Question about Samsung RS2534 Side by Side Refrigerator
Refrigeration problem My temp readings on the front of my fridge read -18 and +3 but the temps inside both are not what it says, If I switch the fridge on and off the compressor kicks in and the true readings come up, once the temps come back down to -18 and +3 the fridge and freezer starts to become warm again but the temps for both stay the same -18 and +3.
  • sligosparky Nov 13, 2007
    Exactly the same on mine!!!
    Novelist:
  • 87 Answers
It sounds very much like control board problem. The chances of both sensors at fault seems unlikely. Unusual that it is the exact same temp unless they are your setpoint requirements. I would advice contacting reliable fridge guy to check the cabinet. Hope this is of some if not much help.
Posted on Sep 15, 2007
FREEZER NOT FREEZING AND FRIDGE FREEZING
please provide your model number it's impossible to help you without it
Appliance 911 Sea Breeze
Jul 31, 2015 | Refrigerators
Sub zero 690 control center readout
A picture would be helpful, but there should be two 2 digit numbers. the one on the top should be fridge temp reading somewhere around 34-40, and the bottom one should be freezer temp, reading around -2 to 05.
Feb 25, 2013 | Sub-Zero 690 Side by Side Refrigerator
Fridge freezer
HI jACQUELINE.well i reckon the fridges r a bit temperaMENTAL.:).Before u do anything well u can check weather u have ice build up on the rear panel inside freezer compartment.either way i would first turn it off for 24 to 48 hours.then remove bottom plinth panel (bellow the door).thoroughly clean condenser coils right to the end.then try u could get lucky.if it doesnt work then the problem could b inside the panel.def/heater,fan motor,t/stat,or the board.good luck Ali
Aug 24, 2012 | Refrigerators
Freezer not maintaining temp
sounds like the evap thermistor took a ****. in the back of your freezer you have cover that sits over the refrigerator coil. under this coil sits a heater element that is turned on and off to defrost the refrigerator coil based on how long you've had the door open. the evap thermistor reads the temp inside the freezer.. close to the refrigerator coil.. and tells the heater element to turn off after it reaches a set temp where it can be sure that the ice has melted off the refrigeration coil which is about 60 deg. if your thermistor has taken a ****.. your heater element will only shut off based on the "fail safe" time (which is based on how long you've had your fridge door open) leading to a hot freezer.
i suspect your at home more on the weekend.. inside the fridge.. getting cold beers.. and that is why it ends up hotter on the weekend.
Cheers!
Jun 14, 2009 | GE Energy Star PDS22SIS Stainless Steel...
Whirlpool side by side Refrigerator not cooling, two -- where -18 temp used to be.
the fact the bowl was filled with water and that you said the inside of the freezer was coated with ice, indicates a failure of the defrost system.
now the ice has gone, reset the temps and wait to see what happens
Oct 15, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Repair
seems like its not defrosting in the fridge. remove rear panel and look for ice around the thermister.
Jan 28, 2008 | Samsung RS2630SH Side by Side Refrigerator
Sounds like a main board problem cause the temp should not be accurate one minute, then way off the next. I would have someone look at this cause it would be difficult to figure this out without being there to troubleshoot it
Jenn-Air Refrigerator side by side
make sure the two vents inside freezer and refridgerator nside are not blocked....normal range is approx -15 to + 15 in freezer,...and 37-42 in fridge...take temp readings inside of both....a full freezer and fridge retian colder temp more...
Jan 03, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
Samsung RS2534 Side by Side Refrigerator Logo
199 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
