Question about Sharp EL-733A Calculator
Number 2 key not working
Well for starters I have a scientific calculator el-556g. The number 2 key doesn't work any more. I thought maybe the little keypad carbon was rubbing off or something. I opened it up poked around and then put it back together. still doesn't work. Any thoughts on what the problem could be -
  • Anonymous May 25, 2009
    Number 8 does not work.
    I observed this issue from time to time.
    New Friend:
Get a new calculator you stupid *****.
Posted on Jul 15, 2010
SOURCE:
How to use power and percent in el-531x scientific calculator
To use the power, you use the y to the x key, above the EXP key. To enter 2 to the power of 4, you enter 2 hit the y to the x key and enter 4 and hit enter.
To use percent function, you enter the percent key after the number. To calculate Interest, where Interest = Principal x Interest x Time. For example, if the principal is $1,000, the interest rate is 8%, and time/term is 4 years, we would enter 1000 x 8 Percent x 4. When the8 is entered followed by the percent key, it should turn into 0.08.
Good luck,
Paul http://www.sharp-world.com/contents/calculator/support/guidebook/pdf/Operation_Guide_EL-531W_ser.pdf
Jul 28, 2016 | Scientific Calculator Office Equipment &...
Why the right most buttons of my SHARP EL-W506X scientific calculator does not function?
Mmmm... it sounds like the calculator has been dropped or possibly gotten wet - maybe with something wet & sugary, which when it dries leaves behind a sugar deposit that won't allow enough electrical connection for the keys to work.
At this point, you've got very little to lose - if you suspect that it may have gotten wet, you could pull it apart (carefully) and rinse it out inside - very thoroughly - with distilled water, then let it dry for about a week before you put it back together.
If it's been dropped, it's probably not worth repairing; even scientific or statistical calculators are inexpensive compared to the cost of repairs.
Jul 19, 2014 | Sharp Office Equipment & Supplies
Upper keys don't work
You activated the base-5 numeration system, where the digits are 0,1,2,3 and 4. Change the numeration system to DECimal.
Jan 13, 2014 | Sharp el-531x scientific calculator
Unresponsible key
Try cleaning the keypad. Reset the calculator. When you press the EXP key or the 2ndF +EXP key try pressing firmly the calculator between your thumb and index (left hand).
To work around this defect (due to the venerable age maybe)
enter the approximate value of PI=3.14159265359 on your calculator and store it in one of the available memory locations. When you need use PI just recall the value to the display.
The EXP key is just a short cut for *10^(exponent). You can explicitly use the general power key.
If you are averse to using this workaround consider acquiring another calculator.
Dec 24, 2013 | Sharp Office Equipment & Supplies
I can't get rid of the zero in front of the minus, add, multiply and devide sign. how do i get rid of it?
Are you entering any number before pressing the minus, add, multiply, or divide key? Those operations require two numbers; if you don't supply the first one then the calculator will supply the previous answer, which was zero.
For example, to add 2 and 3, press 2 + 3 = and you'll see 5. Now to add 4 to that, press + and the calculator will automatically supply the 5. Press 4 = and you'll see 9.
Oct 08, 2013 | Sharp el-531x scientific calculator
How to I stop my sharp EL-531X calculator from rounding when converting from decimal to scientific notation?
You need to select the number of decimal places you would like, or if you would like the calculator to behave as normal. Press SET UP and select FSE (press 1) . You now have 5 options.
0: FIX means you can choose a fixed number of decimal places for every calculation.
1: SCI means scientific notation and choose the number of significant values you would like to deal with.
2: ENG means engineering and the power goes up in multiples of 3.
3: NORM1 and 4: NORM2 are the usual or normal settings on the calculator. Most school calculations will use NORM1 mode.
Aug 28, 2012 | Sharp El-531x Scientific Calculator Green...
EL-556G very old but very reliable cant remember how to clear the Memory
Either press the reset button on the back of the calculator, or "STO" then "M+" for main memory.
Sep 22, 2011 | Sharp EL-733A Calculator
How do you raise to a power on a Sharp el-738 business calculato?
I don't know about this specific calculator, but there is probably a button on your calculator that has a "y" with an "x" as a superscript (exponent). Or is could be reversed. But you wanted 2^8, you would push the 2 first, then the exponent button, then the 8, and there's your answer.
Good luck.
Jul 14, 2010 | Sharp EL-738 Scientific Calculator
How do you change the number of decimal places?
• Press [2nd] [MODE] and scroll to FLOAT.
• Press the right arrow key until the number of decimal places needed is highlighted.
• Press the [ENTER] key.
For 2 decimal places, 2 should be highlighted. All answers will then be rounded to 2 decimal places.
• Press [2nd] [QUIT] to return to the home screen.
Mar 17, 2010 | Sharp EL-738 Scientific Calculator
The calculator is intermittent: Most of the time
Not knowing what to do, I tried anything that could possibly help:
I installed fresh batteries and I pushed the reset button on the back of the calculator (Sharp EL-546L) and finally, it work all right after more than 5 years I own the calculator and where it did work correctly for 5 minutes. I tried the reset button in the past (long time ago) and it didn't work. This time it worked because, maybe, I've used fresh batteries.
Marcello
Jun 03, 2009 | Sharp EL-738 Scientific Calculator
Sharp EL-733A Calculator Logo
279 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
