Question about Intel Desktop Board D815EEA2 (BOX815EEAA2) Motherboard
Keyboard when computer start no error .but key board halted.and not working. but, keyboard ok no problem
  • kashifa Sep 17, 2007
    NO USB KEYBOARD,KEYBOARD IS PS 2,AND KEYBOARD ENABLE IN BIOS SETUP.ANY OTHER KEYBOARD SAME PROBLEM.BUT KEYBOARD DETECT IN SETUP AND DIVICE MANAGER
This is your m.board problem .keyboard port is not working
Posted on Jun 13, 2008
    Sergeant:
    Champion:
  • 293 Answers
Is this a usb keyboard? if it is enable it in the bios.
Posted on Sep 14, 2007
SOURCE:
Acer laptop gets hanged every time it is opened. on dignosis it shows code 0211= key board error.pl advise
Try this:
  • open BIOS
  • Look for HALT settings
  • Change settings of HALT ON ALL ERRORS to HALT ON ALL ERRORS EXCEPT KEYBOARD
  • Wait for windows to boot then try your keyboard again
Oct 19, 2010 | Acer Computers & Internet
My HP48Gx has a problem with the last keyboard column(F L R X arrow / * - +). It stops working and if you shake it then it will work again. Any ideas?
Warning
In the keyboard test (below), make sure the keys are pressed in the right order. If the calculator fails the keyboard test then it needs repairs. (Ignore the beginning of the post and skip to the last part For Repairs )
You can reset the calculator:
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the diagnostic tests.
Make the calculator perform a
Self test.
  1. Turn calculator on
  2. Press and HOLD the key [ON]
  3. Press and release the key with "E" to its right (the one before last in first row)
  4. Release the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterward you should see
IROM OK,
IRAM OK,
HP48GX OK
The self test will continue repeatedly until you perform a
System Halt
  1. Press and HOLD the [ON] key
  2. Press and release the "C" key
  3. Release the [ON] key.
The empty stack should appear.
If you do not see IROM OK and IRAM OK, the calculator requires service.
If the above procedure is successful, you may want
to test the keyboard.
  2. Press and HOLD the [ON] key
  3. Press and release the "D" key.
  5. Press and release the "E" key. KBD 1 should appear on the top left corner of the screen.
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a high pitch sound at each press.
  7. If everything is OK, when you press the last key (+) the screen displays KBD 1 OK.
To exit the keyboard test proceed as described above under System Halt.
If you follow the proper sequence and a hexadecimal number appears after pressing a key, the calculator requires service.-
For repairs
You can also try this site. They do repairs on most models, except the newer ones.
Feb 04, 2010 | HP 48gx Calculator
The 7, 8 and 9 keys do not work on my 48sx. The
In the keyboard test, make sure the keys are pressed in the right order. If the calculator fails the keyboard test then it needs repairs. (Ignore the begining of the post and skip to the last part For Repairs )
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the dagnostic tests.
The following procedure valid for the 48G should work for the HP48GX.
Self test.
  4. Relaese the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterwards you should see
IROM OK,
IRAM OK,
HP48GX OK
System Halt
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a hight pitch sound at each press.
For repairs
There is an HP customer self repair (CSR) which you can contact. On the site it is sais that the service is available for products under warranty or on contract. but you have nothing to lose by contacting them. Here is the link to the web site
Nov 17, 2009 | HP 48gx Calculator
I just changed the battery in my HP 48GX that I haven't used in some time, but the alert symbol is on and nothing else is happening
The following procedure valid for the HP 48G should work for the HP48GX.
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Nov 07, 2009 | HP 48gx Calculator
The calcutor doesn't turn on from the first time. It takes too long to turn on and at random. Also the soft keyd don't work. I try to set the modes but when I press shoose nothing happens.
The following testing procedure valid for the HP 48G should work for the HP48GX. If any the tests fails the calculator requires service.
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Sep 23, 2009 | HP 48gx Calculator
Have a 48GX that stopped working, placed new doubleA batt no response... Note a wird meshed blue line at the center of the screen... Thx jsd
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Sep 15, 2009 | HP 48gx Calculator
Calc. asks to recover memory, display goes blank, keys beep
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Aug 04, 2009 | HP 48gx Calculator
The #3 key sticks and won't show on the display
Try the following procedure (valid for the HP 48G should work for the HP48GX.) If any of the tests fails the calculator requires service
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Jun 30, 2009 | HP 48gx Calculator
I have one intel 845gvsr board for repair. The board is dead. When RAM is removed it gives memory error beeb i.e. 3 long beeps, but RAM is ok & cpu is also ok. When is installed the board does nothing. No...
Hi there
Three Long Beeps = Keyboard/Keyboard card error
An error with the keyboard can be caused by any of the below possibilities.
  1. Keyboard is not connected properly.
  2. Stuck key
  3. Bad keyboard
  4. Bad PS/2 or AT port
Solution:Keyboard is not connected properly
Verify that the keyboard is connected properly to the computer by turning off your computer and then disconnecting and reconnecting the keyboard to the computer.
Stuck key
Ensure that there are no stuck keys on the keyboard. If all keys appear to be ok and you have a standard desktop computer with keyboard, attempt to turn keyboard over and gently hit the back of the keyboard to loosen any dirt or hair that may be stuck in the keyboard.
Bad keyboard
Try another keyboard on the computer to verify that the keyboard has not gone bad.
Bad PS/2 or AT port
If all of the above solutions are not able to resolve your issue it is likely that the port on the back of the computer may be bad and the motherboard or I/O board may need to be replaced.
Good luck and kind regards
Jan 05, 2009 | AOpen XC Cube MZ915M (95MZ1592Z1) Barebone
Compaq evo d500 won't start up and won't let me access boot menu. just keeps saying keyboard fault even when another keyboard is used
press f10 during startup , when the bios open, look for the setting "halt on" . it will have a choice of keyboard, all errors or no errors , set it on "no errors" save and reboot. that may fix it.
You could also get another keyboard (neighbors or a new one) and test to see if a new keyboard solves the issue without recovering your system.
you can also use the recovery CD that came with your system:
USING THE RECOVERY CONSOLE TO REPAIR DAMAGED
FILES
If you cannot start your computer, you can run the Recovery Console from operating system CDROM
provided with the PC. To run the Recovery Console from the operating system CD-ROM:
NOTE: Make sure that the system is configured to boot first from the CD-ROM drive, then from
the hard drive. You can verify or change device boot order using the Computer Setup (F10) Utility.
For more information, refer to the Computer Setup (F10) Utility Guide provided with the
computer.
1. Insert the Windows 2000 or Windows XP CD-ROM into the CD-ROM drive.
2. Click Start > Shut Down, then select Restart from the drop-down list.
3. In the Shut Down Windows dialog, click OK.
4. Press any key to start the computer from the CD-ROM drive when you are prompted to do so.
5. On the Welcome to Setup page, press R.
6. Choose the installation that you want to access from the Recovery Console.
7. Type the administrator password. If the administrator password is blank, press the Enter key.
Oct 17, 2008 | Compaq Evo D500 PC Desktop
Intel Desktop Board D815EEA2 (BOX815EEAA2) Motherboard Logo
53 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
