Question about Kenmore 24032\24036 Top Load Washer
Out of balance 80 series Kenmore washer
It spins out of balance during wash and spin cycle. I beleive it started after she washed a load too big! Now it does it all the time.
SOURCE: Sears Kenmore 80 series washing machine Model 110.26832691
Model 11020922990 Kenmore Three speed is tearing shirts. Sear is no help at all. All they want to do is send a $75 service call or sell a warrenty. I just need an answer to the question, Why are my shirts being ripped up. The owners manual has some suggestion none of which fit this situation.
If I have to rely on Sear a rock at stream side sould like a better solution!
Posted on Jun 02, 2008
  • 188 Answers
SOURCE: Kenmore 80 Series washing machine - loud banging at end of spin
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further.
Posted on Mar 10, 2009
  • 8 Answers
SOURCE: kenmore washer 80 series misses spin during wash.
You may need to replace the motor coupling between the pump and motor...
Posted on Apr 07, 2009
Maytag317
  • 1136 Answers
SOURCE: Whirlpool Kenmore 80 Series is making loud noises during washspin
Hi, Make sure the washer is solid to the floor. To level the washer, Put your foot against the front panel at the floor and tip the back of the washer toward you. Then set the washer back down and the rear legs should self adjust.
Hopefully this will stop the washer from shaking.
Vic
Posted on Jul 05, 2009
  • 1937 Answers
SOURCE: I have a Kenmore 80 series washing machine and the
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
This also assumes that:
1. The machine will agitate and go through the rest of the cycles.
2. It will pump out the water.
3. Since it tries to spin, the Lid Switch is OK.
The problem points to the clutch and / or transmission
See the following for how to pull the clutch on Kenmore top load direct drive washers.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the clutch springs and pads seem OK, the problem points to the main spin gear inside of the transmission. If the clutch springs and/or pads are damaged, there is a rebuild kit for them.
Following is the Whirlpool / Kenmore installation and maintenance PDF on how their top load, direct drive, neutral drain washers work.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Here is another PDF of the Whirlpool parts list for their commercial washers, consumer models are basically the same.
If you look at the operation PDF you'll see how the transmission works when going into the spin cycle. If the "Neutral Drain" cams are intact, they drive the main spin gear which drives the spin gear connected to the clutch.
If the main spin gear is broken (It's a metal plate surrounded by plastic gears) you would hear a major grinding noise and the washer wouldn't spin.
Opening the transmission is not difficult but is a messy job. It holds about 14Oz. of oil.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the main spin gear or neutral drain assembly cams are damaged, they aren't too difficult to replace.
The Whirlpool Parts PDF has part numbers for both.
The Neutral drain assembly costs about $15 which is a lot less than $170 for a new transmission.
The Main spin gear is quite a bit more but still less than a transmission.
Posted on Oct 12, 2009
I have a Kenmore 80 series top load washer. It will not drain during spin cycle. If I run it through a second spin cycle it will usually drain. Any ideas
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 18, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My Kenmore top loading, series 80 washer seems to be way out of balance during high speed spin cycle.
check the rubber feet and does it rock when it not on ! we have had the feet worn
Jan 11, 2010 | Washing Machines
During the spin cycle, the washing machine rattles loud almost as if its off track, it is the 80 series kenmore top load
souns like the gearbox (what the motor mounts to) it bad. I'm asummin the load in the washer is balanced (all the clothes are not on one side of the tub)
Jul 05, 2009 | Kenmore Washing Machines
Kenmore TL Washer Just Hums
try to wash by 1/2 load the same cycle maybe the problem come from overload laundary
Jun 06, 2009 | Washing Machines
Kenmore washer 80 series misses spin during wash.
Apr 07, 2009 | Kenmore Washing Machines
Kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80- spin cycle does not spin
possible bad bearings in basket support asm or bad basket drive asm both pretty big jobs
Dec 13, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer stopped during unbalanced spin cycle
lid switch is broke lever probley broke off or screw holes broke out due to off balance load forcing tub over against switch lever
Apr 29, 2008 | Kenmore 20172 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
420 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
