Question about Samsung SP-R4232 42 in. Plasma HDTV
Samsung PS42S5hX Similar to other reports my PS42S5HX intermittently goes black on the top half 2 or three times a day, a very slight tap to the side of the panel clears it
  • Bluebazzer Sep 17, 2007
    Thanks, I'll investigate at the weekend, if its in the vertical I would have thought I would have lost the entire picture. Good thing as you say it does not appear to be a parts failure
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Very simple your problem in vertical section. as you say that slight tap brings normal so there is no parts failure it is due to loose contact in vertical section mostly ele.capacitor in feedback ckt.
Posted on Sep 14, 2007
SOURCE:
Samsung UN55HU7200FXZA. Black screen. When turn on,Verticals white & black lines, and after 2 seconds goes black (no video).
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Feb 20, 2017 | Samsung UN55HU7250 Curved 55 Inch Ultra
I have a samsung tv , model code. ps42s5hx/xex , version sa01 ,, the symptom is showed on the picture (black on the left) what should i do to resolve this problem? I am a local tv engineer in Albania
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Aug 10, 2015 | Samsung Televison & Video
Samsung PS-63P71FH top half switching off
the buffer board in one side has problem.
Aug 15, 2012 | Samsung P63FP 63" Plasma TV
42lh3000 Right half of screen is black but goes better when warms up, still flickers at times, how can i repair this? The tv is about 2 years old and never had a problem with it before, the sound is great...
I have fixed an LG 42LH3000 with this very problem. Large TVs have a tendency to flex and bend ever so slightly when being moved or through heat, this can affect the connection of the ribbon cables at the top of the screen - either at the end where the Tcon board is or where the screen driver board is. When one end of the cable loses contact, half the picture goes (there are two ribbon cables. one for each side of the screen).
Remove the cables then carefully reattach them. If you still have an intermittent problem would suggest leaving the screws out of the T-con board as this will give the ribbon cable more slack.
Don't attempt any of this unless you know what you're doing - risk of damage to screen if handled indelicately also risk of fire when plugged back if the ribbon cables aren't secured properly.
Dec 19, 2011 | LG 42LH3000 42" HDTV LCD TV
Black pixels in shading and back ground turning red
This is not a "rear projection" plasma TV for whiuch you offered solutions, It is the LCD Flat panel the Liquid Crystal Display a 40" Samsung. I do not think this problem is a dead pixel as that woulde be "black" Reading on the web I found only one post that appeared to be the same or similar and the person said somehing about "switching the red wire" Maybe it is a "stuck" pixel -- sticks on red once in a while. Like previously after the first time it occured it has not come back in three days now. Samsungs repair comes today i will cross my fingers.
Jun 29, 2009 | Epson Livingstation LS57P2 57" Rear...
LCD TV SOUND BUT NO PICTURE
Faulty parts on PS board , bad press for Samsung
Because the Samsung LNS4051D would not turn on and the power LED would blink 4 times and the relay would click and this would repeat again and again. I replaced power supply board parts CM806, 811, 812 & 817, all 1000 uf 10v capacitors, three had their tops bulged up slightly that I missed on initial visual inspection. After seeing the reports of problems with these caps on http://www.fixya.com/support/t1336881-will_not_turn_or_off , I replaced them with Radio Shack part 272-1032, 1000 uf, 35v. They are slightly bigger, but fit OK. TV is working fine now. Cost was 4 x $1.59 = $6.36 plus the time. I saved between $100 to 300 in the process of either replacing the board or getting the unit serviced.
Dec 31, 2008 | Televison & Video
No picture, sound ok
I have a similar issue. Sometimes the entire screen goes black and sometimes only one-half - either the top or bottom half goes black. The only solution we have found is to gently tap the TV (usually the front side) and the picture will come back for awhile. It almost seems heat related as it only goes out after the first 10 minutes of use. There must be a fix to this.
Aug 25, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Samsung PS42S5hX - Bottom half of screen flashing black sometimes permanent, does not do this all the time.
might be y drive board bottom half it connects to the y sus board usually on the left side if your looking at the set with the back off
May 27, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Samsung PS42S5hX
This could be caused by the Y-main board or the lower buffer board going bad
May 26, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Samsung SP-R4232 42 in. Plasma HDTV Logo
106 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
