Question about GE GSS25JFM Side by Side Refrigerator
Freezer still icing up
We replaced the defrost heater and the freezer is still icing up. What else could it be?
    President:
  • 1,865 Answers
Thermostat or possibly bas seal
Posted on Apr 15, 2009
  • 57 Answers
Frost and ice is formed usually from humidity intrusion from OUTSIDE the freezer cavity.
Take a standard piece of 8 1/2 by 11" piece of paper and close it into the door. It should not be easily removed. Continue this process all the way around both doors. Should the paper be easily removed at any point, then this is the problem, bad door seals.
Question at this point is... Were the doors ever removed? Check the door brackets. If when you lift on the door handle(s) and the door shifts, the brackets may need tightening or the associated hardware in them may be worn from use and may need replaced. The "Thimble" is the part to look at physically to see if it is worn. It acts as the "weight bearing washer", so to speak, between the door and it's hinge. (See web page >>HERE<< for replacement part numbers and parts breakdown) IF the hardware seems in tact and tight and there is a noticeable deformity in the gasket, it may need replacement, and in some cases, both gasket and hinge.
The replacement and or inspection is a 2 person effort to check out effectively. Doors are heavy, and a little help with a 2 by 4 board under the door aids in both alignment of the doors, removal, and to check for loose hinges. WARNING: if you do have to replace the door gasket or hinge, take into consideration if you have an icemaker and/or chilled water unit in the door - as these devices will need to be turned off and disconnected before any door removal. also: When checking for that loose hinge with a 2by4 DO NOT apply too much downward pressure as this may damage the hinge and associated hold down bolt(s). Simply place the board under the hinge, and a block under the board out on the floor as a fulcrum and GENTLY press down to see if the door hinge has "give" or as an aid in tightining related bolts on the hinge, or for inspection and replacement of hinge and door parts.
As mentioned, large accumulation of frost and ice usually comes from outside the unit. If your defrosting heater is functioning correctly and "cycles" normally, the only two causes are the gaskets and alignment, or someone indecicesive as what to have to eat.
We are here to answer anything about everything - If this has helped, Please inform us with a check in "FixYa" if it has solved your pronlem, Even if you did not originally post it! If this did not help, Post a clarification of your problem and we'll get back to you!
Hope this helps
Len
  • Len Falk
    Len Falk Apr 15, 2009
    This I should have added first - The fix all of fix all's is DUCT TAPE! To see if it is an intrusion of humidity around the door. Turn off the unit. Remove the ice by removing refrigerated and frozen items and remove the frost and ice using an electric hair dryer being careful not to place too much heat in any one area for too long - This may warp or damage any plastic if you do. After the unit is dry and free of ice, place the duct tape on the OUTSIDE of the door gasket all the way around each door. Make sure the tape does not overlap on double doors and that it seals. Check to see if it ices as bad with this in a day or two. If not, then you KNOW it's the seals/hinge. If it does, it is possible the humidity MIGHT be coming from a bad grommet on the ice maker / chilled water unit if so equipped, or from another point. It is possible that the defrost cycle timer is not functioning. The defrost cycle timer "usually" turns on for a few minuets after a compressor cycle finishes, but at that point you may consider a qualified technician to see if this is so.
    Len
  • 3 Answers
Make sure the fan is working.
I have a problem with my s75438dt,the fridge as stopped working
If defrost heaters in freezer stop operating during defrost cycle, ice builds up around coils and blocks cool air from being blown to refrigerator side. If ice you need to defrost with heat and replace heaters. Remove rear freezer wall and look for solid ice covering coils. Also push freezer door switch closed while keeping door open and determine if fan is working.
Feb 06, 2016 | Refrigerators
Tip
Refrigerator not cooling-freezer section icing up
Refrigerator not cooling, ice forming on back of side-by-side freezer:
Turn off unit. Empty freezer section. Remove freezer back panel (4 screws) to expose iced-over coils. Use a fan to speed up defrosting. Put a towel or a plastic drip pan in the bottom of the freezer to collect melting water (rather than letting the water collect and maybe overflowing in the drip pan underneath the refrigerator).
After defrosting, by temporarily replacing the freezer back panel and turning on the unit, the refrigerator may operate OK for about 3 weeks before the next excessive ice build up.
Possible problem- a burned out Defrost Heater.
To check: After defrosting, turn off power to or unplug the refrigerator.
Unscrew the Defrost Heater bracket (2 screws). When loose, unplug the two wires connected to the unit. Have the unit checked, or use an ohm-meter to check continuity. If unit measures "open", high resistance, replace the Defrost Heater and bracket. If the heating element shows continuity (or low resistance) the heater is probably OK and you have another problem. Now you may need to contact a repair man.
on Jul 06, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
How do i replace the heater on a maytag RSW22E0D side by side?
