Question about Toshiba Tecra S1 Laptop Notebook
Audio device problem
I dont hear sounds when i play audio files and movies in my windows media player
  • 385 Answers
Type DXDIAG into the Run box,
Test for sound in there,
If no driver,
Device manager, click sound, update the driver in there.
Regards.
Posted on Apr 15, 2009
Windows media player throws error when I play any audio
As you may have already notice, there isn't a problem with your driver.
However to gain a better understand the problem you rule out a couple of things. However, if the this problem is only present in windows media player. Then you should try another play i.e. VLC media player.
1. Go to you device manager and make sure the device is working properly. If not try uninstalling the device, restarted the computer letting windows discover the device again.
2. Next go to windows media player file (press "alt" key to get toolbar in newer version. Select options -> devices select your speaker -> properties and be sure that your audio device is available and selected.
3. Finally if all these options has failed, please use an alternative media like the one mention above (VLC media player).
I hope this have been a great help in your troubles. Please provide feedback on the solution.
Jan 19, 2014 | Microsoft Windows 7 Home Premium 64BIT...
How do I reformat the audio for video file on external harddrive ! The video plays but there is no sound
Make sure you have compatible audio codecs installed on your computer and the playback device volume is up and not muted. For PC, try playing the file with VLC Media Player:
http://www.videolan.org/vlc/
If the video file itself has no audio embedded, then there will be no sound until that file is edited (using any video editing software - windows movie maker, etc) and audio is added.
Apr 13, 2012 | Samsung Computers & Internet
The file format is not supported
Hi driddle00...
This information came from the Microsoft WebPage:
"Cannot play back the file. The format is not supported. This behavior occurs because PowerPoint can play back only QuickTime movies (.mov and .qt files) that use compression schemes with corresponding Media Control Interface (MCI)-compatible codecs.
A codec (compressor/decompressor) is an algorithm or scheme that is used to record digital video or audio. For example, when you transmit video over the Internet, the video must be compressed on the sending end and decompressed on the receiving end. A codec can be chosen based upon the user's audio or image quality and image size preferences.
When you read a QuickTime movie, a Video for Windows decompressor decompresses the QuickTime files. If the decompressor does not support the compression method used by the QuickTime movie, the decompressor cannot display the movie on the screen.
To work around this behavior, use one of the following methods. uparrow.gifBack to the top Method 1: Create a hyperlink to the .mov file loadTOCNode(2, 'workaround'); Create a hyperlink to the .mov file, and then let the QuickTime Player for Windows play the file instead. To do this, follow these steps:
  1. Select the object or text that you want to assign the hyperlink to.
  2. On the Insert menu, click Hyperlink.
  3. Under Link to, click Existing File or Web Page.
  4. Select the QuickTime movie that you want to play, and then click OK.
    Note Under Look in, click Current Folder to see a list of files, click Browsed Pages to see a list of recently viewed Web pages, or click Recent Files to see a list of recently used files.
During the slide show, click the linked object or text to play the movie. If a valid player is available, the player starts, and then the player plays the QuickTime movie. uparrow.gifBack to the top Method 2: Convert QuickTime movies to AVI format loadTOCNode(2, 'workaround'); Note In the following steps, you must use QuickTime 4.0 Pro. You cannot follow these steps with the basic version of QuickTime 4.0. The steps are the same for both Windows and Macintosh versions of QuickTime 4.0.
You can use other QuickTime editing programs instead of QuickTime 4.0 Pro. To do this, see the QuickTime documentation for the relevant steps.
To convert the QuickTime movies to AVI format, follow these steps:
  1. Start QuickTime Pro, and then open the file that you want to convert.
  2. On the File menu, click Export.
  3. Set the Export file type to Movie to AVI.
  4. Click Options, and then click Settings.
  5. In the Compressor group, click the list of compressors, and then select one from the previous list. Cinepak is a popular format. Select the format that you think works best with the movie.
  6. Make sure that you change the extension on the file name to .avi, and then click Save.
uparrow.gifBack to the top Method 3: Recompress the QuickTime movies with compatible codec loadTOCNode(2, 'workaround'); Note In the following steps, you must use QuickTime 4.0 Pro. You cannot follow these steps with the basic version of QuickTime 4.0. The steps are the same for both Windows and Macintosh versions of QuickTime 4.0.
