Question about Acer Computers & Internet
Vista desktop won't connect to internet cable modem eithernet
Had wirless network set up was working fine for months somthing got changed and now desktop which is wired out of dir 655 router willnot connect to internet diconected everthing and tried just using cable modem to desktop it will only connect through usb and will not go through ethernet port the router won't accept the modem to to usb connection and wants it to go with either net cable
i hit the reset button on the router and now laptop is saying the network does not exist it does pick up the network just as d-link
tried just reconecting as it was and reinsatalling software from router and it can't restart the net work if connected to desktop through eithernet and if trying usb it says inncorrect router
    President:
  • 1,865 Answers
Power down cable modem, router, and computer. Connect ethernet cable from modem to router/ and connect ethernet cable from router to PC. Power up cable modem first, after modem shows connectivity, plug in router. After router shows internet connectivity, start computer. Be sure that you LAN card operable
Posted on Apr 15, 2009
Can get router to connect to Internet
Cathy, your router does not connect to the internet, your modem does. Are you trying to use wireless, or is it hard wired like using an eithernet cord? If so then make sure the eithernet cable is hooked up properly and that it is goodIf it is good then try to connect your modem directly to your computer by using the eithernet cable. If that works then you know that the signal from and too your computer is working properly. Next go to your control panel and open network and sharing center. Go to set up a new connection. If that doesn't work then you might suspect a defective router. By the way has it worked before or is this a new setup?
In order to help you through this you need to be more specific with what is going on with your system. What brand of router is it? Depending on what brand there is a web address you can use to be able to access your modem.
Good luck,
Marty
Jul 19, 2014 | Computers & Internet
Windows vista crashed. changed bios to load xp. worked. old files on hidden drive. problem is cant connect to internet. driver files on hidden drive. Now what? Try to find driver and load it?
your explanation is very confusing. your internet connection must come from a modem either directly or remotely thru router. your mentioning of hidden drive does not make sense. drivers are not part of internet connection. you need to reset the modem and router if you are connecting through it. turn everything off. unplug router and modem. after 15 seconds unplugged, plug only modem in, wait until lights stablize; now plug router power back in, wait for lights to come on;,next turn PC on. Wait until completely booted up. go to control panel click on Network Internet, when opens try to find the local connect to network. if none, then your modem is not receiving signal or IP Address from your internet provider(comcast,centurylink, whoever). check status, if active fine. if active but icon says no internet access then your router is not set correctly. you may have lost its set up and you will have to reset up your router. you should have the step or instructions for doing that. after resetting and network active, restart computer so that is receives fresh settings from router.
if no network is found after restart you may have to reconfigure your internet connect by using the internet connection wizard(control panel).
Sep 27, 2012 | Dell Dimension B110 PC Desktop
Just got a new linksys e3000 router. all other laptops working fine except one toshiba with vista. i have another toshiba with vista that is working fine also though. it will connect wirlessly if i disable...
You have to update the wireless adapter driver on the toshiba website. I'm guessing you have an Atheros adapter because those usually have this problem. The driver is not advanced enough to log onto a WPA or WPA2 encryption, WEP will work fine. The driver updates have a 50/50 chance of fixing the problem otherwise you are stuck with WEP.
Jan 11, 2011 | Linksys E3000 Wireless Router
I'm trying to connect dsl directly to my laptop - but when I connect the eithernet cable from the dsl modem to my laptop it says there is no internet connection??? The dsl cable works fine with my...
Maybe the laptop is configured by default to look for a wireless signal through its wifi drivers, or a different previously installed modem. Go to your Computer/Control Panel/Network Sharing Center and set up a new connection there so your computer knows what to do.
Nov 02, 2010 | Dell (0E828) for Latitude C610 Modem
Router -> Modem Connectivity: I am fine if I'm hard-wired to the modem but if I connect wirelessly through the router I can't get WAN. I can get the modem page wirelessly. This just started tonight. I...
Have you check your DNS settings within your Wireless Network Adapter TCP/IP properties settings? Or it may be a proxy server or firewall settings wich may block internet access to the internet. Try testing it with your LAN cable first and see if you are able to connect to the internet using that cable from the laptop/pc to the modem. If it works using the network cable then it might be a DNS related issue on your wireless network adapter tcp/ip properties.
Jul 29, 2009 | Belkin (F5D5231-4) Router
I have a Linksys router and it really dosn't tell me a lot about hooking it up! Can anyone help? MDL# EZXs55W It is a five port. The tech connected the cable and the eithernet cable to the modem. I tried...
Great !
But if you have trouble installing the cd, follow these instructions:
Router setup
You do not have to use the cd.
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 13, 2009 | Computers & Internet
Loss of internet connection to desktop with WRT 160 N
If you do this and post the results I can tell you how to configure the router as you do not need the domain:-
1. connect to modem with an ethernet cable, without the router
2. assuming it's windows, start --> control panel --> Network Connections --> double click on the Local Area Connection --> Click details and post ip address, subnet, default gateway and both dns servers
Jan 20, 2009 | Linksys WRT160N Wireless Router
Wanting wireless hookup
1)Prepare your modem. Unplug the modem's power cord and place the wireless router unit next to the modem. If the router has antennas, make sure they are raised to their full upright position.
2)Reassign your networking cable. Unplug the cable currently connected from your computer to your modem and plug it into the port located in the wireless router. This port is usually colored blue.
3)Connect the router and the modem. Use the networking cable that came with your wireless router to connect the modem and router unit. The router port is typically colored in green.
4)Start up your modem. Plug in the modem's power cord and wait 1-2 minutes while it configures its settings and prepares to connect to the Internet.5
5)Start up the wireless router. Plug the wireless router's power cord into an outlet and wait 1-2 minutes to get it started. The router is ready when the 'wired computers' and 'modem' icons light up. These logos or icons vary by make and model of your router so consult the owner's manual if needed.6
6)Insert your installation CD. Use the wizard or assistant to check the configurations of your computer settings and launch your wirelessnetwork clip_image001.gif
Things You’ll Need:
  • Wireless Router unit
  • Networking cable (comes with router unit)
  • Installation CD
  • Modem
  • Modem power cord
Dec 02, 2008 | D-Link DI 713p (DI-713P) Wireless Router
Cannot maintain wireless connection
Try manually add the network. If the problems continue, I would turn the laptop in for repair/replacement (if it under warranty).
May 15, 2008 | HP Pavilion dv9730us Notebook
Losing internet connection when I try to connect laptop to wireless router
Your cloning the mac address - thats the problem. It should use it's own mac address to connect to the modem. You need to power down the modem, then repower after a minute or so to let it connect to the new mac address. The problem you are seeing is due to network collisions betweenj the desktop and the router with the modem.
Nov 29, 2007 | Belkin (F5D7230-4) Router (587009)
Computers & Internet Logo
928 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
