Question about RTO Oar Sockets
I have a 1998 Champion 181 bass boat. The navigation lights are not working properly. - When I plug in the front green/red light, it immediately comes on with control switches in the OFF position. (The light is VERY bright) - When I turn the navigation lights (for the rear white light and front green/red light) the front green/red light goes VERY DIM. It is so dim it would be considered to have turned OFF. - The green/red light never goes off in any position of the control switch, even when placed in the anchor position (which should be just the rear white light) I am looking for a wiring diagram to ensure it is wired properly, but I will take any advise possible to fix the problem
    Sergeant:
  • 187 Answers
Check the switch. It sounds like it has seen better days. Also check the wires on the back of the switch to see if they are shorting out. The problem is at the switch area. Good luck.
Posted on May 12, 2009
9.9 mercury 2 stroke #1 coil green/ white or green/yellow
You have some luck looking around the Mercury section of the boating forums.
http://forums.iboats.com/mercury-mariner-outboards-25/
Mar 21, 2013 | Light Outboard Motor Boat Bass Fishing...
Navigation lights in bass tracker don't work
Have you tried resetting the circuit breaker immediately below the switch? Also, if you look under the dash, you'll see how the switches are powered. Older models sometimes have push-on connecters, so it's possible that the connector became disconnected.
home lights
Apr 28, 2012 | Boating
Yamaha 50 hp motor oil red and green oil sensor lights are on
The engine will self destruct if you continue to run it without the proper oil mixture. Some oil systems have to purged of air if ran dry. Seek professional assisstance.
Aug 21, 2009 | Bass Pro Boating
Speaker wire colors
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Aug 10, 2009 | 1991 Ford Tempo 4 Door
1998 Champion 181 bass boat in California...It appears that livewell is leaking into bilge,...and the aeration pump is not working? Could it be the pump? or a fitting at the base of the live well...by the...
try "duct tape" the fittings and drain to seal those areas, refill and see if water is still leaking, if so it's your live-well is cracked somewhere, and can be repaired on the inside with fiberglass resin..... if not then most likely the fittings/pump/hoses/etc....yes its a pain .Champions don't have alot of room to access any of that...got a Ranger myself....hope this helps and see you on the water....GL
Jul 06, 2009 | RTO Oar Sockets
Trailer light problem
Check it with a test light. White-ground, Yellow-left turn, Green-right turn, Brown-tailights. Check it on the truck first. There are seperate fuses for just the trailer wiring in the fuse box under the hood. The Blue and Red wires are for Trailer brakes, don't worry about those.
Mar 14, 2009 | 2005 Chevrolet Silverado 1500 2WD
Wiring a new radio in 1991 ford explorer
Right Front:
Right Rear:
Left Front:
Left Rear:
Right Front:
Right Rear:
Left Front:
Left Rear:
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
Bose lifestyle no sound
Hi, best practice when troubleshooting a no-sound Bose Lifesytle system is to first begin with the internal sources (i.e. the AM/FM). Bose Lifestyle system when connected properly (media center and bass box via the data cable) should show a steady green light underneath the bass module. Begin by simply playing AM/FM tuner and try to increase the volume till 45 (normally the sound becomes audible at this level). If the system still has no sound, then try to check if the bass module is steady green. When you see a blinking green LED (slow green) then do kindly check the DIP siwtch (red latch switch with white mini switches) just beside the Light and data connection. All of the switches should be in "ON" position (basically toggled upwards with the arrow marking indication). Before changing DIP switch settings do ensure that the bass module is not connected to the electrical power. after ensuring that all DIP switch are in the "ON" position, connect the data cable firs and then power up the bass module. Then you should see the bass module blink green twice and once you turn on the nedia center, the green blinking should turn steady green. That should sort out your problem.
Also do note tha this procedure applies only to Series II Lifesytle System and does not include the Series IV (with the smaller bass module).
If all still fails, there is an internal problem with the bass module which would require servicing.
Hope this helps!
Jan 27, 2008 | Bose Lifestyle 18 System
RTO Oar Sockets Logo
486 people viewed this question
Top RTO Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a RTO Boating Expert? Answer questions, earn points and help others
