Question about Logitech 250 Headset
Conversion of usb to RJ9
I need to convert from a USB end connection point to a RJ9 . Is this possible by cutting of the usb and inserting an RJ9 ?
  • adam_halpern Feb 15, 2009
    need to connect Sennheiser VMX 100 to PC via USB
2 Suggested Answers
ScottSwan
  • 33 Answers
SOURCE: USB ripped off
Here's one
Posted on Feb 16, 2008
How do I connect the mouse?
212
i am assuming you have a usb mouse and a PS2 connection on the computer. If this is the case then you need a female usb to ps2 mouse adapter
So that the mouse cable plugs into the USB female connection and the male ps/2 plug end goes int othe female ps2 port on the computer.
If this is the case you have the wrong converter the chester will convert a ps/2 on the mouse or keyboard to a usb on the back of the computer.. Can you tell us what sort of mouse you are trying to connect does the end of the cable have a usb plug on it a bit like the blue usb plug in your picture.
Google it and see the difference.
Mar 12, 2015 | Chester Creek PS/2-USB Converter PS/2 to...
Tip
How to convert 220 volts to 110 volts for the iPod Touch
<p> <p>The battery of an iPod Touch prepared for use in the United States is designed to be reloaded from the current supplied by a 110-volt electrical system. Power is transmitted to the battery charger with an iPod battery, which are connected via a USB cable and then connected to a 110 volt outlet. To use the power of a 220 volt outlet with an iPod Touch, set the current 220 volts to 110 volts. A conversion adapter voltage, also known as "Step Down Transformer," it is necessary and can be obtained from an electronics store, a hardware store and even some drug stores. <br /> <p><br /> <p>1. Place the 220-110 voltage converter card (aka, "Step Down Transformer") next to a 220 volt outlet. Plug the adapter into the outlet. <br /> <p><br /> <p>2. Connect the end of a USB cable to the USB connector USB iPod charger iPod. Connect the other end of USB cable into your iPod's own socket on the bottom of the iPod Touch. <br /> <p><br /> <p>3. Plug the iPod into the 110 volt outlet in the battery adapter for the iPod Touch. <br /> <p><br /> <p>4. Unplug the charger from the iPod adapter and the adapter from the outlet when the battery is charged. Unplug the USB cable from the iPod charger and iPod Touch. <br />
on Aug 09, 2011 | Apple iPod touch
Ipod touch pa623ll
You can add video content to your Apple iPod and watch movies on its screen.
Video syncing is controlled by the iTunes application, which then sends the movie files to the iPod's hard drive.
The iPod supports a variety of video formats, and iTunes can convert other files that are not supported.
Plug the iPod USB cable into the bottom of your iPod.
Connect the other end of the iPod USB cable into a free port on your Mac or PC computer.
Open the iTunes application by clicking on the Dock icon on a Mac or using the Start menu on a PC.
Go to the "File" menu and select "Add to Library."
Navigate to the movie file you want to transfer to your iPod and click "Open."
Click on the movie you just added to iTunes, go to the "Advanced" menu and select "Create iPod or iPhone Version."
This will convert the movie file to a format that the iPod can play.
Click on the name of your iPod under the "Devices" list on the left side of the iTunes window.
Go to the "Movies" tab and choose to sync all movie files with your iPod.
Click on the "Sync" button at the bottom of the iTunes window.
The syncing process will begin and the movie file will be transferred to your iPod.
Transfer DVD Movies to an iPod
Transferring DVD movies onto your iPod for personal on-the-go viewing depends on the exact type of DVD you are using.
Some DVDs are in a format that can easily be transferred to iTunes, which can then convert the movies to a format for the iPod if needed.
If the DVD can't immediately be played in iTunes, you will need extra software to convert it before you can transfer the movies to iTunes and then to the iPod.
Load the DVD into the computer's disc drive and open up both the DVD in a window and your iTunes application.
Drag the DVD's main movie file into the main iTunes window to add it to your personal iTunes library.
Connect the iPod to the computer with its USB cable if it isn't already connected.
If it is already connected, or if the iPod does not automatically sync with iTunes, drag the DVD movie file from the library list to the iPod shown in the iTunes source list.
Convert the movie file to an iPod friendly format if you get a message saying the file can't be played on the iPod by selecting "Convert Selection for iPod" in the Advanced menu.
Please note that this conversion can take some time--five to 10 minutes for every two minutes of video.
Conversion Software
Download and install a DVD conversion program to your computer; look for one specifically designed for converting DVD to iPod if possible.
Open the conversion program on your computer and upload the DVD movie file into the program with the "Open" or "Upload" option.
There should be multiple files on the DVD; the actual movie has the longest run time.
Select the format that the file will be converted to from the program's drop-down list of available formats if the program is not automatically set for an iPod format. If an option specifically labeled "iPod" isn't available, choose an MP4 format.
Choose a location on your computer to save the converted file to using the program's "output" option--the desktop is the most common and easiest location.
