Question about Panasonic Panafax UF-585 Plain Paper Laser Fax
Confirmations I am trying to get a print out of a fax my PA sent on 20/08/07. is this possible as I can only get the last 32. Thanks
  • tracymyoung Dec 14, 2007
    I faxed something on 11/6/07, is there anyway to retrieve confirmation that the fax was submitted successfully today?
    Problem Solver:
  • 19 Answers
If it was before the last 32 you can't,have you're PA resend.
Posted on Sep 16, 2007
SOURCE:
How do you program the panasonic kx-fl511 to print fax confirmations sent.
How can i remove call service6 problem on my
Problem with the Panasonic KX-FL511 Plain Paper Laser Fax
Jul 07, 2011 | Panasonic KX-FL511 Plain Paper Laser Fax
I cannot figure out how to get a confirmation receit showing my fax was actually sent. How do I do this? Thank you.
You need to turn on report printing in order to get a confirmation page that shows your fax was sent. to change the settings you press the menu key and then use the arrows to navagate the choices until you see fax set up. Then you press "ok" or "enter". Then use the arrow keys again to scroll the choices until you find reports or confirmations, and then again press ok or enter. Then use the arrow keys to change the reports that print when a fax is sent and save your changes by hitting ok or enter. Then try a test fax to make sure the report prints and your done!
Jun 13, 2011 | Epson Office Equipment & Supplies
How do I print a fax confirmation AFTER I've sent a fax on the HP L7590?
The product can print confirmation reports automatically for each fax that is sent and received.
Printing fax confirmation reports
  • The default fax confirmation setting is Off . Use these instructions to enable printed fax confirmations.
  • Press Setup on the product control panel.
  • Press the right arrow button until Print Report appears on the control panel display, and then press OK .
  • Press the right arrow button until Fax Confirmation appears on the control panel display, and then press OK .
  • Press the right arrow button to select the appropriate option (listed in the following table), and then press OK .
Sep 25, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
What button do I press to generate a Fax report - this is not always generated automatically.
Sounds like your Fax Options are set to print on error only. If you want to have both confirmations and error pages do the following:
1 Press Menu until “Fax Setup” appears on the top line of the display. Press Enter.
2 Use the scroll button to find MSG Confirm. Press enter.
3 It may be selected to On-Err. Use the scroll arrow buttons to get to On. Press Enter.
4 To return to Standby mode, press Stop/Clear.
This should make your fax print out a confirmation on a successful or failure transmit of your fax.
If you want to print out the last few sent or receive faxes:
Printing a Report
1 Press Menu until “Reports” appears on the top line of the display.
2 Press the scroll arrow buttons to display the report or list you want to print on the bottom line.
•Phone Book: Phonebook list •Sent Report: Sent fax report •RCV Report: Received fax report •System Data: System data list •Scheduled Jobs: Scheduled job information •MSG Confirm: Message confirmation •Junk Fax List: Junk fax number list
3 Press Enter. The selected information prints out.
You can find your manual in English by clicking here.
------------------------------------------------------ Please rate this post if it helps you! :)
Dec 08, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Black mark on right side of paper
The scanner is not working properly, not the printer part of the unit.
The LED array is not lighting causing black scanned prints.
Resolder the contacts in the LED array...probaly a cold solder joint.
Feb 17, 2009 | Brother IntelliFAX 4100 Laser Fax
Panasonic Panafax UF-585 Plain Paper Laser Fax Logo
54 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
