AV inputs broken picture
My problem is with a 29" Panasonic flatscreen CRT, quintrixF, bought in late 1999. I've just moved the TV to another room, there were no problems of any sort when it was in the old room. The problem is the picture, on all three AV inputs, it's jittery, with ghosting & interference patterns, occasionally black & white etc.. I've tried it with a DVD player, a Gamecube & a camcorder, so it's not the input device. I've checked that it's on the right picture system (PAL 50hz in this case), so it's not that. The picture also occasionally comes right for 5-30 seconds, but then goes back to the problems again.
  • bdenni Apr 15, 2009
    I don't actually have a soldering Iron.
    The inputs have worked fine for the last ten years, and all three jacks, which are in two different places, all started being affected at the same time. It doesn't sound like a connection issue to me.
    After watching the interference patterns for some time now, I've noticed another symptom. It seems that for the first few minutes it can't work out what colour system the input signal is, then after that, the colour is good, but the patterns change to fluctuating static across the middle of the screen.
    Thanks for your response ^_^
  • 4,234 Answers
The first thing I would suspect is a bad ground connection at the input jacks. Try gaining access to that board and resoldering the jack connections.
Let me know if that resolves the problem.
Thanks,
Dan
Posted on Apr 15, 2009
  • ABRsvcs Apr 15, 2009
    Poor solder connections occur because of repeated heat/cold which occurs when the set is on and off over the years. This is a very common problem and could effect all inputs if the connection problem is between the "input board" and the rest of the set. The loss of color can be casue by the loss of the sync pulse which is possible if there is a bad ground side connection. Static in the picture is also a symptom of a bad ground.
    For a set of the age you describe, the first step is always to look for and repair any poor solder connections that exist. These connections will often work for years until disturbed by a mechanical change (moving the set for example).
    If you know someone that can assist you with soldering, look for any solder connections that appear grainy rather than shiny or have rings in the solder area and resolder them. That may resolve the problem. If not, then we will need to loof for defective capacitors in the video signal line.
    Plesae keep me posted.
    Dan
TV has no picture, but sound works fine
Are you using the AV input for the XBox or other cable? If you use AV, then use the same input that the Xbox does not show picture, plug in a DVD and see if it works. If it does not have a picture, so 100% your TV has problem.
Aug 11, 2009 | Sony Televison & Video
Ive got a 29'' tube flatscreen that wont work no more
seems to be an issue with picture tube.Please try after changing picture tube
Jul 28, 2009 | Televison & Video
I have an old tv, a konka k148e2. i have bought a
First check your TV AV Input connection that its works with other things like VCR.
Jun 17, 2009 | Televison & Video
When I turn on my panasonic flat screen tv, it flickers off and on or stays black for a long period before we gradually get a picture.
You have a dry jointon your main card, check the following
switch contacts
line transformer or line transistor,
Apr 14, 2009 | JVC AV-K29MX1U 29" TV
To Connect AV Cable from Panasonic VCR to Sony 29 inches
You can either connect the antenna output of the VCR to TV ant in or hookup the audio/video outputs from VCR to audio/video TV inputs. If using the antenna output you need to sellect channel 3 or 4 to view VCR. If using the adio/video lines you need to select the line input on TV to view VCR.
Feb 18, 2009 | RCA F20640BC 20" TV
29" crt tv video and sound problem
Is it possible that the input to the TV is still good including cables and cable box or anything? If another TV works from the same input then it may be the TV settings like AV/video rather than TV channels. Check all this out. I hope it is something simple as that. Good Luck.
Sep 22, 2008 | JVC AV-36150 36" TV
Broken av inputs
I use a screw extractor,
a tapered threaded tool that binds on the inside of bolts et al, you wind it inside the broken end and pull gently.
where the item is a press fit and very small, needle nose pliers may provide sufficient grip.
Sep 01, 2008 | Philips Magnavox 27MS343S 27" TV
AV-2053m
My problem is solved!!! I called my neighborhood TV repair shop. The technician suggested I check the Internal Speaker Switch on the back of the TV. And sure enough, I had accidentally move the switch to the OFF position while carrying it from one room to the other. Ahhhhhhhh!!!!!!!!!!!!! my 13 year old JVC is as good as new!!!!!
Aug 02, 2008 | JVC AV-32260 32" TV
Picture not fitting on screen
if your tv has a warranty take it back to where you you bought it.or check if your remote has the zoom feature,if it does zoom it back.or else you will have to call the repair man to program it for you.
Mar 23, 2007 | JVC AV-29LX 29" TV
Televison & Video Logo
148 people viewed this question
Top Televison & Video Experts
