 code means "loss of Horizontal Deflection"
Nov 14, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55613 Not Reading Sources
have tthe tuner checked...it may have gone bad
Oct 01, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Diamond Shield Mitsubishi 55315
if either of u r close to michigan i have the above tv with no video possibly willing to part it out
Nov 11, 2007 | Mitsubishi WS-55313 55" Rear Projection...
Pink horizontal line when the tv is powered on.
1. White raster with no signal, washed out looking video with signal. Access the service menu, "menu 0357" use the audio button to select "video chroma" adjustments, use the video button to select item "40 - AGIW", use the adjust button to change the setting to 0, then press the enter button to store the change.
Jun 13, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Horizontal Lines in picture
CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB. HOPE THIS HELPS!
Jan 12, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
265 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