Click on the conversion button, which is usually the biggest button located in the lower right corner, to convert the file and save it to your computer.
Open up the iTunes application and drag the converted iTunes or MP4 file into the iTunes library.
Connect the iPod to the computer using its USB cable.
http://www.dvd-ipod.biz/guide/cucusoft_dvd_to_ipod_guide.html
Jul 24, 2013 | Computers & Internet
Converting audio and vidio from rca conecter on VCR to USB conecter on HP laptop
You need to covert the data from analog (RCA) to digital (USB). Connecting an RCA video / audio to a computer has to go through some software for the conversion.
Jan 10, 2013 | HP Computers & Internet
Can it be used as external hdd
Yes it can be used as an external hdd.
This is the only procedure i know and i hope you'll be satisfied.
Things You'll Need
Screwdriver
Locate and purchase an IDE to USB cable conversion kit. Insert the driver CD that came with the kit into your computer's CD drive. Follow the instructions on the installation prompt that will appear on your computer's screen to install the conversion cable driver software.
Power off the computer once the driver software has finished installing. Remove the power cable and all of the other cords from their ports on the back side of the computer.
Set the entire computer case on its side so that the left side panel is facing upwards. Check the back end of the case to determine if the side panel is locked with two case screws or only a metal latch. Disconnect the panel from the case either by removing the screws or by pulling upwards on the latch.
An IDE Cable
Pull the side panel off of the computer case and set it aside. Locate the drive that you want to connect with a USB cable. Remove the screws holding the drive into the drive bay. Disconnect one end of the IDE cable from the motherboard, but leave the other end connected to the back side of the drive itself.
5
Remove the drive from the drive bay with its connected IDE cable and set it outside of the computer case. Set the side panel back onto the case and re-attach the metal latch or case screws. Plug the cables back into the computer ports and power the computer back on.
6
Insert the end of the IDE cable that used to be connected to the motherboard into the IDE port on the conversion cable. Plug the male USB end at the other side of the conversion cable into any open USB port on your computer.
Have a nice day friend and i hope this would satisfy your needs.
Aug 20, 2011 | Samsung (SP0411N) 40 GB Hard Drive
Telephone line RJ11 jack does not fit into plantronics
The correct connection size for headsets used with S10, T10 & T20 is an RJ9. The jack on the back of the T10 and T20 is an RJ9, this is for the cord that runs into the wall jack. The cord itself has an RJ9 on the end that plugs into the T10 & T20 and an RJ11 connection on the other end that plugs into the wall jack. This cord is supplied with the units.
Good luck from Headsets Direct!
Oct 03, 2009 | Plantronics (45647-04) for S10, T10, T20...
What extra device do i need to transfer photo`s to my sansa?
first off you need a converter program from here
http://www.sandisk.com/driverdownload/download.asp?driverID=184
then install that then
  1. Hook up your Sansa MP3 player to your computer with the USB cord. This cord has one flat end that inserts right into the bottom slot of the player. The other squarish end goes into your computer's USB port.
  2. Choose "Sansa Media Converter" from the options that pop up automatically when you complete the connection to your player. Find media that you want to convert to your MP3 player by clicking on the "Add Media" button in the converter. Once you have the media you want in the box, click "Convert" to convert the media and download it to your player
hope this helps a bit
Sep 25, 2009 | SanDisk Sansa e260 MP3 Player
How can I format my newly bought Seagate 250 GB External Portable Drive into FAT32 system. Are most dvd players now with usb support for divx cannot access external drives that are in NTFS format such as...
You can specify the format type on the option page for format before you press the format button when displaying the drives in "My Computer"
Additionally, you can CONVERT an existing FAT or FAT32 partition to NTFS. Follow the steps below for Windows XP:
  1. Click Start, point to All Programs, point to Accessories, and then click Command Prompt.
  2. At the command prompt, type the following, where drive letter is the drive that you want to convert: convert drive letter: /fs:ntfs For example, type the following command to convert drive E to NTFS: convert e: /fs:ntfsNote If the operating system is on the drive that you are converting, you will be prompted to schedule the task when you restart the computer because the conversion cannot be completed while the operating system is running. When you are prompted, click YES.
  3. When you receive the following message at the command prompt, type the volume label of the drive that you are converting, and then press ENTER: The type of the file system is FAT.
    Enter the current volume label for drive drive letter
  4. When the conversion to NTFS is complete, you receive the following message at the command prompt:Conversion complete
  5. Quit the command prompt.
Sep 21, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Connection to new computer
About conversion cables, u cannot guarantee the outcome specially with these type of printers.
My experience with POS printers, they like straight cable (Parallel on both ends) or (USB on both ends) and direct to computer connection.
Some successfully managed to get it working, mileage varies.
You can buy these type of cables from stores.
May 16, 2008 | Epson TM-T88III Thermal Printer
Logitech 250 Headset Logo
1,063 people viewed this question
Top Logitech Radio Communications Experts
Bharat Das
Bharat Das
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
