Question about Logitech Z-5500 Computer Speakers
Led main screen light on logitech z-5500 speaker set broken
The main screen still works but i have no led light..At all it slowly faded now it is gone..Any help would be greatly appreciated?...Thanks..
    Scholar:
  • 59 Answers
Well try the "turn off - let cool down a bit - turn on again" routine along with the strike/punch/hit it here or there(sometimes they DO really help) -if this doesn't work, you have these options:
1. Do you still have a warranty? If it hasn't expired yet, no question, you have to take it back to the shop for a return or repair...
2. No warranty? Well at a repair shop it could be possible that the price of a repair is somewhere near the price of a new one. Maybe you could try your nearest "Joe's Repair-It-All" type of service first :-)
3. Have a friend considered a geek/expert do it for you
4. Pull it off yourself - open the box and look at the type of backlight your display has. I'm more than certain it's gonna be a set of SMD LEDs, cause FL panels are not common in this cheaper stuff.
either in case 2,3,4 try to get all the LEDs new, this will prevent differences in the quality of backlight. Also this is a chance to change your backlight maybe to match your computer's controls or in-case lighting. The repair shop is likely to be able to offer different colours, then that expert/geek friend in case 3. will gladly help you or you can find some electronic parts store round the place you live or order it online and have all delivered to your house, but first disassemble the unit
to know the parts gone wrong...
Posted on Apr 15, 2009
Sanyo dp42849 picture is slow
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 22, 2017 | Sanyo DP42849 42 in. HDTV
Hello there, I recently purchased a Logitech z-5500 speaker system online, I have plugged all the speakers and set it all up correctly. It makes sound when I pres the "Test" command on the...
verify if the computer has a digital output that matches your speakers (5.1 or 7.1). Also, verify that the cable leading from the PC to the main speaker box is OK. Also, the speakers may come with an installation CD, so you'll need to install the accompanying control application.
Jan 02, 2011 | Logitech Z-5500 Computer Speakers
Only the center speaker work well now.
I have the same problem but its all the speakers, move the control pannal around and it should work. If yours is broken like mine call Logitech and they will help you.
Feb 08, 2010 | Logitech Z-5500 Computer Speakers
The right speakers logitech Z 5500 do not work
try buying a new optical cable or change some settings on your tv.
Feb 04, 2010 | Logitech Z-5500 Computer Speakers
Logitech Z-5500 DON'T POWER ON. HELP!!!
check its power supply if its working, first.check the outlets(electrical sockets)just to be sure of proper fit.
May 31, 2009 | Logitech Z-5500 Computer Speakers
Logitech MX Revolution Left Click Button Broken
I have a Logitech Revolution MX 5500 Bluetooth mouse (part of the Logitech MX 550 desktop set.)
In my case, uninstalling SetPoint and re-installing solved this exact problem.
Mar 23, 2009 | Logitech Cordless Desktop MX 5500...
No power in Z-5500 logitech speakers
The logitech z 5500 digital is very sensitive to power peaks. One of the most know problems is that the fuse breaks because of these peaks. I´ll show you how to replace the system´s fuse.
First of all, you just need to write down the specification of the system´s fuse. The system´s fuse specifications are printed in the back side of your subwoofer, right next to the subwoofer´s on/off switch. In an european system it says: "T2AH250V (Time Delayed)". If you use another power voltage (120v), it may say something different. Anyway, write it down on a piece of paper and go to an electricity store and ask for a similar fuse (It is very cheap. Not more than 1$)
-The best way to get a similar fuse would be by bringing the broken fuse with yourself to the store-
In the back of your subwoofer, using an screw-driver, un-screw the fuse´s cover and remove the broken fuse. Replace it with the new fuse, attatch it to the cover and screw it back again.
If you turn on your system now, it will probably work fine.
Oct 20, 2008 | Logitech Z-5500 Computer Speakers
Logitech z-5500
Try to click the EFFECT BUTTON a few times to change the effect settings (see also in display) from e.g. Stereo (which uses only two front speakers) to other settings (for which some will use the other (rear/center/sub)speakers as well). Success,
Jun 20, 2008 | Logitech Z-5500 Computer Speakers
LED light fades as soon as turned on and no sound
Hi Umphreak
It is bad resistor issue on your logitech speakers, has to replace them. (or) the power for your mac mini, its not very AMP good, for them.
try in another PC and see if work fine the speakers.
Nov 25, 2007 | Logitech Z-2300 Computer Speakers
Logitech Z-5500 Computer Speakers Logo
3,925 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
