Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
Black Screen appears and Windows restarts itself when on
I had a new hardrive put in my pentium 4 computer, new powersupply box and all drivers updated. Unfortunately, it didn't solve the problem completely with freeze up plus, blackscreen appears and restarts itself. Please offer any solutions that might be of help to me. I also had WindowsXP reinstalled with all updates. I have series 865GM3/865GVM2/865PEM3
    President:
  • 1,865 Answers
Enter Bios Setup and restore default Bios settings
Posted on Apr 15, 2009
  • 432 Answers
If you press F8 do you get the menu items that you can use the up / down arrows to navigate ie to select safe mode etc ?
If so select the option to disable automatic reboot on error and hopefully it will give you a blue screen of death and you should be able to post back with that error as it is or google it and it should tell you the issue.
CPU max temps are set too low in bios ( check those and set them to a reasonable temp )
driver issue ( corrupt graphics card driver )
Or the power supply is not powerful enough to power the motherboard and everything else ( post back with power supply rated wattage ) and what you have hardware wise - have you installed any new hardware recently ?
Reset to factory settings
Restoring the original factory image erases ALL existing data. This includes files, folders, programs, drivers, E-mails, photos. Before performing a PC Restore, back up all personal files. If you do not back up your personal files, the data will be lost.
You must press <F8> before the Windows logo appears on the screen. If you press <F8> after the Windows logo appears on the screen, the Advanced Boot Options menu will not appear on the screen. If you do not see the Advanced Boot Options menu, restart the computer, and then repeat this step until you see the menu on the screen.
3 Press the <Down Arrow> on the keyboard to select Repair Your Computer on the Advanced Boot Options menu, and then press <Enter>.
4 Specify the language settings that you want, and then click Next.
5 Log in as a user who has administrative credentials, and then click OK.
6 Click Dell Factory Image Restore.
7 In the Dell Factory Image Restore window, click Next.
8 Click to select the Yes, reformat hard drive and restore system software to factory condition check box.
9 Click Next.
The computer is restored to the default factory configuration.
10 When the restore operation is completed, click Finish to restart the computer.
The software is now installed as it was when the computer was first received.
BE AWARE. EVERYTHING WILL BE DELETED> USE AT OWN RISK! BACK UP IMPORTANT DATA TO EXTERNAL HARDRIVE
Jan 12, 2014 | Dell Inspiron 1525 Laptop
My lenovo LCD screen is flickering black and striped lines, how to get it fixed in Richmond Hill Ontario
Laptop computers have LCD displays that are sensitive to many things. LCD displays have faults that sometimes produce a flickering screen, lines, dots or a faint display. These screens are sensitive to magnetic fields or electronic items near the computer. Speakers, cell phones, lights and other electrical items are examples. Your display also could be flickering due to software issues such as the video drivers or hardware issues relating to the inverter going bad or the LCD screen itself needing to be replaced. Trace the cause of your problem to come to a resolution.
1.Turn off the computer. Disconnect all external devices. Turn the computer over (bottom facing up). Take out the battery and reseat it. Turn the computer on.
2.Reset your resolution and refresh rate.
Windows XP:
Right click an open area on your desktop. Click "Properties" in the drop-down menu.
Click the "Advanced" button at the bottom of settings tab. Another dialog box appears. Click the "Monitor" tab. Change the Refresh rate to your default, or 60 hertz. Click "OK."
Windows Vista:
Click "Start, Control Panel." Find and click "Appearance and Personalization." Click "Adjust Screen Resolution." Change resolution to the default, or 800 x 600. Click "Advanced Settings." Click the "Monitor" tab. Change the refresh rate to the default, or 60 hertz. Click "OK."
Windows 7:
Click "Start, Control Panel." Find and click "Display" Click "Change display settings" on the left side. Change screen resolution to 800 x 600. Click "Advanced Settings" in the lower right. Click the "Monitor" tab. Change the refresh rate to 60 hertz. Click "OK."
3.Check the computer's surroundings. Move away any speakers, fluorescent lights, fans, cell phones, radios and any other electrical device that can cause flickering. Temporarily move electrical items away from the computer to see if they are producing this issue.
If the flicker stops, put back one item at a time to determine what is causing the problem.
4.Connect an external monitor to your laptop computer to see if that screen is also flickering. If there is no flicker, then the problem is strictly with the laptop, indicating a possible hardware failure. Contact the manufacturer for a replacement LCD.
If the flicker continues, go to next step.
