Question about GE WWSE5200B Top Load Washer
It washes but will not spin
WJRR4170GWW is the model and it is less than 2 years old. It washes but will not spin.
After having a similar problem and looking all over this website, I found a lot of answers from "experts" saying that the washer should be replaced, or replace the motor, etc.
I just found this at the GE website, and it cured the problem in less than 2 minutes. I'm no expert, but I'd at least recommend trying this.
http://www.geappliances.com/search/fast/infobase/10013033.htm
Posted on Jun 09, 2009
I found a site that gives you diagnostics and how to fix them, without the purchase of parts... believe it or not, it does work.
http://www.appliance-repair-it.com/GE-washer-repair.html
Posted on Apr 19, 2009
    President:
  • 1,865 Answers
The timer controller is usually the problem, replace the timer
Posted on Apr 15, 2009
It seems like our washing cycle goes all the way through to drain/spin without fulling draining or spinning - we have fabric softener left in the dispenser and the clothes are - particularly at the bottom...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 27, 2011 | General Electric WJRR4170GWW Top Load...
Brand new GE washer only 2 yrs. old stops agitating and spinning. Model #WBBR3NOG2WW. Any help provided would be greatly appreciated.
Probably a bad timer/module control assembly. It works for a short time then the metal contacts get hot and "open up". The timer control mod is what's behind the big knob. About $90.00.
Nov 01, 2010 | General Electric WJRR4170GWW Top Load...
Agitator not moving, how do I get it open to check the belt?
My machine is not agitating, I already have had one repair before it was a year old they replaced the agitator, any suggestions how I can get it going again with out a major repair cost?? ugh!
Aug 18, 2010 | General Electric WJRR4170GWW Top Load...
Front loader won't balance on spin cycle. thumps and walks almost every time. Spins ok if empty. This is a new problem (last month or so). Machine is less than 2 years old. Maytag model MAH2400AWW...
The problem may be you might be cloths will be less quantity kindly check the cabinet of the unit and the upper spring is be elongated kindly replace the spring before that check the cabinet any revit has been cutted off
Dec 24, 2009 | Washing Machines
Washer fills and drains but won't aggitate or spin
Seven flashes means the washer did not sense a lid opening. Check the lid switch.
May 30, 2009 | General Electric WJRR4170GWW Top Load...
Since the washer is less than an year old it must be under a warranty.Try contacting the customer care and get it replaced.
Generally for such a problem,the following checks need to be done.
* Test the lid switch
* Test the timer control
* Test the centrifugal switch
* Test the water level switch
* Inspect the motor coupler
* Inspect the drive belt (belt drive only)
* Inspect under the washer for soot (clutch)
* Test the motor
* Inspect the pulley
* Test the transmission
In your case I would advice to get your machine replaced with a new one.Good luck,Please do rate the solution if accepted.
Apr 10, 2009 | General Electric WJRR4170GWW Top Load...
Top loader stops and will not drain
sounds like the lid switch. if you have a hole that the lid finger goes in stick a pencil in it and turn it to spin if it spins replace lid switch finger not making contact. if you dont have a hole then try to tighten the screws on the side of the lid.
Jun 23, 2008 | Whirlpool Washing Machines
GE WWSE5200B Top Load Washer Logo
520 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
