Question about SNK West Coast Customs WCC-6004 Car Amp
Orion wcc-6004 it has a burning smell how can i fix this issue?
    Problem Solver:
  • 15 Answers
Turn it down your burning out the internal battery from crankin it to loud also check ground to make sure theres good connectivity
Posted on May 22, 2009
When I drive my 2005 ford escape I sometimes smell something burning?
Either it is due to heat from engine I.e. burning dripped oil or clutch issues.incorrect use of clutch I.e. Slipping it or resting foot on it will cause the clutch fluid to burn and waft into the car interior.i once had a burning smell issue that was due to a bin liner getting stuck underneath the engine which caused it to melt and emit a terrifying smell that caused a few days of anguish.
May 05, 2015 | 2005 Ford Escape
Marantz pm 6004 blikining red power standby
Are the speakers connected?
If so , you have an output DC voltage issue ( typically outputs dont want to see more than 100mV DC going to the speakers. If that happens , the Protect circuit will kick in. Find a repair tech in your area because I think this amp is worth fixing
May 21, 2014 | Marantz Audio Players & Recorders
Burning smell after i replaced lamp
have a expert examine the set to make sure there is no safety issue here and if not the set may have got some plastic so hot that is what you are smelling.
Apr 04, 2012 | Samsung HLP6163W 61" Rear Projection...
My orion 6004 amp was connected, but it didn't turn on, so i was going to disconnect it and smoke came out from wire connections, i opened and i didn't find a solution Can you help me with it?
you had a short circuit.... you need to check the fuse of your amp if it is blown then replace it.. otherwise replace the cable if it is burnt and check your amp carefully
Aug 01, 2010 | Orion Car Audio & Video
Burning and fan type sound
That is probably the power section about to fail. The burning smell is going to be from overheating components. You will have to take it into either an akai repair depot or a local tv repair and have it looked at. Get an estimate first. The repair cost on this could be cheap if itis obvious and the repair gys are on the ball or it can be pricey if they just replace major parts (typical). Also have a good idea of what replacement cost is so you know if it is worth fixing.
Jul 20, 2010 | Akai LCT42Z6TA 42 in. LCD Television
I have Hoover Widepath Bagless 12 Amp Windtunnel vacuum. Yesterday I was vacuuming and smelled smoke and it shut itself off. Today I cleaned out the filters (they weren't bad) made sure nothing was...
Hi There,
When a vacuum cleaner smokes, it is usually only one of two possible problems.
It could either be that your motor burned up, or that your belts burned. The belts on this particular model are notorious for breaking, but the fact that your machine doesn't come on at all after this happened, sounds like it may be the motor.
Both of these issues have a unique smelling smoke. If the smoke smelled like an electrical burning smell, this indicates it's your motor. If the smoke smelled more like burning rubber, then it's probably your belts.
If the smoke smelled like burning rubber, here's a video that we've recorded showing step by step how to inspect, trouble shoot, and replace the belts on your vacuum cleaner. If you open it up and the belts are still in tact, then this probably is a more serious problem of the motor burning out.
. I'd be more then happy to walk you through more advanced diagnosing if this doesn't fix your problem, please just use the comment box here on the Fixya repair page.
If this was helpful to you, please be so kind and rate my repair helpful, or leave some feedback for me. This is really appreciated by the Fixya community if the repair solution was able to fix your problem.
Thanks again,
Chris Jones
GoVacuum.com
Jun 14, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Screen distorted and burning smell
Those dead resistors that the cause,u are smelling burning plastics.Try website Tvrepairworld.com to buy a whole convergence board for the replacement.The Samsung/Akai are using the same convergence board.
Jun 06, 2010 | Akai PT4250A 42" HDTV
Why wont my amp turn off
when it was installed they put it on a constant hot you either need to find a ignition hot or install a switch in to the remote wire
Feb 13, 2010 | SNK West Coast Customs WCC-6004 Car Amp
Orion 6004 connection problems
It should be wired up like below:
  • +12V to the battery (through an inline fuse).
  • Ground to a good, close point on the chassis.
  • REM to the remote turn-on of the head unit.
Remove the connections to the speakers and see if the issue still exists. If it doesn't, reconnect the speaker connections and find out which one causes the amp to go into protect mode.
Apr 07, 2008 | Orion 6002 Car Audio Amplifier
SNK West Coast Customs WCC-6004 Car Amp Logo
146 people viewed this question
Top SNK Car Audio & Video Experts
xxxxxx xxx
Are you a SNK Car Audio and Video Expert? Answer questions, earn points and help others
