Question about Sony PlayStation® 3 (60 GB) Console
My playstation 3 When i press on the power on the front, i hear the drive trying to boot but after a couple of seconds it swithces off and back to standby Please help what can i do
  • 107 Answers
Mine did this once. I turned the switch off the back and unplugged it for a few minutes. Plug it back in and turn the switch on the back, then try again. This worked for mine and it's been fine since. If it doesn't work, then I'm out of ideas.
Posted on Apr 15, 2009
How to enter safe mode on my ps3
Step 1: Turn off the PLAYSTATION 3 by holding the Power button on the front of the unit till the Power light is red.
Step 2:
  1. Touch and hold the Power button, you will hear the first beep, meaning the PLAYSTATION 3 is powering on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep, indicating the video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a third beep and the system will power off (Power light is red).
Step 3:
  1. Touch and hold the Power button, you will hear the first beep, again for the PLAYSTATION 3 to power on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep for video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a quick double beep. At that point release the Power button. If you succeeded in activating Safe Mode, you will see a message on the screen saying, "Connect the controller using a USB cable and then press the PS button."
Apr 24, 2014 | Sony Playstation 3 (PS3) Console
Tip
Playstation 3 not starting up?
Are you plagued by the problem of your Playstation 3 not booting up properly?
Got a screen with just a background and no icons?
Seeing a wavy line and nothing else?
This is the tip for you!
This is a problem with the Playstation 3 software becoming corrupt. It is very easy to fix if you follow my simple steps.
Please note, this method will erase your hard drive so any save games you had will be lost. All your online trophies will be preserved.
Step 1.
Turn your Playstation 3 off into standby mode (red light on)
Step 2.
Press and hold the power button. The Playstation 3 will beep when you first press it, then beep again 5 seconds later and then beep once more and turn off back into standby mode (red light on). You must now release the power button.
Step 3.
Press and hold the power again. The Playstation 3 will beep when you first press it, beep again 5 seconds later then there will be 2 quick beeps together. When you hear these 2 quick beeps release the power button.
Step 4.
Your Playstation 3 will now start up with a screen asking you to connect a controller via USB. Connect your controller and then press the PS button.
Step 5.
A menu will now be displayed on screen. Select option 5 "Restore PS3 System". This will then ask you to confirm that you wish to go ahead with the system restore. Accept whatever the Playstation 3 says.
The Playstation 3 will now go through the system restore process and re-install the system software back to out of the box status. You will have to set your user name, date and time and network settings again.
Once you have completed the above, the Playstation 3 will restart and spring back to life again!
I hope this helps all of those out there who are suffering this problem.
on Nov 10, 2010 | Sony Playstation 3 (PS3) Console
When I turn on my PS3 will not load the basic applications, neither the games. When I press the PsS button on the cotroller to turn it off I will get the option but it will not tunr off and i will get a...
Step 2:
Step 3:
  1. Touch and hold the Power button AGAIN, you will hear the first beep, again for the PLAYSTATION 3 to power on.
  4. Connect a USB cable to the controller and the PLAYSTATION 3 and press the PS button to enter Safe Mode.
  5. Then you will see the Safe Mode menu.
*****CHOOSE RESTORE FILE SYSTEM WHICH IS OPTION 3****
and DONE!!
www.1RepairStop.com
Aug 25, 2011 | Sony Playstation 3 (PS3) Console
My Sony PS3 is the orginal 60 GB unit and worked fine for quite a few years until the icon stopped appearing. This meant I could play blue ray, CD, DVDs. I had no problem playing a game that was on the...
You can try to do a system recovery on your PS3. this will set your PS3 back to factory settings as the settings may have been changed during the use. Here is the process in which you can do a system recovery.'
PS3 Recovery Menu
  1. Place the PS3 in standby mode
  2. Press and hold the power button for a couple of seconds, you should hear a beep
  3. Keep a hold of the power button for a couple more seconds, the PS3 should shut back down to standby mode
  4. Once this happens, press and hold the power button again for a couple of seconds, waiting for 1 single beep.
  5. Ignore this beep and keep it pressed until you hear 2 consecutive beeps, release the button.
I think you choose option 3 and then repeat and choose option 4. Once you are done with this, try out your PS3.
Aug 05, 2011 | Sony Playstation 3 (PS3) Console
I did everything except this time now it says "
Try a Restore
PS3 Recovery Menu
Try restoring the file system (Option 3), then repeat with rebuilding the database (Option 4).
