Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Kenmore ice maker problem
I have a Kenmore bottom freezer refrigerator.Model no.795-7756 4600 Serial no.610kr00489. The automatic shut off is not working. It keeps making ice until it is full to the top of the bucket then it freezes ever thing up on top of the ice maker. It hums like it's trying to dump but can't move.
The first time it happened I turned off the ice maker dumped the ice & let it defrost. After it defrosted I removed the excess water from the ice tray by soaking it up with paper towels. I turned it back on it did the same thing.
I now have it turned off. I would like to know how the cut off works & what I can do to fix it.
Thanks
Dennis
  • pop_890 Apr 22, 2009
    Thanks for the reply. It seams to be working at the present time. I defrosted it for two days, removed the excess water & moved the limit switch down & let it go back up several times. I would assume from your reply that if I continue to have this problem it would be in the limit switch. Thanks for the help if I continue to have this problem I may need information on how to adjust the limit switch.
    Dennis
  • Kenmore Master
  • 4,655 Answers
I'm not sure in your case if its better to order a new ice maker or if you want to take it apart and change the thermostat or possibly the limit switches. Some have a spring so if you try to do it yourself do it slowly and carefully as not to lose the internal parts. Let me know, I will help you if you need, Sea Breeze
Posted on Apr 19, 2009
  • John Tripp
    John Tripp Apr 22, 2009
    Here is how your model is listed.
  • KENMORE ELITE
  • REFRIGERATOR
  • Model# 79577564600 The replacement Ice Maker is model D7824706Q
  • When I was referring to limit switches and springs these are the internal parts of your Ice Maker They are very difficult to work on if you havn't done one before. Very Tedious, because of all small parts and settings are difficult to set without having done this before.
    If you decide to replace the ice maker please go to (click link below)
    http://servicepartstec.blogspot.com/
    put your ice maker model number D7824706Q in the parts search feature. That will take you to a cost effective replacement.
    I'm not trying to get you to buy. I just think it is the best route for most ice makers.
    I also invite you to Appliance Junk Forum where you can post and read about these appliance problems. Click on link below. Become a member we would love to have your input. Just make sure if you replace, to confirm with the people you buy from that the model of your Kenmore matches the part number of the Ice Maker, Thanks, Sea Breeze
    http://appliancejunk.com/forums/index.ph...
Where is ice-detecting sensor located in the bottom freezer refrigerator? No ice/water in door, only in freezer (Kenmore)?
On the side of the icemaker, there is a wire bale or arm that is pushed up by the accumulating ice that shuts off the icemaker.
Oct 01, 2014 | Kenmore Refrigerators
How do get the freezer slider door out
first shut off water to it then unplug it till it warms up enough to melt the ice that's got it stuck shut be prepaired to clean up a mess it has happened to me
Aug 21, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
How do I find out the model number of my Kenmore elite Fridge
Since the freezer is icing up there could be many different problems a blockage or a problem with the defrost or timer of the unit if u greeting unit number is should be on inside of the door or back by the condenser best bet from what I see is get a tech to fix it they will find all those numbers that u need
Dec 11, 2013 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker not working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
fdfdfs43
Apr 19, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I need a repair manual for a kenmore automatic icemaker
we always replace the unit we not open it b/c there are very small parts that might get damage its 122$ but if u want to try take the whit cover and open 3 screws then the unit open and the arm can be change make sure u put all together correctly...good luck
Dec 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Icemaker not working on a Kenmore Bottom Freezer
if the volve behind the fridg for the ice get 120v for short time when the ice maker ask for water then the volve is bad but if there is no 120v to the volve then the command not coming from the ice unit and it need to be change , the wholl ice maker unit :(
Dec 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker not hooked up (on purpose). The ice
Sounds like you are not going to use the automatic icemaker, so I would remove the whole icemaker unit which will include disconnecting the wire harness behind the icemaker which will shut off power to the icemaker and will also give you more storage room in your freezer compartment.This will not harm the refrigerator or the icemaker, you could also disconnect the waterline if you want.Please note that this solution applies to the top freezer,and bottom freezer style refrigerators only thatt DO NOT have dispensers through the door. Good luck !
Dec 02, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
I have a one-year-old Kenmore Elite Trio 25 with an automatic ice cube maker in the bottom freezer. The unit makes ice just fine, but appears to fill the bin too full. When I pull the bin out to retrieve...
this particular model comes with an adjustable swing arm for ice prduction
pu the swing arm on the 2nd to last click
in the down direction
all the way down is off
Oct 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore - over under
Adjust the feet to raise the front of the frige, which should be higher than the back. Therefore the weight of the door will keep it shut or at least cause it to shut itself if it pops open.
Jul 08, 2008 | Kenmore 62832 / 62834 / 62839 Bottom...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
1,195 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
