Question about Toshiba Satellite Pro L300 Notebook
Restore factory settings with XP service pack 2 without arecovery disc
I have pywin32 microsoft error at log on. i need to restore the factory settings for my toshiba L300\L300D satellite Pro notebook. i have no recovery disc with me. i am using XP service pack 2. PLEASE help me.
  • Shoaib Rais
    Shoaib Rais May 11, 2010
    ok try this Restore procedure without disk
    Toshiba: BEFORE TURNING ON THE LAPTOP, press and hold the 0 (zero) button on the keyboard, then turn on the computer while holding the 0 (zero) button down. When the Toshiba logo screen appears, you can release the 0 key.
Restore emachine factory settings
F9 or F12 leads you too a system recovery to reformat the pc or you can download hirens boot cd off google that fixes NTLRD errors
Apr 21, 2014 | E-Machines W3052 PC Desktop
How to format my compaq pressario cq40 604tx laptop with xp
hi
Boot from your XP install CD and select the option to format the C:
drive. If you don't have an install CD, use the "System Restore" CD or
DVD that came with your system. These restore your system to factory
settings. There're still other ways to format your C: drive, but
without either an install CD or restore one, you'll end up with an
unusable system after formatting the C: drive.
If you use the XP install CD, you'll need to be SURE you have all the
drivers for things like your DVD/CD drive, NIC, video, audio, modem, etc.
Jul 02, 2010 | Microsoft Windows XP Professional With...
I lost my restore and internet
Microsoft issued Service Pack 2 and Service Pack 3 for XP to patch (and "improve") the OS. The list of patches and downloads for XP are here:
http://www.microsoft.com/downloads/en/resultsForProduct.aspx?displaylang=en&ProductID=4c937a02-bae0-4317-a1a9-0c56cd979d05
You needed to install the service packs to continue accessing Microsoft's updates for your computer. Microsoft assumes you don't want to lose this data. You could get rid of the problem by reinstalling the entire OS from your current disc (if you have a full version, if you have an update version of XP you'll need the OS disc for Win95, Win98, WinMe or Win2K). Start with formatting the hard disc. However, you will lose the ability to contact MS for updates with Windows Update until you manually download and install the Service Packs (including SP3).
Alternatively you can build a new recovery disc for your current XP version, if you take the IT versions of the service packs. This takes several steps - first you need to copy all the files from the CD to a hard disc. Then you need to slipstream in the service packs. Then get the boot image files from the CD and create a new .iso with all of the files. For SP2, http://www.winsupersite.com/showcase/windowsxp_sp2_slipstream.asp has more information on the details.
If you want to add the SP3, you need to add the following set of steps:
http://www.winsupersite.com/showcase/xpsp3_slipstream.asp
I hope you can get your machine to function.
(if you have information that you want to save, you may want to try using a LiveCD with Unix with an external drive (optical or hard disc formatted as a FAT 32 drive) attached.)
May 14, 2010 | Dell Dimension 4300 PC Desktop
I get a kernal stack inpage error while downloading microsoft xp service pack 2, resulting in the pc rebooting and failing to reboot during chk disc
Try hitting F8 when you boot the machine
This should get you into Safe Mode
Go into Start Programs Accesories System Tools System Restore and try to roll the installation back a week or so
Jul 09, 2009 | Computers & Internet
Lookin for xp service pack 2 product keys
check the website crackserialkey.com
and pls reply us back.
Thank You.
May 18, 2009 | Microsoft Windows XP Professional With...
Some service process not kill in Windows XP
Well you have to get in and use system restore to that point when you had'nt installed the freeware tool and on the prompt that a restart is required for the changes to take effect, chose next time windows is shutdown, which means you dont have to reboot the client machine, but it will be executed the next that machine is switched off by the user.......sodeep
Apr 15, 2009 | Microsoft Windows XP Professional With...
Problem With My PC
When did it first start happening?
Do you have restore points activated? Try restoring your machine to an earlier date to see if it fixes the problem.
Feb 05, 2009 | Microsoft Windows XP Professional
WEBCAM
it is saying you need service pack 2 for windows xp, i would think,....it is a number of updates to winxp opereting system for it to perform better .
(he says smiling), if you have the original windows xp disc with service pack two on it ,put it in the cd/dvd drive and press enter when it asks for it.
good luck
Terryu
Mar 09, 2008 | Logitech Webcam
Restore
Well you can try creating another user account on the computer, by going to control pannel and click on user accounts. Then log off from the computer and log in as the new user. If this did not fix the issue, Lest us know what happens
Sep 18, 2007 | Microsoft Windows XP Professional With...
Toshiba Satellite Pro L300 Notebook Logo
414 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