Place all frozen items that are inside the freezer now into a ice chest. Unplug the power cord from wall receptacle that goes to the refrigerator. Place a few towels inside the bottom section of freezer to absorb any water that overflows the freezer floor during manual defrost. Place a bucket of very hot water inside the freezer and close the doors. Give the freezer time to warm up and melt the ice behind the rear wall of the freezer. Click HERE RSW22EOD Freezer Parts Breakdown to view the freezer components. Remove item #20 in that photo to expose the=> 61001846 Defrost Heater Elements The 61001846 Defrost Heater Elements can be seen as item location 20 in this photo=> HERE It may be a good idea to change the 52085-29 Defrost Thermostat It's just easier to get to while replacing the defrost heater elements. I am here if you have questions, John Tripp Appliance 911
Contact me here.
Jun 22, 2014 | Maytag MBB1956GES Bottom Freezer...
GE GSL22JFTABS Frost buildup on back wall of freezer and ice maker not making ice
Your unit is not defrosting, causing the unit to build up ice and not allow the air to flow. There are 3 possibilities, listed with the most likely first.
1. The DEFROST HEATER in the freezer section, just behind the cover along the back wall of the freezer.
2.The DEFROST BI-METAL which is just about the HEATER, it is a small round thermostat that keeps the HEATER from getting too hot
3. If both of those parts are good, then you have a bad MAIN BOARD. The board regulates the defrost cycle, which replaced the older defrost timers.
May 20, 2012 | GE Refrigerators
The freezer is iced up. Is there only one temp control for fridge and freezer
If the freezer is iced up, this is a clear indication that the defrost heater is not working. Either the defrost heater or the defrost thermostat is bad. If in doubt, replace both of them.
Dec 17, 2010 | Kenmore 3.7 cu. ft. Compact Refrigerator
My Jenn Air Model No# JSD2789DES Refrigerator does not stal cold and freezer is not freezing anything...I noticed in the back of freezer the wall was covered in ice. It was working fine the other day...
Ice building up in the freezer is not good, it means that your defrost heater is not working.The purpose of the defrost heater, as the name implies, is to prevent ice from building up on the evaporator that is inside the freezer compartment. The heater and/or thermostat failure is responsible for the ice building up in the freezer. Replacing both of is recommended, but if the heater shows continuity with an ohmmeter, just replace the thermostat; if in doubt, replace both of them and your refrigerator should be back to normal. Do not forget to clean the refrigerator condenser fins.
Dec 12, 2010 | Jenn-Air Refrigerators
Ice building up in freezer
Due to the frosting up, The glass defrost heater broke. Any good tech knows this happens. The defrost heater must be replaced. If this is a GE side by side. The new replacement heater has dual elements. The standard heater that was put in them, was not large enough to defrost the coils fully. Replace heater and you should be fixed up. I would also replace the thermostat while you are in the freezer section they are only like 15 bucks and this way you will have a new defrost circuit.
Jun 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
unplug appliance, melt ice on back of freezer, remove panel rear of freezer, find leads to defrost heater and test with a multimeter, if you have condinuity replace defrost termostat, if no condinuity replace defrost heater. after removing panel you will have to melt ice in rear with heat gun before testing.
Jun 22, 2009 | Admiral Refrigerators
GE GSS25WGMCC, Ice Forming On Freezer Interior Surfaces
i had the same problem and i replaced the defrost heater and it worked fine for about one month but now having the same issue. Most of the time from what I have heard it is the defrost heater (about $60 part). I might have another issue going on with mine like a defrost thermostat. Your defrost heater is right under the panel on the inside of the freezer section. remove white panel on back side of freezer section and remove two screws and two wires and replace it and you should be fine.
Apr 15, 2009 | GE Refrigerators
Refrigerator freezes up
PLEASE DISREGUARD GUEST FIXYA SOLUTION,FREEZER PROBLEM PROCEDURE IF NOT DEGITAL,FIRST CHECK IF ICE ON BACK FREEZER WALL. STEPS-FIND DEFROST TIMER,BOTTOM FRONT ,BOTTOM BACK, INSIDE FRIG.ON CONSOLE,LISTEN TO SEE IF FAN IS RUNNING IF SO TURN THE DEFROST TIMER CLOCKWISE TILL YOU HEAR A CLICK SEE IF FAN TURNED OFF IF SO YOUR FREEZER IS IN DEFROST,FREEZER WILL COME OUT OF DEFROST IN 20-30 MINUTES IF IT DOES AND THE FAN COMES ON YOU HAVE ELIMINATED DEFROST TIMER&FAN,NEXT REMOVE BACK PANEL TO FREEZER IF THERE IS ICE FORMING REMOVE BOTH LEADS TO HEAT AND CHECK WITH VOLT METER ON OMES,IF YOU GET ANY READING THE HEATER IS GOOD,IF NO READING REPLACE HEATER AND CLIPON TEMINATOR,IF HEATER IS GOOD DEFROST COILS WITH HAIR DRYER TOP TO BOTTOM AND THIS WILL ALSO CLEAR THE DRAIN,IF EVERYTHING CHECK OUT GOOD DEFROST TIMER ,FAN ,HEATER, DRAIN, YOU NEED ONLY TO REPLACE THE LITTLE ROUND CLIP ON TERMANATOR,LET ME KNOW-MIKE
Oct 13, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE GSS25JFM Side by Side Refrigerator Logo
286 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