5.Reset/Update your video driver. Click "Start" and right-click "My Computer." Click "Properties." The "System Properties" dialog box will appear.
6.Click "Device Manager." A list of items will appear. Click the (+) sign next to "Display Adapters."
7.Right-click the video adapter and click "Uninstall." Confirm removal. Restart the computer. The video driver will automatically reinstall itself.
8.Check to see if the flicker still exists. If so, go to the manufacturer's website. Download and install the newest video driver and BIOS for the computer.
9.Restart computer once drivers are installed. Continue to the next step if there is still flickering.
10.Open up your display screen all the way. If the flicker stops by opening it a certain distance, it is the display inverter. If the flicker still exists, the LCD screen should be replaced.
11.Contact the manufacturer of the computer for more information and a possible replacement inverter and LCD display. This will depend on the manufacturer and the computer itself.
I hope you find it very helpful. Thanks
Sep 05, 2011 | Lenovo 3000 N200 Notebook
Restart
Chkdsk is a utility designed to check the integrity of the data on a computer's hard disk drive as well as find and fix errors which could corrupt such data.
Running chkdsk on your Windows XP or 2000 system can repair minor Windows problems
There are several different methods that can be used to run chkdsk
start with this one..... chkdsk c: /p
1. Click the Start button then... Run
2. In the Run window's Open box... type in ... cmd
3. Click OK and an MS-DOS-style black screen will appear in a new window
4. Run chkdsk by typing one of the the following commands where the cursor is blinking...
chkdsk c: /p and then press ...ENTER...
This is a short test that will tell you whether or not a longer test is needed. If after the test is done and a message ...One or more errors detected on the volume... appears then proceed to one of the next options...read them both first
Please let us know if that was helpful enough.
Good Luck & Thanks,
Shiv.
Aug 17, 2009 | Intel Pentium 4 630, 3.0 GHz...
"Input Not Supported" after adjusting screen resolution
What resolution are you trying to run? The native resolution for your monitor is 1440 x 900, setting to that should fix your issue
Jul 13, 2009 | Acer AL1916W 19" LCD Monitor
My computer comes up with a black screen
try and start in safe mode
then see if your driver is correct in my computer property hardware devices
Jan 17, 2009 | ATI RADEON HD 2400 PRO Graphic Card
Driver for USB port on my Intel Pentium II machine
Thats a tough operating system to get support from. If you can find out who the manufacturer of the motherboard is you could try a windows 98 driver for it. If you can find a way to put Windows XP into your computer, that would make it easier to take care of it.
Jan 13, 2009 | Intel Pentium 3 , 450 MHz Pentium III...
Hi CAn anyone Help I have a Dell Latitude D610 When I start up I see the windows xp logo and then the screen go blue Its freezes with the following message... A problem has been detected on your hardrive...
You need to do the following:
test a different RAM module, even if this does not happen frequently a faulty RAM can give same problem.
The problem is more likely a defective system or a faulty hard disk drive.
Try reinstalling Windows, do a full installation with hard disk formatting (do backup of your files first).
If that still does not work, then the hard disk has a faulty sector, replace the hard disk.
Dec 23, 2008 | Dell Latitude D610 Laptop Computer -...
Upgrade from Pentium 3 to Pentium 4
what socket is the Pentium 3? Socket A. The sockets have to be compatible for example you can't upgrade a Dual Core for a Core 2 Duo because although the chipsets look the same the motherboard may not support the new instruction set. I had this problem recently as i wanted to upgrade my Intel Celeron D 3.02ghz to the Pentium Dual Core 1.8ghz and although the chips were identical and fitted perfectly in my mobo, the actual mobo i was using (foxconn) wouldnt work with it forcing me to buy an ASRock mobo and replace the entire system.
May 27, 2008 | Dell 2.8 GHz Second Processor for...
Sound drivers
ravi jaiswal,
your motherboard has a packaged CD containing all the drivers needed. after installation of OS (operating system), put the driver CD in your CDROM/DVDROM device. The CD should autorun itself, if not then explore the CD then find "Setup". double click it. if prompted with menus, select best one relating to "Audio"...restart computer after installation and play sound file formats.
P.S. I assume you have Windows Operating system...
provide more details of it doesn't work
Feb 13, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Reboot problem..
Easiest possible solutions first:
1) download and install the latest drivers for your video card
2) see if there is an update for the game that causes the problem
3) run memtest86 from http://www.memtest86.com/ to check if your RAM is bad
4) swap out the current video card with a known good video card
Nov 09, 2007 | MSI MS-6366 Motherboard
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
64 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
