Question about Akai LCT3201AD 32 in. LCD Television
IC2 for MLT169C - Akai LCT3201AD 32 in. LCD Television
Menja ga SG6841S,reseno
Posted on May 15, 2009
Jebem li ga ne znam ni ja koje je:)
pozdarv
Zdravko
Posted on May 03, 2009
Mlt168a what is ic2
is the main memory of ur unit , is located in the main siganl board
Dec 02, 2010 | Akai LCT2715 27 in. LCD Television
Pmp3000 got hit by lightning 1 leg of the ic2
Th TOP221P chip is available but I can almost guarantee you have other damage as well. I assume it is pin 5 that burned. D7 and C16 would certainly be destroyed. IF IT IS ANY OTHER pin, you will find many other parts destroyed. D7 is a common 1N4007 and C16 is 4.7mfd/450VDC. Remember to carve out any burned baord material as it is conductive.
For the chip you can procure it here:
http://search.digikey.com/scripts/DkSearch/dksus.dll?lang=en&site=US&WT.z_homepage_link=hp_go_button&KeyWords=top221p
Aug 02, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Shutter opens, but doesn't close? I advance my film, press the shutter release, and it opens, but stays open. The only way my shutter will close is if I press the battery check button. I read a trouble...
That camera needs tobe services. The IC2 is the technicians code that tells where to start. With the problems you describe it would be best ot let a technician overhaul and recalibrate it if possible. then you will have a camera that operates like new.
Apr 28, 2010 | Canon EOS-AE-1 35mm SLR Camera
No water pressure on my honda 2600 excell ic2 model xr2625
you need to check the valves,
there is a possibility that the springs are rusty.
Nov 15, 2009 | Garden
My Plaxma flat screen, AKAI PDP4294 is dead
Well, I will tell you Jim that plasma flat screens as a whole are having similar problems without regard to brand or model. Part of this problem with others has been the poor quiet fan cooling setup they have in them to say the least. The problem you have experienced is in the voltage regulator section of your power supply. Without being able to see exactly the section the IC2 is in I would have to look at a good schematic to find the right part # for. However, through my experience oveer the years I usually go ahead and desolder the part and take it to a large electronic supply house and they are usually more often than not able to identify the component for you without a schematic. However as you said and you are correct in thinking that the plasma tv you have may give you a similar problem in the future without any added cooling fans on the back cover. Do not be deceived though because LCDs over 32" and above suffer similar problems with the added one that they have images that actually burn-in to the screen much like computer monitors and that is annoying as well. Even if your tv is more than 2 years old and past the warranty period, you may be successful in getting it replaced with a new one because you have a very common problem occuring here that I know the manufacturer knows about. Most plasmas are rate to have 60,000 hours of use which is 20 years, they just have not developed or been around long enough to substantiate that claim. Good luck and God bless.
Jan 14, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Aficio 1035
ic2 bus on BICU board defective.
Jul 02, 2008 | Ricoh Aficio 450 Copier
Red light still flashing
you also have to replace the 2 resistor on bottom of the board they are 10 ohms each they are surface mount 1/4 quarter watt each they are next to z3, also have to replace the 3 caps. I have fixed 4 units with the same problem this must be obviously a design issue since many of these tvs have the same problem.
hope this helps
Feb 16, 2008 | Akai LCT2701TD Television
IC2
It is a known defect that polaroid won't stand behind!  The original part which I suggest not to but b/c it will just burn up again is UI8007S-1...I highly suggest buying an upgraded part from www.lcdparts.net which is UI8007S-1MSS, and actually less expensive than the worthless original.
I will never purchase a Polaroid product again!!!!
http://www.mp3car.com/vbulletin/lcd-display/74566-backlight-inverter.html
Feb 23, 2007 | Polaroid FDM0700A Under the Counter 7 LCD...
Akai LCT3201AD 32 in. LCD Television Logo
186 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
