Question about Panasonic (KX-TDA0104) (KXTDA0104) Power Supply
Analog card not working in tda100
I have a TDA 100 Panasonic system, i wanted to use a cordless phone so i installed an 16 port analog slt card. Now the scenario is Intercom(extension) is working but can not get the CO(Main line) in the cordless or normal 1pair analog phone. Could anyone help me with this problem. Do i need any other configuration
  • 2 more comments
  • theamarz Apr 15, 2009
    i tried this dialing line, to access the line but when i press 9 am not even getting a dial tone and that extension have COS 2 which has even 00 open, advice please
  • theamarz Apr 16, 2009
    no again its not working, and when i press 9 am not getting any tone but when i press 7 the tone changes but can not get in to the CO line, advice please
    yes i can dial. and when there is an incoming call comes it rings as well
  • theamarz Apr 18, 2009
    thank you very much dude. i fixed it u r wonderfull,,, thanks a lot
    Problem Solver:
  • 19 Answers
You will still need to dial a 9 from the phone to get an outside line, or you can program the analog ext to auto dial it for you. If you still can't then it sounds like the phone is in the wrong COS so it doesn't have access to the CO's.
Posted on Apr 15, 2009
  • 2 more comments
  • Chase_42 Apr 15, 2009
    You can dial ext to ext right? If so try dialing 701 then see if you get dial tone. What this will do is manually pick trunk group one from the phone system. If that is the trunk group number for you CO's. The 7 tells it to pick up a trunk and the 01 tells it to try group 1 of the trunks. You may have to try several other groups but the trunk (7) shouldn't change.
  • Chase_42 Apr 16, 2009
    you did say ext to ext was working correct? you can dial another ext from the cordless?
    Ok 2 places to check for problems that I know of. One is the external call block in the programming tool should be 2.7.2 make sure there are no blocks highlighted. Also check in the programming tool 4.1.1 option 2 tab to see if pickup dial set is off and nothing in the pickup dial number. Also please verify the card and port you are plugged into. Card number, and which pair of wires on that 66 block you are using.
    Almost forgot one other thing, check the TRS lvl make sure it is 1, TRS 7 if on will not allow outside dialing. Should be 7 by default by the way.
Some analog line in not working on kx tda 200
have you tested the same line directly with an analog phone?Is it working?
Oct 09, 2012 | Panasonic Kx-tda0196 Remote Card For...
KX-TDA Series Maintenance console
p/s i need support on kx-tda100 maintenace console gives errror
the software that can maintain the kx-tda 100/200 version is not installed to this pc
any one with ideas p/s p/s i need to configure it p/s
Jul 06, 2012 | Panasonic Kx-tda100 Kx-tda100 Digital...
Hi local charity has been given a TDA100 telephone
What's a crone box? If you have no problem installing the system, without a manual, then you have a problem. The TDA-100 is a dealer only product. Hanging it on the wall and running cables to the Amphenol connectors is the easy part. The 16 port digital card uses the first 16 pairs of the cable that get cross cut to the second pair of an RJ-14 jack....in the USA. The 8 port and 16 port trunk cards use the first 8 and 16 pairs of the cable. The only tricky part is if you have a hybrid 8-port card. It uses the first 2 pairs of every 3-pair set for voice and data.
Your real problem is going to be programming. With a manual, but without the programming software, you're going to be very limited. If the system is already functional, you might have access to some of the programs, but you're going to find it difficult to do anything worthwhile.
I suggest you call a Panasonic engineer to finish the job.
Carl
Jul 16, 2011 | Panasonic Lands Phones
I have a desktop Panasonic corded phone model kx-t7633 and I want to connect a handheld cordless phone model kx-tg4011 to it. How do I sync the two phones?
There are a lot of conditions, but first you have to have an analog port to back up the digital. In a TDA 30/50 it means one of the first 4 extensons in the system which have the Digital Super Hybrid ports. It's something that the dealer or someone with the dealer password and maintenance tool will have to set up. Once it's done, the mated extension can either stand alone, or be merged with the digital phone.
Carl
Jul 03, 2011 | Panasonic KX-T7633 Corded Phone
I have a panasonic KX-T7130E and want to know how to connect and install it.
It connects to a Panasonic Key Service Unit, pick a number, TA/TES, TAW, KXT, KXTD, and in some cases TDA/TDE/NCP. It's an analog 4-wire system phone, so it requires both voice and data pairs (a 4-pin connection) and a port on the system. You can only connect one 7130 to a system extension.
Carl
Jun 05, 2011 | Panasonic KX T7130 Corded Phone
Hi , i have panasonic TDA100 ipbx system i recently buy kx-tda170 hybrid extension card and install to pbx how can create extension from 25aid cable
The 170 card is an 8-port DHLC and it's pinned exactly like the old 123211 and the TD series systems where the first 2 pairs are the voice and data for a Panasonic Analog phone or a single line set on the first pair, and the 3rd pair is unused in the TDA. There are 8 3-pair sets in the cable and the 25th pair is nothing. Here's a link to an installation manual http://public.carl.airpost.net/Pana/TDA/100_TDA_IM_07-04.pdf The instructions start on page 139.
Carl
May 05, 2011 | Panasonic KX-T7731 Corded Phone
I would like to set up an answering machine on Panasonic kx-t7630 but don`t know how.
A 7630 is a digital phone that connects to a TDA/TDE or NCP Panasonic phone system. There are 4 analog ports in a TDA-50 or lower phone system, so you could install an answering machine on the first 4 ports of a TDA by default. If you have a TDx-100 or higher, you have to have cards that contain analog ports.
However, you could always wire the answering machine on a specific line.
Carl
Jan 15, 2011 | Panasonic KX-T7630 Corded Phone
I need to know if we can set up a answering machine with our panasonic telephone KX T7630 system as we are going away for a couple of days.
Just hope its not today and tomorrow :-)
In a TDA-50 or lower system, the first 4 ports are dual (triple) ports in that they can be analog, digital, or eXtra digital ports. If you plug an answering machine into the back of a phone, it can be extension 201-204, 100 higher than the digital station.
It's only a DIY project if you're very good, so I suggest you run it by your dealer/installer/engineer for guidance.
Carl
Dec 16, 2010 | Panasonic KX-T7630 Corded Phone
I have a phone system in my house using the KX-T7633 model corded phones. I want to plug in a cordless phone in the back of the KX-T7633 so that I can be cordless, but when I do I can not get a dial tone...
In a TDA-30/50 there are FOUR super hybrid ports, the first 4 on the cabinet. In a TDA 100/200/600, there are NONE. Which one do you have and is your extension 101-104? If not, it won't work. You can probably wire an analog port to the first pair and use the same cable, but it will never merge with the digital set.
Carl
Aug 24, 2010 | Panasonic KX-T7633 Corded Phone
Just plugged caller id box in to panasonic kxt7420
There is no such thing as correctly plugging an analog caller ID box into a digital phone line.
CID display comes from a TD-193 card mounted in the Key Service Unit and it only displays on Panasonic system display phones designed to work on a TD system. The only system that passes CID through to stations is a TA-824 and certain models of TDA-s that have special analog extension cards.
You can use the analog box, but you have to bring the line from in front of the system to the CID box.
Carl
Nov 11, 2009 | Panasonic KX-T7420 Corded Phone
Computers & Internet Logo
285 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