Feb 10, 2011 | Sony Playstation 3 (PS3) Console
My Ps3 wont load the dashboard help
Please try the following solution to fix your PS3. Please note, option 5 will erase your hard drive so any save games you had will be lost.
Step 1.
Step 2.
Step 3.
Step 4.
Step 5.
A menu will now be displayed on screen. Select option 3 "Restore File System". This will then ask you to confirm that you wish to go ahead with the system restore. Accept whatever the Playstation 3 says.
The Playstation 3 will now go through the system restore process and re-install the system software back to out of the box status. If it still does not work try the above but choose option 4. If that does not work try option 5 as a last resort, this will erase the hard drive.
Once you have completed the above, the Playstation 3 should restart and spring back to life again!
Jan 28, 2011 | Sony Playstation 3 (PS3) Console
PS3 Discs Not Loading.. (Dvds, Cds) We Opened Up The PS3 And Checked The Drive And Cleaned The Lens And Dusted Off Everything Pretty Much And We Put It Back Together And turn it on Still Not Working Jus...
Welcome to Fixya
Try the troubleshooting procedure below:
Step 1 - Turn off the playstation 3 by holding the power button on the front of the unit till the power light is red.
Step 2 - Touch and hold the power button, you will hear the first beep, meaning the playstation 3 is powering on. Continue to hold the power button and after about 5 seconds, you will hear a second beep, indicating the video reset. Continue to hold the power button and after about 5 seconds, you will hear a third beep and the system will power off (power light is red).
Step 3 - Touch and hold the power button, you will hear the first beep, again for the playstation 3 to power on. Continue to hold the power button and after about 5 seconds, you will hear a second beep for video reset. Continue to hold the power button and after about another 5 seconds you will hear a quick double beep. At this point release the power button. if you succeeded in activating the safe mode, you will see a message on the screen saying 'connect the controller using a USB cable and then press the PS button.
Step 4 - Perform the safe mode options in the following order until one of the options works for you. If one option works, do not continue onto the other options.
Restore Default Settings
Restore File System
Rebuild Data Base
Restore PS3 System etc...
Dec 31, 2010 | Sony Playstation 3 (PS3) Console
Hard disc is corrupted
You can possibly restore your system by following these steps.
Step 1: Turn off the PlayStation2_bing.gif 3 by holding the Power button on the front of the unit till the Power light is red.
Step 2:
Touch and hold the Power button, you will hear the first beep, meaning the PlayStation 32_bing.gif is powering on.
  1. Continue to hold the Power button and after about 5 seconds, you will hear a second beep, indicating the video reset.
  2. Continue to hold the Power button and after about another 5 seconds you will hear a third beep and the system will power off (Power light is red).
Step 3:
  1. Touch and hold the Power button, you will hear the first beep, again for the PlayStation 3 to power on.
    Connect a USB cable to the controller and the PlayStation 3 and press the PS button to enter Safe Mode.
  • Then you will see the Safe Mode menu.
  • This last step can possibly erase the data you have stored on your harddrive, so I recommend the options in this order...if one of them works stop and don't try the others, that way you may be able to retain your data.
    1. Restore Default Settings
    2. Restore File System
    3. Rebuild Database
    4. Restore PS3 System
    Mar 29, 2010 | Sony Playstation 3 (PS3) Console
    Ps3 initial screen says hard drive file system is corrupted and then goes through a restore. when it gets to100% it shows the start screen and then displays same corruption message again
    Sounds like power must have failed while the update was writing to the PS3 harddrive.You might be able to fix this problem by booting the PS3 into safemode. Here's the steps to do that:
    Step 1: Turn off the PlayStation 3 by holding the Power button on the front of the unit till the Power light is red.
    Step 2:
    1. Touch and hold the Power button, you will hear the first beep, meaning the PlayStation 3 is powering on.
    Step 3:
    3. Rebuild Database
    Mar 28, 2010 | Sony Playstation 3 (PS3) Console
    When I turn on the PS3 it does not boot up.
    Hi try to restore/rebuild your database and filesystem.
    in worst case do the "Restore PS3 System" this gonna wipe your harddrive, so remember to backup your saves, games that you bough on PSN can be redownloaded fromt he store.
    Step 2:
    Step 3:
    Step 4
    : We recommending performing the safe mode options in the following order until one of the options works for you. If one of the options work, do not continue onto the other options.
    3. Rebuild Database
    Oct 10, 2009 | Sony Playstation 3 (PS3) Console
    Sony PlayStation® 3 (60 GB) Console Logo
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