To recompress the QuickTime movies with compatible codec, follow these steps:
  3. Set the Export file type to Movie to QuickTime Movie.
  6. Click Save.
uparrow.gifBack to the top Verify that QuickTime movies are compatibleYou can use Microsoft Media Player to... loadTOCNode(1, 'moreinformation'); Verify that QuickTime movies are compatible loadTOCNode(2, 'moreinformation'); You can use Microsoft Media Player to verify that a QuickTime movie is compatible with PowerPoint.
Note Microsoft Media Player (Mplayer.exe or Mplay32.exe) is a different program than Windows Media Player. Microsoft Media Player is included with various versions of the Windows operating systems, and is an MCI-compliant device. Windows Media Player, however, is a new technology that does not rely on MCI to play various forms of media. Windows Media Player can play a wider range of video and audio formats than Microsoft Media Player can play.
To determine the compatibility of the movie, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open box, type the appropriate command for your operating system:
    • In Microsoft Windows 98 or Microsoft Windows Millennium Edition, type mplayer.exe, and then click OK.
    • In Microsoft Windows NT 4.0, Microsoft Windows 2000, or Microsoft Windows XP, type mplay32.exe, and then click OK.
    Microsoft Media Player starts.
  3. On the File menu, click Open.
  4. Select the QuickTime movie that you want to verify. Click Open.
If the QuickTime movie is compatible, Microsoft Media Player opens the movie. If Microsoft Media Player opens the movie, but PowerPoint does not, there may be a problem with PowerPoint or with the MCI settings. If Microsoft Media Player does not open the movie, and then you receive an error message in Media Player, the movie is not compatible and cannot be played in PowerPoint. You may be able to make the movie compatible by using one of the methods described in the WORKAROUND section of this article."
Sep 06, 2011 | Philips GOGEAR SA6045 MP3 Player
My computer was reformated, but I cant use my Multi media becuse there is no audio device which the program asking for, what shall i do
Not sure if you are saying you dont have a sound card installed or if when you try to play a movie it says it cant play the audio. if it is the later then i advise you intall a few codec packs. starting with divx, then community codec pak, and ac3 filter. these are the most common codecs required for most of the audio in media files. if it asking for an actual hardware sound insure that you have direct x installed as the media center in windows vista uses direct audio to paly the audio tracks in media files.
Nov 04, 2010 | Microsoft Windows Vista Ultimate Edition
No Sound Can Be Heard
that message usually means that the audio file is the wrong format for that media player you can download a different player that plays that format, go into my computer and pull up the music files that dont play right click on one and select properties and it will tell you its format/file type
May 27, 2009 | HP Pavilion zv6000 Notebook
WMP error message-C00D11B1
Can you try this:
  • Start-> Control Panel->Hardware and Sound
  • Sound / Manage Audio Devices
  • Highlight your audio device
  • Properties
  • Advanced
  • In the Exclusive Media section, UNCHECK the box "Allow applications to take exclusive control of this device."
  • Apply
Hope this helps.
Thanks.
Mar 08, 2009 | Microsoft Windows Vista Ultimate Edition
Sound program
is it movie or music?
if it is movie use g-spot to find out which codec is missing
http://www.free-codecs.com/download/GSpot.htm
if it is music check your soundcard and the options in windows media player
Jan 22, 2009 | Intel Premier Resources 4-Channel 32-Bit...
Sound troubleshoot
first thing you can do is uninstall 11 and then reinstall it. but before you install media player 11 again uninstall the previous version 11 doesn't upgrade ..what sound device do you have???
Aug 18, 2008 | Creative Labs Sound Blaster Live! 5.1...
Sound device
Sound of my Pc is disapeared I think drivers are missing what should I do ?
Jun 24, 2008 | Computers & Internet
Speakers dont work
u need properly sound driver
check your sound chip in motherbord and tell me i give u link to install proper driver
Apr 01, 2008 | Computers & Internet
Toshiba Tecra S1 Laptop Notebook Logo
73 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
